Old 04-23-2011, 10:49 AM   #16
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,968
Originally Posted by mousitsas View Post
In case he reads this, I do hope he will provide graphs of the M.H. setup against the prefilter setup
Great to hear. It would be wonderful to get one of his kits before I leave and not wonder.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 04-23-2011, 11:45 AM   #17
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Originally Posted by cjracer View Post
I didn't "Feel" an issue with heat or notice the loss of HP, but Tahoeacr has done more testing than I have and I'm sure he has the numbers to prove it.
W/ the FCRs, you just put Pod filters on, that's a project for later this year. Flanny did a slick setup for the FCRs.
I find it takes a big improvement before I can feel it. Just 100hp and 500lbs throws this old guy off. I tried and tried to get a good dyno test showing the air temp change. I could record 160 degree in the stock airbox but couldn't reproduce this on the dyno. The problem was to get the airbox that hot I had to shut off the dyno fans Then the oil temp would go up. I do all my dyno runs with oil temp at 185 and Engine coolant at 195. I could get repeat proof that in a rise from 100 IAT to 115 IAT there was a drop of 4/10 whp. Not much but what really happens when it gets in the 140 to 160 range? We all know that colder air is more HP I just couldn't prove it.
tahoeacr is offline   Reply With Quote
Old 04-30-2011, 05:25 AM   #18
Rich2wd OP
Oddometer: 115
Job done
G'day all, removed some stuff and fitted the Moto Hooligan Airbox, update here: http://www.advrider.com/forums/showt...68535&page=165
Cheers Rich
Formerly Rich too_wheelz
2007 KTM 990 Adventure
2009 KTM 300 Christini AWD
Rich2wd is offline   Reply With Quote
Old 06-12-2011, 11:49 AM   #19
Kenbike
Oddometer: 692
Rich How has your new air box system worked for your bike?
Is it to loud?
What mods to the bike do you have in place?
Current Bikes: 2014 BMW GSA, 2010 Vespa 300 Super scooter ( hers), 2012 Vespa 300 Super (his)
Kenbike is offline   Reply With Quote
Old 07-01-2012, 11:30 PM   #20
srad600
srad600's Avatar
Oddometer: 656
This looks like a very clean alternative to the OEM airbox. I've been going back and forth between the moto hooligan box and the CPR fab system. Can't really decide if one is better than the other at the moment. I believe you keep the "glove box" with both, and they both come with pre-filters now...
Has anyone tried both? Preferences?
srad600 screwed with this post 07-03-2012 at 05:06 PM
srad600 is offline   Reply With Quote
Old 07-03-2012, 03:09 PM   #21
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,173
Yes I've tried both. I'm still working on refining my fuel maps.
Fun stuff! No preference yet as I'm still putting the CPR through the test
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 07-04-2012, 12:10 AM   #22
srad600
srad600's Avatar
Oddometer: 656
Cool, can you post up the results when you're done? I'm really curious about how they stack up.
Old 09-03-2013, 02:36 AM   #23
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,997
Bump to an old thread. Considering the Motohooligan air box kit (block offs, k/n filter, secondary butterfly's) Any current reviews? And what's the deal with new butterfly valves?
I thought a common mod was deleting the secondaries...
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 09-03-2013, 05:49 AM   #24
bikyto
bikyto's Avatar
Oddometer: 2,173
I've ran both. Installed both on several 950/990 adventure, SD and SM?
Performance wise, they are very similar. Actually, I get the same mileage and hp using the maps I've worked on.
The bike runs better with the secondary butterflies on. From my experience. I had them off before.
The oval butterflies were developed before tuneecu became mainstream. You can achieve the same results in your mapping.
Do you have any particular questions? I'll try to answer the best I can.
Old 09-03-2013, 02:14 PM   #25
goodcat8
goodcat8's Avatar
Oddometer: 2,997
Good info. I've got a serious bog at 5200 rpm. Looking for any type of remedy before I dive into the whole power commander custom tune route.
Old 09-09-2013, 02:57 AM   #26
Top Bloke
Porky Rider
Top Bloke's Avatar
Oddometer: 111
I have Rich's bike now, loving it. Does surprisingly well in very dusty conditions too when using the Outerwears prefilter.
My new prefilter arrived today with a complimentary Motohooligan T-shirt. Good Guy Motohooligan!!
Top Bloke is offline   Reply With Quote
Times are GMT -7.   It's 11:06 AM.
