Old 02-03-2005, 11:42 AM   #1
Surly OP
surly adventurer
Surly's Avatar
Oddometer: 2,131
640 Adv and Happy Trails bags
What size?
I am thinking Tetons with the canyon cut
The narrow 7.5" for the exhaust side and the 9.5 or 10.5 for the other side
They say that the capacity is 33.19, 39.82, 46.46 liters each
My idea is to sell the Jesse's on the GS to help pay for the HT bags. Not to mention I dont need TWO sets of bags.
What size are you running on your 640?
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 02-03-2005, 12:09 PM   #2
Surly OP
surly adventurer
Surly's Avatar
Oddometer: 2,131
Well I measured my Jesse's
they were aboot the same size if you didnt count the top lid
So if I went with the tetons
Large and small which is 10x15x18 and 7.5x15x18 i will have almost the capacity of the Jesse's minus the lids
Do you guys think this will be too big for the 640?
Surly
Where is Surly?
Old 02-03-2005, 12:12 PM   #3
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,558
It all depends on how much weight you plan on carrying with the sidecases.
My LC4 Adv. with Happy Trails from two years ago:
With the cases loaded up to 60-90lb. of camping gear, the bike is quite a handful to maneuver on pavement or trails.
I decided to go to a Pelican case as topbox instead, and keep the bike more nimble and able to squeeze through traffic.
Mankind is doomed & Physics do not lie
Chances favor the prepared mind.
Cat0020 is offline   Reply With Quote
Old 02-04-2005, 08:48 AM   #4
Surly OP
surly adventurer
Surly's Avatar
Oddometer: 2,131
looks like you got the big ones
talked to the guy at HT and he said id have to move the mounts on the bags to switch bikes and i dont want to do that
i guess i will just get the Tetons size in the 7.5 and 9 inch width (if the rack is asymetrical due to the exhaust) or two 9 inch wide guys
Do you think I can spray paint the insides rather than poping ($90) for the powdercoat?
Surly
Where is Surly?
Old 02-04-2005, 09:10 AM   #5
Nom de Guerre
Nom de Guerre's Avatar
Oddometer: 2,034
The Happy Trails site says that their "SU bracket" (pannier mounting brackets) require the passenger footpeg brackets in order to bolt on correctly. I'm wondering if it would be possible to fab some kind of spacer to work with the SU bracket if you want to strip the passenger peg brackets off your bike but still rig the side cases?
Anyone have any direct knowledge or insight into this?
They look like really nice side cases.
Nom de Guerre is offline   Reply With Quote
Old 02-04-2005, 01:50 PM   #6
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,238
check out passmore's bedliner thread; somethin about a cheap rattle can substitute that might work for inside the boxes.
BTW, does your riding involve crashin' alot? if it does you might want to consider Pelicans - many threads on this if you search. they are likely the best solution for longevity on a DS.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 02-04-2005, 01:59 PM   #7
Surly OP
surly adventurer
Surly's Avatar
Oddometer: 2,131
was considering pelicans
they seem a little heavy tho
crashin'? well i tend to have to pick my bike up when i am having fun
Surly
Where is Surly?
Old 02-04-2005, 02:27 PM   #8
Surly OP
surly adventurer
Surly's Avatar
Oddometer: 2,131
Handy Pelican PDF which has all the dimensions and, yup, weights too
http://www.pelican.com/pdf/table_cases.pdf
So Cases4less has the 1550 for 86.50 and the 1600 for 98.25That is a whole lot cheaper than any Alum box.....
Surly
Where is Surly?
Old 02-04-2005, 03:20 PM   #9
meat popsicle
Ignostic
Oddometer: 14,238
Yup
and when you go down they are way more likely to hold together than any commercially available pannier known to me.
in fact they are so sturdy that we (find those threads?) have been worried that if they catch on something it could tear the rack or the bike up! So we are considering ways to design in a "break away" mount so that w/ sufficient force the bag will separate in an attempt to protect the rack and bike from damage. the break away part would then be reloaded or replaced with a small cheap part to remount.
scottcolbath (sp?) has jimjib's ole bike w/ a good setup - using conduit clamps (adel clamps) as the break away part. they cost almost nothing and you can throw spares in the pannier for the eventual break away. only problem is they are a permanent mount and for some they want some way to quickly take them off and put them on; lockable thru the latch or a cable thru the pelican security holes
Old 02-04-2005, 04:14 PM   #10
DevDel
DevDel's Avatar
Oddometer: 560
You will break the subframe mounting a heavy box out on the tail. I believe Jimjibs bike had already been repaired. It's nothing but a flat tongue out there, with no real support. Okay on the street, no way for off road.
Dev
SPAM:
I've got Happy Trails bags I'm going to get into the flea market eventually, contact me if anyone wants them
DevDel is offline   Reply With Quote
Old 02-04-2005, 04:25 PM   #11
meat popsicle
Ignostic
Oddometer: 14,238
Dev
SPAM:
Yup, many have reinforced their LC4 subframe - Loaded's done it - purdy easy I hear. Always a good thing. But if you put your "lighter" bags on their and stuff them full of 50+ lbs then a few pounds of bags ain't gonna make much difference.
Old 02-04-2005, 06:16 PM   #12
DevDel
DevDel's Avatar
Oddometer: 560
Indeed even side bags are rough on the subframe if you ride fast over the rough stuff. They do have the advantage of tranfering the weight triangularly down into the lower portion of the subframe, and also gain support from the grab handle mounts, which are located in a braced area. Only the rear mounts put stress on the "tongue".
Dev
Times are GMT -7.   It's 07:16 PM.
