Old 04-28-2011, 08:28 PM   #31
goroka
Oddometer: 93
Thanks for that Joe - I am usually with pure enduro bike hence my comment
Cheers
goroka is offline   Reply With Quote
Old 04-29-2011, 02:10 AM   #32
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,030
So today's job was a tool tube. I wanted somewhere permanent to carry my tools until I made my rallye bash plate. So a quick and simple tool tube was on the cards.
I had some PVC pipe and got a few fittings (finally one of my projects actually costs me money!!)
Fabricated a mounting bracket for the pipe:
I then made some "Straps" by bending some metal in the shape of the pipe on my anvil and welded them in place. Trying to get it to match as close to the exhaust on the other side as possible.
All this needs to fit in this little pipe:
Somehow I JUST made it all fit and all was good:
Joe Watson is offline   Reply With Quote
Old 05-04-2011, 03:59 AM   #33
goroka
Oddometer: 93
Good to see the project progresses My GTYR exhaust has aarrived - will be intersted to see the difference. I am also on the Coast - would be good to catch up on a ride sometime. I have yet to see another WRR offroad locally.
Cheers
Old 05-09-2011, 04:30 PM   #34
goroka
Oddometer: 93
Well worth the expense for GTYR exhaust and pivot pegs - also adjusted front forks - the improvement in performance and ride is is significant. Something to think about when your budget allows.
Old 05-09-2011, 07:43 PM   #35
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,030
Pivot pegs are definitely on the list after just now going to MX boots. I am getting used to the shifting and braking but pivot pegs would help out a lot I am sure.
When you say adjust the forks, what do you mean by that?
Old 05-09-2011, 10:18 PM   #36
goroka
Oddometer: 93
"When you say adjust the forks, what do you mean by that?"
There are adjustments on the top and bottom of the front forks for rebound and compression. Also a valve to release any air that gets trapped in the system. If you have the handbook for the bike check out section 4 page 14. I havent changed the back shock absorber.
Cheers
Old 06-17-2011, 04:10 AM   #37
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,030
Big box arrived ALLLL the way from the US of A.
All looks good
Starting to pull the bike down
All apart and ready for the fuel pump swap etc. (Bike is taken apart more than needed because I was fitting other stuff at the same time, more on that stuff later.)
Mucking around with mine and my mates new tank
Swapping stuff over:
Fitting the splash line and re-mounting the fuel light sensor:
The line I "T"ed into, I hope it was the right one!
All fitted up:
I had to drill out the rear tank mounting holes a bit and also elongate the seat bolt holes. No problems though and now will be easy to take everything on and off. So I would say that I am the first WR250R to have the IMS big tank!
Also added some stickers as you can see to try to offset the white tank a bit.
Old 06-17-2011, 04:21 AM   #38
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,030
I also did a lot of new things in the "Cockpit". New handlebars - Tag Metal X5 in a YZ double high bend.
Tag Metal grips with grip donuts:
Under the grips are the heated grip elements:
The wiring goes from the battery through a fuse, then one 12V outlet under the seat, then wires run to the front of the bike:
Up the front I have a 12v outlet for the GPS and also the wiring etc for the heated grips with the Hi Lo switch which is all run off a relay.
The resistor for the grips gets super hot and started melting the electrical tape so I moved it down to the bottom triple clamp to act as a heat sink:
This is where the switch for the heated grips is sitting for the time being.
I ran a wire for my hour meter / Tacho only to find out I only got the hour meter one..... : I have the tacho one coming so its all good cause the wire is already there ready to go now.
I also added these adjustable bar risers. Not the best idea, but I tested them and they are super solid. I have them up 30mm.
So here is the completed cockpit with under bar mirrors and GPS all mounted up.
Old 06-17-2011, 04:27 AM   #39
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,030
Fitted a 12 tooth front sprockets to help liven things up just a tad:
I also fitted some Michy AC10s front and rear with Michy 4mm ultra heavy duty tubes:
It is bloody hard getting the nipple out of the rim with 4mm tubes! I need one of those wire jigger things
The weapons of the trade:
I also balanced them up. Some stick on weights and a spoke weight for the rear:
and the front too:
Old 06-17-2011, 04:28 AM   #40
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,030
I will take it for a spin tomorrow or Sunday and check and adjust everything then give it a good wash and take some good overall piccies for you all.
Old 06-17-2011, 09:32 AM   #41
dadreier
American Flyer
dadreier's Avatar
Oddometer: 18
Question
Joe,
You commented that the bar risers were "not the best idea".
What don't you like about them?
Dennis
dadreier is offline   Reply With Quote
Old 06-17-2011, 04:23 PM   #42
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,030
Hi Dennis,
I do like bar risers, just not these particular ones because they are in sections to make them adjustable. I was just worried that they wouldn't be as solid. But only time will tell.
Old 06-19-2011, 06:02 PM   #43
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
They work fine except when you drop the bike the bars will need realignment due to movement in between all the pieces. Isn't hard to realign and doesn't take long. Used them on a lot heavier bike than the WR250R for a year with no problems. Can be fiddly when setting up etc due to the pieces involved.
Keep it going Joe.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-20-2011, 01:23 AM   #44
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,839
Now you have a IMS tank Joe will you be doing the suspension
White pig
b0mb3r is offline   Reply With Quote
Old 06-20-2011, 03:29 AM   #45
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,030
Suspension is definitely on the list, but it is a very long list and I don't really know how to prioritise it! I haven't even set up the standard suspension and it has been fine so far. So first on the list is setting up the stock stuff, preloads, rebound and sag etc.
Times are GMT -7.   It's 04:27 PM.
