Old 12-03-2014, 01:37 PM   #1
Proveick OP
Proveick's Avatar
Oddometer: 1,945
Most Perplexed: metalic restriction
Rode it only about 200 miles since September purchase: Then --
Motor will not spin, plugs out, in 6th gear on stand and motor hits metalic obstruction and will not spin either way when rotating wheel.
(Sounds like left side)
Ideas before tear down? Stuck valve, broken valve spring, rod, crank? Thanks, very perplexed
My first car was a motorcycle.
Proveick screwed with this post 12-09-2014 at 03:39 PM
Proveick is offline   Reply With Quote
Old 12-03-2014, 04:11 PM   #2
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,024
Did you or someone else shove a screwdriver or such in the tdc location hole near the starter?
Did it kick back while running out of gas enough to damag.e the cam chain guides?
In any case pull the starter and look into the clutch for loose bolts.
ThIs is the right time of year for it to happen.
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 12-03-2014, 04:32 PM   #3
Proveick OP
Proveick's Avatar
Oddometer: 1,945
Negative on the scewdriver.
Didn't kick, pulled in the clutch and rolled to a stop.
Happened in October, 60 degree day.
I"ve never heard of fuel starvation causing this.
It started for a few seconds after pump, filter and strainer were reinstalled, clanking got progressively louder then shut it off.
Now motor won' turn over. More ideas? Thanks
Old 12-03-2014, 04:36 PM   #4
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 5,016
Pull the valve covers and check for dropped a valve.
bemiiten is offline   Reply With Quote
Old 12-03-2014, 04:46 PM   #5
Proveick OP
Proveick's Avatar
Oddometer: 1,945
Pulled the valves covers and they are intact, just can't see if they fully open/close.
Old 12-03-2014, 07:37 PM   #6
Mr.JAJA
Mr.JAJA's Avatar
Oddometer: 686
Thumbs down Running out off fuel
Running out off fuel means also running lean for a short time. On a 2- stroke that's can burn a hole in the piston very quick.
Mr.JAJA
Mr.JAJA is offline   Reply With Quote
Old 12-03-2014, 07:42 PM   #7
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,676
If the head of a valve broke off, the stem could stay in place but it might close up the clearance which might not be apparent because you couldn't put that cylinder at tdc because the head of a valve is in the way. So, remove the throttle bodies and look in the intake ports. Then do the same with the exhaust.
First, perhaps, remove the alternator belt. Maybe the alternator threw a wobbler? The BMW cars with the water cooled alternator would do it and if you didn't take the belt of, you might think the engine is seized when you couldn't turn it over.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 12-04-2014, 07:15 AM   #8
Proveick OP
Proveick's Avatar
Oddometer: 1,945
Thank you, going to start with alternator, starter and clutch bolts.
Old 12-04-2014, 07:19 AM   #9
rg, sw wa.
Oddometer: 336
Good luck, hope its an easy, inexpensive (as BMW goes) fix.
Ron,
rg, sw wa. is offline   Reply With Quote
Old 12-04-2014, 08:52 AM   #10
Proveick OP
Proveick's Avatar
Oddometer: 1,945
Ron,
Thanks, it's been a less then stellar ownership experience.
Old 12-04-2014, 09:43 AM   #11
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,661
That sucks that you are having that experience, the bike gave over 100k happy miles for the PO, and you got 200 miles into it so far. Hope you get this resolved, it's a beautiful bike and you deserve to enjoy it.
AviatorTroy is offline   Reply With Quote
Old 12-04-2014, 10:55 AM   #12
ragtoplvr
Oddometer: 6,612
If you rotated the engine in reverse you could have broke the old brittle cam chain guides, they can be inspected with the valve covers off.
Rod
ragtoplvr is offline   Reply With Quote
Old 12-04-2014, 11:04 AM   #13
Proveick OP
Proveick's Avatar
Oddometer: 1,945
Rod
Tried to rotate wheel both directions (plugs out, in 6th gear) didn't force it.
Just a metalic stop in both directions.
Hoping it's loose clutch bolts or the above.
I appreciate everyone's contribution.
Old 12-04-2014, 12:41 PM   #14
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,498
Clutch in or out and it wont turn over?
If it was running fine last time you rode it, that is perplexing.
Old 12-04-2014, 02:27 PM   #15
ragtoplvr
Oddometer: 6,612
Do you have curious kids that like to "help"?
strange things end up in strange places some times.
Rod
Times are GMT -7.   It's 05:09 PM.
