Old 04-25-2013, 09:07 AM   #781
stickerbush
stickerbush's Avatar
Oddometer: 45
Originally Posted by SOLO LOBO View Post
Added six gallons to my almost empty tank and rode in today ~15 miles.
My initial impressions are.... WOW!
It's much better (thanks Alex !)
Compliant, planted, firm and feel right about where they need to be. Previously they were bouncy, a bit weird.
How's the plushness factor?
"I ride a GS scooter with my hair cut neat..."
stickerbush is offline   Reply With Quote
Old 04-25-2013, 09:19 AM   #782
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
Really good, but after adding two click of comp and rebound to the rear shock (which really changed the behavior of the shock!) I had a few small instances of speed wobbles coming home on the freeway between 65-70mph when hitting pavement ridges (fairly significant ones).
Think I need to up my steering head bearing rep-load a bit. It's hard to judge where it should be since the main wiring harness really impacts the bars ability to fall to the sides.
NOTE: for the other R-Dubb clamp triple users CHECK YOUR UPPER AND LOWER FORK CLAMP ALLEN BOLTS ON THE TRIPLES!
Mine were a bit loose when I pulled my forks last time and I know I had them all tight.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 04-25-2013, 03:40 PM   #783
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,392
yep. Don't use your "grunt" meter, torque those fuckers. I used 20ft/lb on the lower and 25ft/lb on the upper. Just took them off to put the gaiters on and they are still at spec.
hardwaregrrl screwed with this post 04-26-2013 at 07:54 AM
Old 04-26-2013, 01:23 AM   #784
Cdubs
made for adventure
Oddometer: 164
springs
Hey all, where did you end up with springs? Jenna I think I read you had .65kg dual springs? Does that mean progressive?
Anyone else have spring rate baselines to go off of? I want to give the suspension shop something to work with as the bike is all apart right now. Hoping I'll have the HPM guy triples soon, but no word from guy in a week or so..
Cdubs is offline   Reply With Quote
Old 04-26-2013, 07:54 AM   #785
hardwaregrrl
ignore list
Oddometer: 7,392
Yep, .65 progressives
Old 04-26-2013, 09:03 AM   #786
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
I have 0.54's and Ontic has 0.55's. EDIT Ontic as 0.60's
R65LazaruS
Solo Lobo screwed with this post 04-26-2013 at 03:05 PM
Old 04-26-2013, 09:06 AM   #787
hardwaregrrl
ignore list
Oddometer: 7,392
I will say, I asked for a more street oriented feel as I spend most of my time on pavement. Wish that wasn't the case. But it's pretty ok off road. Stiff, but it works.
Old 04-26-2013, 09:25 AM   #788
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
I was thinking about springs as I rode in today.... and I wanted bias towards dirt riding... the 0.54's I have actually feel pretty firm and I wouldn't want any stiffer myself.
I need to pack on the miles, but right now can say that the big bumps are nearly invisible, but when I ride over small bumps the front is less compliant then I would like and a bit bouncy.
I am going to ride more miles and then ask Alex for his suggestion on what to adjust.
R65LazaruS
Old 04-26-2013, 01:28 PM   #789
Cdubs
made for adventure
Oddometer: 164
How much do you guys weight? I read through and Jenna said 160 with motocross boots on
Thanks for the baseline!
Old 04-26-2013, 01:29 PM   #790
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
I'm 175-ish in gear
R65LazaruS
Old 04-26-2013, 02:23 PM   #791
hardwaregrrl
ignore list
Oddometer: 7,392
That's me sans gear, I'm closer to 170 full armour and boots.
Old 04-26-2013, 03:50 PM   #792
Clay Spinner
Clay Spinner's Avatar
Oddometer: 675
I'm 175-ish in gear
You guys ruin the whole American stereotype! Geesh... I was 175lbs when I was 15 and that was my playing weight, off season add a good ten pounds at least.
Clay Spinner is offline   Reply With Quote
Old 04-27-2013, 05:21 AM   #793
ontic
Oddometer: 1,070
Hey Cdubs,
Depending on the time of year and whatnot, I weigh at or just over 100kg in my birthday suit (220) so a fair bit over the last two featherweights especially when clad in gear
I'm 6'1" and kinda top heavy.
.60 kg/mm has felt very nice for my test rides to date but sadly I don't have much serious use on the G/S yet. I like my springs firmer than softer though.
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 04-27-2013, 11:47 AM   #794
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
Here's another piece for general consideration:
Front sag: 25% (with me on the bike and ~6 gallons of fuel. 0.54 springs and a small amount of pre-load)
This is using the stock BMW spec of 200mm travel, which means the actual % would be a bit lower.
For the rear, I am at 22% with my Ohlins BM317 that has the 698-21 (175-200lb sring that has a spring length set at ~210mm (as opposed to the 213 spec from Ohlins).
Jenna, what is your front and rear sag?
R65LazaruS
Old 04-27-2013, 11:59 AM   #795
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 639
out of interest - should we be calibrating sag % keeping in mind whether a fork is full length or shortened?
Ras Thurlo is offline   Reply With Quote
Times are GMT -7.   It's 06:34 PM.
