Old 04-12-2011, 01:31 PM   #1
trizzo OP
Oddometer: 207
Touratech Mudguard Riser Kit
How much rise does the touratech mudguard riser kit give over the stock fender? Are there any other kits out there that add more height than the Touratech?
trizzo is offline   Reply With Quote
Old 04-12-2011, 01:43 PM   #2
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
About 1/2 inch. I installed mine a couple of weeks ago, but I haven't had the chance to test it in deep, sticky mud yet. My guess is that it will make a little difference, but perhaps enough.
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 04-12-2011, 02:43 PM   #3
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
TT defines this 1/2-inch dimension as follows: This height increase gives the tire as much space as is technically possible....
Whatever that means.
Fred
FredRydr is offline   Reply With Quote
Old 04-12-2011, 05:50 PM   #4
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,236
Fred
What it means is, if you raised the fender any higher it will ram into the bottom of the beak at full suspension travel.
It wasn't enough for the mud I encountered which is why I did the high fender conversion. YMMV.
MCMXCIVRS is offline   Reply With Quote
Old 05-01-2011, 08:43 PM   #5
JFB
Oddometer: 21
What is the part Number
Couldn't find the TT part number on the canadian site. Can someone give it to me or a direct link would be nice too.
Does someone else do those riser for the front mud gard.
JFB is offline   Reply With Quote
Old 05-01-2011, 10:02 PM   #6
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Not much, really. But it works for me.
johngil is offline   Reply With Quote
Old 05-01-2011, 11:58 PM   #7
Dockstrada
Dockstrada's Avatar
Oddometer: 238
http://www.touratech.com.au/home/54-...ypage.tpl.html
Dockstrada is offline   Reply With Quote
Times are GMT -7.   It's 10:45 AM.
