Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 04-10-2011, 10:47 AM   #1
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
rear brake drum removal on my 1974 chevy pickup
it is a C20, 3/4 ton with floaating axles, I have the axle out whic was easy, I have all three of the keepers off, two spanner nuts, and the tin locker between them. The drum feels loose but won't slide off. Is there something else that needs to come off before this drum will come off or do I just need to keep teetering it till it works off?
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 04-10-2011, 10:52 AM   #2
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
It feels like it is hanging up on the shoes. Where IS the adjuster and how does it work? I don't see a rubber plug like on a regular 1/2 ton drum system.
Sniper X screwed with this post 04-10-2011 at 11:01 AM
Old 04-10-2011, 12:44 PM   #3
troidus
Oddometer: 14,658
Back then GM sometimes didn't knock out the adjuster plug hole at the factory. Look for a plug-shaped recess in the usual spot and see if it appears to just be tacked in place. You might have to hit it with a hammer and punch to knock it out. Another place to look is on the face of the drum, but you probably would have already found it by now if it had one.
troidus is offline   Reply With Quote
Old 04-10-2011, 01:11 PM   #4
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
it doesn't have either. What is there at the top of the backing plate where the adjuster SHOULD be is a very large stut sticking out with a nut on it. It has the be about a half inch stud with the large but on it.
Old 04-10-2011, 02:11 PM   #5
Hughlysses
Hughlysses's Avatar
Oddometer: 3,336
On all the drums I've worked on, the adjuster slot is at the bottom of the backing plate.
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is online now   Reply With Quote
Old 04-10-2011, 03:03 PM   #6
Motornoggin
Two-Bit Throttle Bum
Motornoggin's Avatar
Oddometer: 21,140
Adjuster should be at the bottom. The stud at the top is where the pull back springs are hooked, it's big because it has a lot of tension on it.
O.K. Joke's over. You can bring back the constitution now. Please.
My Wyoming has an East infection.
http://motornoggin.smugmug.com
Motornoggin is offline   Reply With Quote
Old 04-10-2011, 11:16 PM   #7
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Pictures worth a thousand words.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 04-10-2011, 11:51 PM   #8
RVDan
RVDan's Avatar
Oddometer: 2,633
Some of those didn't have holes to get to the adjusters.
The bearing could be hanging up on the spindle. You'll probably need a slide hammer to get it off, and it will probably leave the bearing and seal on the spindle.
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 04-10-2011, 11:59 PM   #9
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,448
It's almost always because the shoes are hanging up on the drums because they've worn a channel in the drums, though.
The future is bright, fruitful, and positive.
Old 04-11-2011, 03:40 AM   #10
42
Bokononist
42's Avatar
Oddometer: 17,424
Actually the ring of rust on the inside lip of the drum is usually the problem. Especially if the drums have not been removed in a long time.
The shoes run about a quarter of an inch inside the drums. The rust builds up pretty thick.
Crawling from the wreckage
42 is offline   Reply With Quote
Old 04-11-2011, 07:37 AM   #11
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
I wish it was there.
Old 04-11-2011, 07:38 AM   #12
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
That IS what is happening.
Old 04-11-2011, 07:42 AM   #13
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Round two then,
Slide hammer, or a chain and your ATV and JERK the drum off, you'll end up needing a brake hardware kit typically when your done.
I have used pry bars to pop the head of the brake nail or keeper out so I could get em off.
Sorry about the troubles. Been there and done that. They don't give you a T-Shirt either.
Old 04-11-2011, 07:52 AM   #14
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
Round two then,
Yeah bummer, but it'll be bitchin to have good brakes again when I am done since for some odd reason, I love this truck! A guy gave me a real bitchin exhaust set up for it too so I think whilst I am looking for a steering gear I'll pop that bitch on there too. It is Hooker headers and flowmaster mufflers on a full length pipe set up. Right now it is a tiny 1.5in bargan basement dual exhaust system on it with stock manifolds. I can actually feel it holding it back.
Old 04-11-2011, 07:53 AM   #15
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
Plus at I had planned to replace everything under there anyway parts kit drums shoes everything....
Thread Tools
Times are GMT -7.   It's 06:02 AM.
