Old 04-10-2011, 12:57 AM   #1
GeckoRider OP
GeckoRider's Avatar
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 412
Light weight batteries
So trying to wrap my head around all the options for light weight batteries out there I made this spreadsheet. I wanted to share what little I have found so far.
Standard disclaimer; I have no affiliation with any of the Makes or Vendors, all the specs were pulled from the Maker's websites when possible, if there is marketing Bull here sorry, this list is far from complete, use at your own risk, etc. I also looked the the "Flagship" models for each Make so I am not comparing apples to apples.
That said, if you know of other Makes I have missed, or Vendors with better pricing, or any other info to add please let me know and I will update the sheet when I can. Also this list was for the F800GS so if any of these would not work without serious mods (trimming tray is OK, tearing apart the bike is not) let me know and I will remove them.
Here is the link (hope it works):
https://spreadsheets.google.com/ccc?...thkey=CNSG4vsP
F800GS Mag/Black 2009 "Faucon GriS"
Farkles; Garmin GPSMap478 in a TT cradle, throttle Rocker, Airhawk seatpad, Pivot Pegs, Renthal grips, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard.
Wishing for farkles; If/when I can ride offroad better- suspension, rims.
GeckoRider is offline   Reply With Quote
Old 04-10-2011, 01:13 AM   #2
SocalRob
SocalRob's Avatar
Oddometer: 9,313
For comparison, what does a standard battery weigh?
Rob
'07 White (the coolest color) GSA rider
'13 Husky Strada & '05 Honda 400XR
SocalRob is offline   Reply With Quote
Old 04-10-2011, 02:51 AM   #3
GeckoRider OP
GeckoRider's Avatar
Oddometer: 412
After looking around the unofficial weight I found was 4.7 kg, 10.3lbs.
Old 04-10-2011, 06:18 AM   #4
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,120
I replaced the standard battery in my F800GS which weighed 4.8 Kilograms with the Shorai 18 amp hour which weighed 960 grams. You could use the 14 amp hour battery which is only 830 grams.
Even the "heavier" 18AHr battery is unbelievably light, saving almost 4Kg high up on the bike.
The good news is that it also starts the bike perfectly.
Until you pick one of these up you couldn't believe how light they are, it really feels like there is nothing inside the case. If I was a motorcycle manufacturer I would be all over this ... 20% of the weight and probably one third of the volume of the traditional battery!
"All that is necessary for the triumph of evil is that good men do nothing." - Edmund Bourke Irish orator, philosopher, & politician (1729 - 1797)
Ducksbane is offline   Reply With Quote
Times are GMT -7.   It's 12:48 AM.
