Old 05-01-2011, 08:13 PM   #91
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,116
If you filed it craftily enough you might still derive some steering stoppage out of the whole foul jamboree!
Thanks for the dimensions, lads.
Old 05-01-2011, 09:03 PM   #92
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Yup, I am going to do some more checking and figuring before heading to the machinist.... hope to preserve some steering stop material as you suggest Lornce!
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 05-02-2011, 01:06 PM   #93
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Originally Posted by ontic View Post
Got a reply from Gletter regarding an inquiry about their triple clamps for 50mm WP extremes. As part of the email they sent me an image I hadn't seen before and I thought it belonged here.
Nice looking, not so cheap
Those sure look like Marzocchi Magnums in 45mm to my eye, but point taken... they do make 'em for 50mm as well.
The Marzocchi's do have the advantage of having comp and rebound adjustable on the fly, where the WP's take a screwdriver... but there are other downsides with 'em as noted on the first post.
R65LazaruS
Old 05-02-2011, 01:10 PM   #94
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Nice update Solo.
Damaging things in the Vice? I'm pretty good at that trick!.
LOL
I too would probably just take to it with a file, after I attacked it with an angle grinder. Of course, first I would clamp it in the vice to do all this!.
Sage advice Ontic. I am borrowing an angle grinder tomorrow and will be doing just what you propose (including the bit about the vice).
Looking at this photo it looks like if you turned the triple towards either extremes (left or right) that the steering stop would at some point drop down past the ridge that is blocking it allowing the bearing to seat. Is this the case?.
The trip's didn't swing far enough to have the tab drop into the open space
I am trying to imagine the radius of material that would have to be removed from that ridge. How thick/high is this ridge btw?
Will have to measure later...
On the other hand, would packing the lower bearing up with a spacer work? Would depend if you have enough length in the stem I suppose.
Perhaps with the stock KTM stem, but mine is shortened to work with BMW's
P.S. My WP50 ktm front-end seller seems to have disappeared. No reply for a couple of weeks now. I have been hoping for a long holiday on his part, but it might be time to start looking again. Dammit.
Bummer, I have a line on a pair from a guy in Brussels, and I will pass it on to you if I don't buy his internals to be a spare for the one I f'ed-up!
R65LazaruS
Old 05-05-2011, 08:25 AM   #95
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Prepping for surgey...
bearing seat to stop-tab (rough measurements below):
Triple clamp lip total height:
Tools of destruction
R65LazaruS
Old 05-05-2011, 08:42 AM   #96
ontic
Oddometer: 1,070
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 05-05-2011, 08:48 AM   #97
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Also in the news, I have a few good lines on a replacement damper tube, have some specs from Jay.T's fork guy's oil weight and volume suggestions, need to buy some fork oil (800cc per leg ) and need to order front brake pads (galfer green's)..
With any luck, I may be able to have the triples on the frame by this weekend and begin fabbing some supports for the headlight unit....
R65LazaruS
Old 05-06-2011, 09:03 AM   #98
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Some fork tuning info from Jay.T who has Extreme's on his R100GS:
Originally Posted by Jay.T
The oil level was set at 130mm. The rebuilder explained to me that the type of dampening system WP uses is not affected by the weight of oil as the BMW. The invoice shows 5 weight. He did make adjustments to the shims and custom wound springs where added. Machined spacers to 2". I supplied him with the overall length to get the ride height and angle where I wanted it. Then provided him with weights of me, totally loaded, bike wieght etc, he came up with the rest for the internals. The bike now handle like a dream. I have a list of part numbers he added if you would like. They would have to be KTM part numbers? Let me know.
-Jay.T
R65LazaruS
Old 05-06-2011, 05:59 PM   #99
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Brake pads ordered check
Lower triple notched to clear frame tab... check
Yeah, I know that looks a bit rough, but I'n not done yet!!!
BMW Steering head bearings on hand.... check
but it is not as happy an ending as we had hoped
Bearing ID for the KTM stem
And for the BMW
Looks like I need a set of KTM steering head bearings before the trip's are on as they have a 29mm ID to the BMW's 28mm ID... may have to push this out a week or two...
R65LazaruS
Solo Lobo screwed with this post 05-06-2011 at 06:15 PM
Old 05-06-2011, 06:15 PM   #100
ontic
Oddometer: 1,070
(EDIT- crossed posts with you, photos and more info now)
Oh, you are cruel!
The tuning info regarding oil weight is interesting. I have read other brief write-ups that mention playing around with higher than 5W oil, to good effect...?
So, will the KTM tripples work?
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 05-06-2011, 06:17 PM   #101
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Well. on the first page there is a picture of crazyivan riding his G/S with my lower triple (which was formerly his lower triple) down the road... so I think the chances are very, very good.
R65LazaruS
Old 05-06-2011, 07:33 PM   #102
ontic
Oddometer: 1,070
Cheers Solo,
OK so, KTM bearings- do you use the KTM races as well, or do you match the KTM bearings with the BMW races? I guess the question is, do you know how the OD of the bearing races compare?
On the other hand,
Is the KTM stem steel as well? It looks a little different (alloy-ish) compared to the beemer one. It looks like there would be plenty of material there to safely turn it down 1mm. The turn-down would be easy enough (for me to get done free) but the re-threading a little more annoying. I am not sure if I know anyone who can cut threads for me for free.... I'll have to find out.
I would imagine that in reducing it only 1mm over-all would not completely remove the previous thread (the valleys would probably still be there?) so if the thread pitch is the same between the beemer and KTM stems/nuts the thread could just be deepened (possibly even very very carefully by hand).
Anyway, if a simple bearing swap does the job then that sounds best. If you have to mix bearings and races every time you change them it might be a little less than ideal for parts availability (say for example having to find/order two different items from a remote place) and for the 'tight-of-arsed'
Anyway, I'm just passing-time and chewing on thoughts. My tank has shipped and my Ohlins has shipped. Still no word from my front-end seller, but still no more activity on his account- I haven't given up hope completely (maybe he is on a really long holiday), but I am a stubborn bastard. Got some pannier frames yesterday that are meant to fit a G/S, but they don't, so they will have to go back to my parts guy.
I've been loosing a lot of auctions on ebay.de lately which is annoying. What the market pays for second hand prices (on parts that are still available new) is bizarre at times, and for parts that I need/desire that are NLA the prices can be really really annoying.
Oh well,
looking forward to the next update,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 05-06-2011, 07:44 PM   #103
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,353
Wow ... Solo ... I know you probably haven't done any calculations per say ... but cutting into the triple ... eeek.
I'm guessing that you probably won't go to the 'extreme' that the WP / KTM guys were calculating on ... and there appears to be a lot more meat on the triple ...
I just don't know. May the force be with you. Live long and prosper. All that.
PS - Looks good though. And I'll admit ... cutting things like that is something I would probably do ..
Fred * '85 R80RT G/Sified * '73 R75/5 LWB
"Simple" with a Goal of "Ludite"
Beater is offline   Reply With Quote
Old 05-06-2011, 08:12 PM   #104
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,760
i must admit i also cringe at the thought...
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 05-06-2011, 09:08 PM   #105
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,116
That won't break in a hundred years, but you could have been a little gentler/neater about it, you butcher.
Times are GMT -7.   It's 09:08 AM.
