Old 04-16-2011, 08:36 PM   #1
snooker OP
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,589
Snooker's G650 XCountry Mods
I've gotten so much good info out of everybody else's mods I thought I'd post my mods here. It is a bit different as most of the writeup is on my external website here:
Snooker's BMW G650 XCountry Page
So what I'd thought I'd do is put up a post and a picture for each page on my website that includes several mods. Before you ask questions, please FIRST check the link at the top of each post for more info at my website, then feel free to post anything else here...
ok here goes... this bike is ridden 90% as a commuter, but when it goes offroad it tends to be a bit rough, so I have 2 sets of wheels and bags, depending on its usage...
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker screwed with this post 04-16-2011 at 09:38 PM
snooker is offline   Reply With Quote
Old 04-16-2011, 08:42 PM   #2
snooker OP
snooker's Avatar
Oddometer: 1,589
1. Mod: Replace stock exhaust muffler with a Leo Vince
Old 04-16-2011, 08:46 PM   #3
snooker OP
snooker's Avatar
Oddometer: 1,589
2. Mod: Select and install a Wilbers rear shock
[UPDATE: The following shows my Wilbers but it never worked out and after 2 years I switched to a Yacugar (sister company to HyperPro). I'll try to update my website someday... In the meantime:
At this site you'll find a lot of shock information including dimensions, sag, etc, for more than just the Wilbers... check it out!
For me, the shock was THE weak link on the bike - just ask my swingarm... so it had to be replaced.
snooker screwed with this post 11-09-2014 at 12:43 AM Reason: Yacugar
Old 04-16-2011, 08:49 PM   #4
snooker OP
snooker's Avatar
Oddometer: 1,589
3. Mod: Install a Sportech windshield
Old 04-16-2011, 08:53 PM   #5
snooker OP
snooker's Avatar
Oddometer: 1,589
4. Mod: Fender support - fix for FARFS! ...or... (Floppy-Ass Rear Fender Syndrome)
snooker screwed with this post 04-16-2011 at 09:12 PM
Old 04-16-2011, 08:58 PM   #6
snooker OP
snooker's Avatar
Oddometer: 1,589
5. Mod: Replace license plate light with bright LED auxiliary brake light and LED license plate bolts
Old 04-16-2011, 09:03 PM   #7
snooker OP
snooker's Avatar
Oddometer: 1,589
6. Mod: Install better Skid Plate, Engine Guard, Case Saver, Extenda Fender, Radiator Crash Bars, Highway Pegs
snooker screwed with this post 07-11-2012 at 12:12 AM
Old 04-16-2011, 09:09 PM   #8
snooker OP
snooker's Avatar
Oddometer: 1,589
7. Mod: Barkbusters handguards, gel grips, mirrors, paint tank panels black
Old 04-16-2011, 09:11 PM   #9
snooker OP
snooker's Avatar
Oddometer: 1,589
8. Mod: Install KTM Axle Cap Nuts that use common 27mm wrenches, also stainless steel wheel spacers
snooker screwed with this post 07-11-2012 at 12:14 AM
Old 04-16-2011, 09:17 PM   #10
snooker OP
snooker's Avatar
Oddometer: 1,589
9. Mod: Kickstand Improvements: disable safety switch, improve boot clearance, bigger foot pad
Old 04-16-2011, 09:25 PM   #11
snooker OP
snooker's Avatar
Oddometer: 1,589
10. Mod: Rekluse "auto" clutch
Old 04-16-2011, 09:29 PM   #12
snooker OP
snooker's Avatar
Oddometer: 1,589
11. Bags: MoJavi bag by Giant Loop, Wolfman tail bags, Nelson-Rigg tank bag and D-B-G number plate bag.
Old 04-16-2011, 09:37 PM   #13
snooker OP
snooker's Avatar
Oddometer: 1,589
12. Mod: Gear Shift Lever
[ UPDATE: THIS SHOULD BE YOUR FIRST MOD! AS THE RISK OF DAMAGE IS VERY HIGH SHOULD YOUR STOCK LEVER TAKE A DIRECT HIT! SEE MY WEBPAGE LINK FOR MORE. I Prefer the Touratech lever. You can also get a Yamaha or Honda one, I don't have the details exactly. ]
You MUST replace the stock alloy left as it is too stiff and will snap off the shifter shaft out of the transmission upon a big hit. Replace it with a softer bendable steel shifter lever. Shown here is an old F650 Funduro lever that is mounted, and a TT lever held up to it as a spare.
13. Mod: Add Tool Tube
This is the Tool Tube mounted in place of the charcoal canister. Has held up well on off road use. I use it for a fuel bottle:
14. Mod: Front forks reworked by TrailTricks
15. Mod: Hi-tech LiFePO4 battery
16. Auxiliary LED lights
PROBLEM 1: My broken swingarm
The page linked to above was originally written simply to show BMW North America of what happened. From it is links to my ADVRider postings.
This occurred on the 2010
LA Barstow 2 Vegas AMA ride. I blame the OEM shock for bottoming and stressing the shock - though I was careful to not let it bottom much in the 3 months I rode it before I replaced it with a Wilbers shock.
snooker screwed with this post 11-09-2014 at 12:46 AM
Old 04-16-2011, 10:16 PM   #14
snooker OP
snooker's Avatar
Oddometer: 1,589
FINALLY a huge page of various links for my G650 XCountry, from mods by other to parts, accessories, history, you name it. I hope it helps...
snooker screwed with this post 07-11-2012 at 12:33 AM
Old 05-02-2011, 06:29 PM   #15
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,043
Snooker--
You've done an amazing complete farkler's re-do of your bike with a whole bunch of smart, functional mods. One thing I find interesting is that your bike and my bike share only two of the same mods--the LIN3 aux brake light and the Scheffelmeir Alu Ritzelschultz--despite the fact that both bikes have many many mods. Shows how wide a range of options are available and how we can individualize our bikes to our own taste.
Thanks for doing all this work and posting up all the info on your website.
--DRONE
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Times are GMT -7.   It's 11:05 PM.
