Old 01-01-2012, 11:00 PM   #391
vacantstare
vacantstare's Avatar
Oddometer: 294
could it be a 21" front wheel that is making it appear the front end is tucked?
vacantstare is offline   Reply With Quote
Old 01-01-2012, 11:47 PM   #392
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,796
Pretty sure that's a 19" wheel there.
The more I look at it, the more I am sure the tire will hit the front cover if you pump the forks hard. Hope not!
Old 01-02-2012, 04:32 AM   #393
oldroadie
Two wheel addict
Oddometer: 467
Maybe one of you will be kind enough to measure a swb R75/5 from the front axle to the points cover so I can take a look. It certainly has been cobbled together from a wreck as it does have a salvage titled frame. The only bent bits I could find were in the subframe, now replaced; that said it's the only R75 around so there's no "good" machine for me to compare. Don't let the tight angles in the little shop fool you, the forks are okay; not perfect but okay.
No worries Supershaft, after 40 years of riding I'm not much of a rider either...
oldroadie is offline   Reply With Quote
Old 01-02-2012, 07:00 AM   #394
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,297
ok I may be wrong, SS may be right.
I measured 7 inches from my tire outer diameter to the nearest point on the front cover.
This is a close estimate as I didn't want to remove the fender to measure directly from the tire.
I'm also reluctant at this time to remove the wheel to measure from the axle, though that's not difficult.
Oldroadie, you may enjoy this bit of reading: http://www.tonyfoale.com/Articles/RakeEx/RakeEx.htm
when I first saw the pic of your bike I was reminded of photos from Foale's tests, but chose to assume the best.
I don't know whether it's been mentioned particularly in this case, but your frame/headstock gussets need to be virtually flat, no deviation allowed beyond minimal distortion adjacent to the welds... i.e. due to welding.
here's a pic I took this morning
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner screwed with this post 01-02-2012 at 07:06 AM
Renner is online now   Reply With Quote
Old 01-02-2012, 07:55 AM   #395
ML WYDELL
NED
Oddometer: 497
Not a scrambler, but I'm workin on it.
ML WYDELL is offline   Reply With Quote
Old 01-02-2012, 08:12 AM   #396
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,297
you've got the right intent
Old 01-02-2012, 08:23 AM   #397
ML WYDELL
NED
Oddometer: 497
The problem is I always choose to ride over modify, its "continually under development and evolution" Tires are next Maybe K70's, sizes are hard to find with that 3.25 front. Maybe you have some recommendations.
Old 01-02-2012, 08:44 AM   #398
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,297
I wish I had some good recommendations, not a lot of 19" dual sport options as I'm sure you know.
I'm currently running a K70 on the R80ST and have no complaints but it is a street tire, only looking a little aggressive (in comparison to other streets).
this old thread may help:
http://www.advrider.com/forums/showthread.php?t=350434&highlight=tires
edit:
check this out http://www.advrider.com/forums/showpost.php?p=8696602&postcount=29
Renner screwed with this post 01-02-2012 at 08:57 AM
Old 01-02-2012, 11:41 AM   #399
Castironmeyer
Castironmeyer's Avatar
Oddometer: 58
[QUOTE=Renner;17619464]
Nice shot of your bike
'83 BMW R80 ST/PD SCRAMBLER
'62 VESPA 160 GS MK1
Castironmeyer is offline   Reply With Quote
Old 01-02-2012, 11:53 AM   #400
Castironmeyer
Oddometer: 58
[QUOTE= Tires are next Maybe K70's, sizes are hard to find with that 3.25 front. Maybe you have some recommendations.[/QUOTE]
I have been reading good things about Heidenau K60's from what I read they stick really good, last long (about 7k miles), and are cheaper than most. ($120.00 for 19" front on ebay) here is a link http://basinmotorcycleworks.com/heidenau.htm
I am leaning towards putting them on my ST before spring
Old 01-02-2012, 12:08 PM   #401
blaine.hale
blaine.hale's Avatar
Oddometer: 3,198
I have them on my r90...if that helps.
They're a dream! Kind of scary in the rain, though.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is online now   Reply With Quote
Old 01-02-2012, 12:16 PM   #402
supershaft
because I can
Oddometer: 9,116
Your best bet is to look for bowing in the gussets underneath the steering head. I think I can see it in the photos but that is stretching it even further. It might be just the lens.
I hear ya! 44 years now non stop for me except for injuries like right now.
Old 01-02-2012, 12:28 PM   #403
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,075
Not to add more anxiety to the frame issues, but it looks in the rear shot, that the rear wheel is leaning ever so slightly to the left relative to the bike itself. Again, could be distortion.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-02-2012, 04:19 PM   #404
Castironmeyer
Oddometer: 58
What size rear do you run, I need a 120/90 18 for my ST and can't seem to find one in stock.
Old 01-02-2012, 04:51 PM   #405
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
lens distortion my ass, that frame is bent like a mo-fo in the front. Has to be
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Times are GMT -7.   It's 01:21 PM.
