Old 04-15-2011, 05:04 PM   #1
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
My WR250R Build.
Hi all,
Here is where I am going to document all the modifications etc that will be done to my newly purchased WR250R. It may be interesteing to some, it may not be to others, you decide whether you stay and read on.
So first off, I bought a bone stock 2010 black WR250R. It only had 3700km on it and was only 6 months old, so still still has a year and a half of its warrant!
Joe Watson is offline   Reply With Quote
Old 04-15-2011, 05:25 PM   #2
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
The first thing I did was fitted a wolfman enduro tank bag.
Old 04-15-2011, 05:44 PM   #3
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
Next was fitting a Zumo 550 and a 12v outlet to power it.
Making up the mounting bracket and doing the wiring with fuse:
Getting into the guts to find some wiring:
Mounting of the GPS:
Final mounting point for the 12V oulet:
Joe Watson screwed with this post 04-15-2011 at 06:24 PM
Old 04-15-2011, 05:48 PM   #4
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
Next was removing the seat strap because it was annoying. Removed the bolts, strap came off, glued the foam back down:
Old 04-15-2011, 06:22 PM   #5
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
I then started knocking up some pannier racks to suit my old RJays bags. This will only be a temporary thing until I get my giant loop.
Back frame:
Measuring and mounting of back frame on the right side. Using the pillion pegs for the front mounting point:
Using the hole above the exhaust mount for the top mounting point:
For the rear mounting point I used the stock number plate section:
Right side complete:
Left side front mounting:
Left side top mounting using the helmet lock section:
Both of the rear mounts in and done:
Left side now complete also:
From the rear:
Bags just thrown over:
Clean and undercoat:
Completed ready for fitting:
On the bike:
Old 04-15-2011, 06:26 PM   #6
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
I fitted a waterproof 12v outlet under the seat with fuse etc. This is used for a pump, charging phone etc so you don't need the ignition on like the 12v outlet at the front of the bike:
Old 04-15-2011, 06:28 PM   #7
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
Sanded out the scratches etc from the exhaust cover and painted it flat black. Not sure if I like it or not yet, might go silver:
Before:
After:
Old 04-15-2011, 06:31 PM   #8
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
Went on a decent ride with the bike fully loaded, full ride report coming soon:
Old 04-15-2011, 08:35 PM   #9
vnp514
Oddometer: 631
Thumb
Nice Job!!
Pete
vnp514 is offline   Reply With Quote
Old 04-15-2011, 08:37 PM   #10
mbabc
Curmudgeon trainee
mbabc's Avatar
Oddometer: 1,981
Great write Up! Thanks for sharing.
"I have never seen a Kentuckian without a gun and a pack of cards and a bottle of whiskey." - Gen. Andrew Jackson
'08 WR250R - '12 Super Tenere - '64 CT-Frankentrail
Little Blue goes looking for Orange
I don't know what time it is, I've switched to kilometers
mbabc is online now   Reply With Quote
Old 04-16-2011, 12:38 AM   #11
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,204
Like the black look Joe.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 04-18-2011, 03:11 AM   #12
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
First adventure ride on the WRR:
http://www.advrider.com/forums/showt...3#post15694603
Old 04-20-2011, 04:43 AM   #13
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,220
FYI... none of your photos are appearing, here or in your RR... "Bandwidth Exceeded, upgrade to Pro!"
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 04-20-2011, 06:11 AM   #14
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
Should hopefully be fixed soon.
Old 04-21-2011, 01:01 AM   #15
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,033
Found a better spot for my rego label:
Times are GMT -7.   It's 01:56 PM.
