05-04-2011, 10:49 AM
#196 |
Forever young...
Oddometer: 1,622
I know I should have know this by reading the whole thread but I got the discount code and would like to order it ASAP, oh and I am lazy too...
I have the fallowing set up on my 990. Stock bars with Scotts damper with the triple clamp. Can I get info on which hand guards set I can use with this set up and if I need anything extra. Bar risers, etc. Thanks. ![]() ![]()
05-04-2011, 10:57 AM
#197 |
Oddometer: 77
I would like in on the discount code.
Many thanks, Pawlie |
05-04-2011, 11:35 AM
#198 | |
Off the road again..
Oddometer: 2,140
Print out a lifesize 1:1 top clamp template from HERE. Please note that when you print out the template, you MUST ensure your printer's auto-resizing options are turned off. These options will have names such as "shrink to fit" and "fit on page" and "auto-size". Turn off all of these or your lifesize template will not be lifesize (1:1). Once printed, you can double check by measuring from bolt-hole center to bolt-hole center to ensure your selected template is of true size. ie: 100mm is 100mm. 96mm is 96mm, etc. Images courtesy of crazybrit from this post: http://www.advrider.com/forums/showp...4&postcount=97 ![]()
For Sale: Micatech V2 Panniers and SW Motech Racks for Yamaha Super Tenere. |
05-04-2011, 12:42 PM
#199 | |
Oddometer: 2,140
Paul said he had replied to your email a while before you posted here, so to check your junk mail just in case it went there. Here is the response so others know the standing for the F650GS single. ---------- It's the issue of some of the top clamps, if you have 7/8" bars some of the clamps are cut with the handlebar groove cut offset from the bolt pattern, so I'd need you to check that for me. I will be making a dedicated top clamp for them 86x35mm with a 2mm offset. Let me know, if your setup is not like this please describe it for me. -----------
05-05-2011, 05:31 AM
#200 |
Oddometer: 80
I'm in......I need to outfit two bikes
05-05-2011, 06:57 AM
#201 |
Oddometer: 18
search for coupon
I've "clicked" on several locations and have not found how to sign up for the coupon. I'd like one as I'm interested in the top clamp and handguards at a minimum. Please advise how I get the coupon. THX!
05-05-2011, 08:07 AM
#202 | |
Oddometer: 2,140
05-05-2011, 08:45 AM
#203 |
R.I.P. Party Boss
Oddometer: 3,587
Chad,
I'm in the second wave and I'll be ordering a setup for an 06 KTM 950 Adv. I have a set of Rox 1 3/4" risers for it. Unfortunately, the bike is in CA and will not be here until 27 May for me to measure. What is the cut off date for ordering? I also have an R1200ST that I am going to put a new top clamp on and regular bars but that will be at least two months a way .
Mike - "For those who fight for it life has a flavor the protected never know." USMC 65-68 RVN 66-67 |
05-05-2011, 08:49 AM
#204 |
Oddometer: 4,942
I'm in, please put me down for a coupon.
Thanks, Lukas
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
05-05-2011, 09:23 AM
#205 | |
Oddometer: 2,140
Hi Mike,
If you haven't already, check out this #26 in this thread regarding Rox Risers: http://www.advrider.com/forums/showp...5&postcount=26 In short, if you are running the Rox Pivot risers, you'll order the same fatbar top clamp that you would if you didn't have the Rox Pivoting Risers, though slightly wider top clamp will work, too. If you have the Rox Anti-vibration risers, then it's best to measure since a wider-than-stock top clamp will be necessary. but check out the above link for a more detailed response. Since we split the group buy into two phases and the second phase group won't receive their coupons until the week of May 23, the coupon will be valid at least a couple weeks into June. Quote:
05-05-2011, 09:30 AM
#206 |
R.I.P. Party Boss
Oddometer: 3,587
Thanks! I've been slowly reading the thread trying catch up.
05-05-2011, 10:05 AM
#207 |
Oddometer: 114
This is the upper I plan to order but the configuration isn't clear to me as I've seen at least four different configurations of the clamp. At the time of order, can I assume there's a "notes" box where I can write in that I'd like holes for switches and LED's?
BTW, thanks to you HDB for putting the deal together and helping out with the info. |
05-05-2011, 11:50 AM
#208 |
Braaaap!
Oddometer: 104
05-05-2011, 01:20 PM
#209 |
SuperSportTourer
Oddometer: 1,005
Chadx...you can move me to the end of the month, and give someone else my May1 coupon. My bike is in pieces at the moment, then the last week of the month I am away on holidays till June2nd. I can order after that with no issues, since I can't use the bike anyways in pieces.
XR200R KTM 950SM CBR Fireblade-GTU Endurance racebike 1996 YZF 600-Lost Era racebike 1999 R6-Rookie Challenge racebike |
05-05-2011, 02:00 PM
#210 | |
Oddometer: 2,140
When you order handguards, the SX is the version included. If you want to upgrade to one of the other versions, you pick that as you order, in the section that looks like this: Upgrade Your Top Clamp SX Top Clamp SXdx Top Clamp - Add $4.95 ADV Top Clamp, Fat Bars Only - Add $14.95 ADVdx Top Clamp, Fat Bars Only - Add $24.95 Check out post #8 of this thread: http://www.advrider.com/forums/showpost.php?p=15700668&postcount=8 which shows the 4 current version of the top clamp. Only the ADVdx version currently has LED holes. Any top clamp images that you've seen that are configured other than in these four ways are older version that are out of production. Hope that helps.
