04-16-2011, 02:41 PM
#1 |
Drunken Squirrel
Oddometer: 2,587
premature alternator failure? or dead battery?
Ok, so I am currently sitting on the side of the freeway waiting for my friend to pick me up... my bike is dead.
Died suddenly then wouldn't start back up. Initially I couldn't even get thee gauges to twitch or the dash to light up. After waiting a minute and removing the key and trying again it lights up but doesn't turn over. I take the seat and bat cover off to look at the connections, erything looks solid. I disconnect my gps and sae plug and try again, nothing. Then I get a jump start from someone and the bike comes to life, it runs! Then we disconnect the leads... DEAD CRAP!!! Try again, hold leads on longer, disconnect, Y seconds dead... So I am thinking alternator but I only have 17k miles!!!! ![]() Worse yet I don't think I am under warranty... Does anyone think things I have done could have caused this? I have noticed my battery was weak for a while now, at least the past year. I have my gps and sae hard mounted to the battery... I keep it on a battery tender junior almost all the time in my garage, notice it gets weaqk after just a few days off I have used synthetic motorcycle oil for past 3k miles, reg before. I have almost drained the battery a couple times but charged to full after, this was months ago. I use heated grips a lot but no heated gear Don't use the brights much, normal running lights Other than that I can't think of anything else related....
Check out my F800GS Ride Reports: Colorado (F800GS and 640ADV) Sep 2010 Riding to Colorado Solo! June 2011 3000 miles New Mexico and Texas! Arkansas Nov 2009 | Arkansas June 2010 | Arkansas Oct 2010 |
04-16-2011, 02:50 PM
#2 |
Citation Collector
Oddometer: 403
Not sure Ender. Sorry about the PIA. From reading about these types of occurances, I bought a different battery just to reduce the possibility that they are Exide related. Try that first...$70 and gives you a "known" to work from.
"An expert is someone who has made every mistake possible within a very narrow field of inquiry" -Niels Bohr |
04-16-2011, 03:17 PM
#3 |
Oddometer: 2,828
Your stator is most likely fine..... Bad battery... Remember if the battery is dead...these bikes will not run....even with a good stator. You have a PM...
Erling |
04-16-2011, 03:37 PM
#4 |
Drunken Squirrel
Oddometer: 2,587
Cool, hopefully it is just my battery!!! Alternators are expensive..
If anyone has ideas let me know! I am thinking I will go Odyssey....
04-16-2011, 03:49 PM
#5 |
Oddometer: 2,828
04-16-2011, 03:54 PM
#6 |
Oddometer: 408
Some else on this forum had an alt go. Might have been CHITOWN, but if I remember,BMW covered it despite being out of warranty. Icould be wrong.
FYI You basically described my bike too.but I only got s'not 9500 on the clock.
"We do not quit playing because we grow old, we grow old because we quit playing." Oliver Wendell Holmes |
04-16-2011, 05:16 PM
#7 |
Oddometer: 998
ONLY 17,000???? Mine did it at 6,000 miles.
It's the battery. Sudden death battery for sure. With the symptoms you describe I would consider you very lucky to have had it last as long as it did. Replace it, have the charge system verified, move on.
Ride Safe, Ride Often, RIDE!!!! |
04-16-2011, 06:15 PM
#9 | |
Oddometer: 1,353
Your symptoms are nominal for sudden battery death. YTZ Yuasa, Odyssey (some mods required), or new DEKA BMW part# 61 21 7 723 566. Not sure what the DEKA # is, but all 3 above are tried and true. P.S. if your stator ever does fail out of warranty, buying a new one from BMW is just one option. Another is to take the stator to a quality alternator rebuild shop and have it rewound and dipped in glass. Cheap quick and easy.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250 I love and miss you Jeneca and I'm sorry. JoelWisman screwed with this post 04-16-2011 at 06:30 PM |
04-16-2011, 08:17 PM
#10 | |
Drunken Squirrel
Oddometer: 2,587
Cool, thanks Joel and everyone for the comments. (Thanks GB for changing the title, I was thinking about that when I was at dinner). What I will do is put the battery on the tender overnight (can't hurt... right? ) and see if the bike runs in the morning long enough I can get my volt meter on it and see if the alternator is working.I do like the idea of the lithium ion batteries but I am not certain of the reliability or downsides, I will have to read the battery thread again. Very good info on the rebuild for the stator, something I would try if I find mine is dead... or in the future when it inevitable goes, hopefully later than 50k!
04-17-2011, 05:39 AM
#11 |
Oddometer: 201
You might also want to consider investing in a Battery Bug at the same time as investing in a new battery. http://www.argusanalyzers.com/batter...analyzers.html
04-17-2011, 07:11 AM
#12 |
House Ape
Oddometer: 2,169
Has everyone who has experienced a battery failure hooked up their battery to a charger at one time or another? I know these things seem to fail suddenly, but I've never had to charge mine, and the bike has sat unused for as long as a month and a half from time to time over the course of 3 winters now. I wonder if unnecessarily charging the batteries may contribute to their failure.
David I'm tryin' ta think, but nuttin' happens! --Curly |
04-17-2011, 08:22 AM
#13 | |
Oddometer: 2,828
Erling |
04-17-2011, 09:27 AM
#14 | |
Oddometer: 1,353
In every case of a battery under warranty failing, the customer was interviewed, battery charged by us, tested on an uber expensive battery tester sourced from BMW ect. Also bike charging systems were tested. Discernible paterns? A certain battery made by Exide that was loaded into certain years of f800, r12, and k13s accounted for about 85% of in warranty failures, though only 40% of the bikes we sold. This battery as of 2011 is no longer sold or equiped by BMW, though a similiar looking Exide battery is which ends in the part# 073. About half of these Exide batteries that failed were charged by customers. Durring all of this time the DEKA 566 battery was installed from the factory as a quality control test on perhaps 10% of these bikes. We didn't see a single DEKA 566 fail that was not atributal to customer abuse (bike laid up for greater then a month, battery left in bike and never charged). In short, it's the battery that is the problem. Not all are bad, not even half are, so some who treat the battery well will experience sudden death while others that treat the battery relatively poorly will have their batteries last 3 years. I believe BMW knows this, though it took them a while to figure it out. Currently all USA dealers are to report any in warranty battery failures of Yuasa or DEKA batteries through PuMA, but we aren't required to report exide battery failures. That kinda says to me, "we know the exides have a quality issue, were trying to make sure the DEKA and Yuasa models do not". In my opinnion, riding all year is the best for battery longevity. If extended layup is necessary, use a charger. A certain number of customers kill their batteries using the wrong charger, or a defective charger. A certain very small number of bikes have a battery killing defective charging system. A larger though still small number of bikes have a defective ZFE or ABS module that kills batteries. Some bikes also have accesories wired in a way that kills batteries, or just too much load hooked up. For this reason, when a battery does fail, you should bring the bike, battery, and any external charger you use into the dealer so all can be omitted or determined to be the cause. But long story short, the Exide oe battery fitted to most k7x F800 and F650 bikes manufactured before 11/10 are of questionable quality. Going forward, it appears BMW is done with that battery which is great, cause I'm tired of making excuses for them lol. If anyone wishes to know way more then the average soul knows about batteries, this is a good resource: http://batteryuniversity.com/ Ride often and enjoy.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250 I love and miss you Jeneca and I'm sorry. |
04-17-2011, 10:15 AM
#15 | |
poser
Oddometer: 259
Sent from my Desire HD using Tapatalk |
