Old 02-03-2014, 02:35 PM   #211
Vertical C
Vertical C's Avatar
Oddometer: 2,495
If it were a guard rail protecting a cliff, it would be a valid strategy to slide into it.
Otherwise not so much.
Vertical C is offline   Reply With Quote
Old 02-03-2014, 03:27 PM   #212
DaLunk
Confused and Bemused
DaLunk's Avatar
Oddometer: 729
Originally Posted by gravityisnotmyfriend View Post
What would that do? Even if I were going to hit something, I'd rather stay hard on the brakes and scrub as much speed as possible before I hit.
I agree, and I've been there. I T-boned a station wagon that turned left across my lane. I got 2 or 4 stitches (can't recall...it was 1980). If steel had a better grip on asphalt than rubber they would make hellishly durable tires out of it.
DaLunk is offline   Reply With Quote
Old 02-03-2014, 03:37 PM   #213
gravityisnotmyfriend's Avatar
Oddometer: 1,343
If it were a guard rail protecting a cliff, I would hope I would have seen that coming. I can imagine a situation where a station wagon unexpectedly showed up in front of me. But a guardrail?
gravityisnotmyfriend is online now   Reply With Quote
Old 02-03-2014, 04:07 PM   #214
Vertical C
Vertical C's Avatar
Oddometer: 2,495
swerve to miss an animal, off the road towards a guard rail....
Old 02-03-2014, 06:04 PM   #215
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,412
What size animal? Probably better to t-bone an animal instead of running into a guard rail. Probably softer,just saying!
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Old 02-03-2014, 08:06 PM   #216
Vertical C
Vertical C's Avatar
Oddometer: 2,495
Use your imagination. Just saying that there are situations where it might be valid to lay the bike down.
Old 02-04-2014, 05:44 AM   #217
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,246
This is like the Bear Grylls joke, it goes something as follows: "10 minute wait at Tim Hortons, had to drink my own piss." "Ran out of Coke and only had Pepsi, had to drink my own piss."
"Didn't have the skills needed to properly avoid a crash, had to drink my own piss."
*WTB: '90 DR350S Stock CV carb (bst33) PM if you have one*
'90 DR350S
How to misuse a '90 DR350S
Photos
Anonawesome is offline   Reply With Quote
Old 02-04-2014, 07:40 AM   #218
hippiebrian
Oddometer: 3,326
Maybe on hard old tires and drum brakes.
Not seeing it with modern tires and modern brakes however. It'sway too easy to scrub some speed down these days and reduce the force of the impact than to riska leg "layin' 'er down".
hippiebrian is offline   Reply With Quote
Old 02-04-2014, 08:03 AM   #219
DaLunk
DaLunk's Avatar
Oddometer: 729
For the sake of arguement I would grant this because there is nearly always an exception to a rule, with the assertion that such exceptions are not the case in the vast majority of "I had to lay 'er down" cases.
Old 02-04-2014, 03:56 PM   #220
dwoodward
dwoodward's Avatar
Oddometer: 5,362
2002 or -03, World Superbike, Laguna Seca. Ben Bostrom ran up the hill to the corkscrew, downshifted, and felt something break. This is where we tie in: He didn't waste time trying to lay 'er down- he just let go.
Now, if we can agree that the tires and brakes will slow you down more than steel or leather (or denim, or skin) will- and you're headed for a guardrail or cliff- Do you want to:
a) let go / push off;
b) try to make the bike lay over and hope it slows down enough, or
c) keep using the tires & brakes, and arrive at the spot slower than a) or b)?
dwoodward is offline   Reply With Quote
Old 02-04-2014, 03:59 PM   #221
jnclem
True Airhead
Oddometer: 393
Sounds like those tires would not be properly scuffed in....
jnclem is offline   Reply With Quote
Old 02-04-2014, 05:03 PM   #222
DAKEZ
DAKEZ's Avatar
Oddometer: 19,702
http://youtu.be/NWQHlNaBVRM
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 02-05-2014, 06:37 AM   #223
H e a d N o r t h
(take the high road)
H e a d N o r t h's Avatar
Oddometer: 954
Originally Posted by DAKEZ View Post
DAKEZ nailed it!
If... you are heading for a truckload of pipe
If... you are chasing a really evil villain
If... that truck is not going to move anywhere near fast enough to catch up to said villain
If... their escape will result in the unleashing of nuclear weaponry
Then... by all means, lay 'er down.
Otherwise, not so much.
...when necessary, use words.
First Ride...EVER!
Jan. 1, 2012
H e a d N o r t h is offline   Reply With Quote
Old 02-05-2014, 06:49 AM   #224
Oddometer: 1,343
Originally Posted by H e a d N o r t h View Post
DAKEZ nailed it!
I will concede that if you meet all those criteria, you may in fact "lay her down"
I will also point out that he had enough time to slow down and simply turn left and drive behind that truck. It wouldn't be quite as impressive, but it's save the body work!
And, thanks for posting that link, Dakez. I guess that's a bond movie I missed. What a great chase scene! Wheelying up the stairs on a turbo yammi? Awesome!
Old 02-05-2014, 09:26 AM   #225
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,609
One more IF
If ... the script says you do this and have a stunt man and medical staff on scene, and everyone involved is coordinating and getting paid to accomplish the stunt
then, by all means, lay 'er down.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Times are GMT -7.   It's 12:04 PM.
