04-22-2011, 10:16 AM
#1 |
Givi LED brake/tail/signal light mod
After several complaints from the wife about how uncomfortable she was riding with a backback when going to work, the gym, etc... we decided to pick up a Givi topcase for the rear of her DRZ400SM. I don't mind wearing a pack for short runs, but she has a couple vertebrae fused after a spinal fracture she suffered in a car accident a few years back.
Post-op shot: ![]() So yeah... easy to see how a backpack might bother her. We wound up with one of these - a Givi E370: ![]() Amongst other modifications to her DRZ, I've also added a fender eliminator and an Edge LED taillight, as well as some aftermarket LED turn signals. They do the job for daily commuter duty, but when we're on the highway, I'd like for her to be a little more visible to following traffic. Here's the current lighting configuration: ![]() I started shopping around for light kits for the topcase. Givi makes a brakelight kit for the E370, but its JUST a brakelight that fills that small rectangular lens above the handle. I wanted something that utilized those huge lenses as turn indicators, as well. Then I stumbled across AdMore Lighting, who happen to make light kits for damn near every Givi case you can think of. Once again, what they had for the E370 wasn't really as complete a package as I'd hoped. It only had turn signal functions, no brake lights. Time to get creative... so I began searching around for basic LED accessory light strips and diode-equipped wiring adapters so that I could combine brake/tail and tail/signal light functions into single units. I had picked up some LED replacement bulbs for the turn signals on my DR650 from a local vendor, so I started checking out his site to see what they offered. I wound up picking up 4 of these LED strips: ![]() And in addition to those, several of these small 2-wire to 3-wire converters: So, with the basic necessities now in hand, time to tear apart the Givi and start laying stuff out! The nice thing about these strips is that they're wired for power supply from both ends. This allows you to cut them into two parts at 3" intervals. I trimmed one in half for two 6" pieces and two more got cut into 9" and 3" sections. On the the fourth strip, I just cut a 3" section of that off for the small brake light lens. Took some rubbing alcohol to the case where the LED strips would go and started laying out the strips. Once I was happy with the spacing, I used the heat gun to heat them up and really squish 'em into place to make sure the self-adhesive backing would stick. ![]() ![]() Next I pulled out the drill and punched a few 1/8" holes in the case to route the wires inside the case. ![]() These holes have since been plugged with some silicon sealant: ![]() I tested each strip after pulling all the wires into the case to ensure they all worked. So far so good! The only strip that didn't look very prominent was the one under the small rectangular lens above the handle of the case. ![]() I pulled the plastic lens out of the case and found a roll of nice shiny aluminum tape and lined the inside of the lens surfaces with it - except the part the light shines through, of course. Getting that sticky stuff crammed in there while trying to not wrinkle the crap out of it wasn't pretty, but it certainly helped brighten up the view from the rear. ![]() ![]() I wired everything up to my spare DRZ battery to see just how bright it would be with all the LEDs powered up. Off: ![]() And on.... "Can you see me now?" : ![]() Still sorting out the wiring and what combination I'll be running each strip as... tail/brake, tail/signal, or some other combo of dedicated functions split between the various strips. Once I get it figured out and get the bike-side connector wire up, I'll post a video. Thoughts and suggestions are certainly appreciated in the meantime.
2002 DR650 (mine)2008 DR-Z400SM (hers) 11 days, 3 provinces, 3800km, 1 great time!(Aug 2010) Our search for summer - (July 2011) Moto-fishing in Central BC GISdood screwed with this post 04-23-2011 at 11:11 PM |
04-22-2011, 11:30 AM
#2 |
Truffle Rustler
Oddometer: 1,947
Nice, looks like a spaceship and may keep the idiots from rear ending!
Normal is just a setting on the dryer. Armageddon was yesterday - Today we have a serious problem. 2009 R1200GS Adventure 2008 K1200GT |
04-23-2011, 12:26 AM
#3 |
Oddometer: 260
Good work!
Stay tuned for ride reports ... Idaho to Arizona in May and Idaho to The East Coast in September. ![]() -09' Triumph Street Triple R I am The Stig...
04-23-2011, 05:15 AM
#4 |
Oddometer: 614
Nice work...now if you can get the brake light to flicker the 1st few seconds when engaged you will Really be noticed.
04-23-2011, 07:57 AM
#5 |
I thought about adding a brake light modulator to the install as well, but I figure I'll wait til the Givi lights are all hooked up first. If I think it needs a little more 'in yer face' visibility, I'll add the modulator a little later down the road.
04-23-2011, 06:59 PM
#6 |
Unreasonable
Oddometer: 2,239
Wow. That is frickin' amazing...
I'm going to look at my Givi V46 very closely tomorrow and see if I can do the same thing...
TransLab a Go Go 2011 Nova Scotia Fresh Air Inspectors Investigate the Cabot Trail "Second star to the left and straight on till morning” ― James T. Kirk |
04-23-2011, 07:19 PM
#7 | |
NAVVET
Oddometer: 227
YOU MEAN BY USING A BRAKE LIGHTS STROBE MODULE LIKE THE ONE ON THIS THREAD ? |
04-23-2011, 07:24 PM
#8 |
Flabby Adventurer
Oddometer: 143
Cool, so how do I get my Givi's to you to get this done... bwahahah.
2012 BMW K1600 GTL |
04-23-2011, 08:05 PM
#9 | |||
![]() Quote:
2002 DR650 (mine)2008 DR-Z400SM (hers) 11 days, 3 provinces, 3800km, 1 great time!(Aug 2010) Our search for summer - (July 2011) Moto-fishing in Central BC GISdood screwed with this post 04-23-2011 at 10:54 PM |
04-23-2011, 09:46 PM
#10 |
Leg Humper
Oddometer: 8,025
You have done a very nice job
L 51.01.900 / L W 114.05.900 "That road less traveled is a toll road, and sometimes the charge is more expensive than we ever expected. Most of the time, it's a one way road. Make the decision, hope for the best, and start traveling. Carry lots of coins." PecosBill Pick good friends and you'll never be lacking Family Me |
04-23-2011, 10:09 PM
#11 |
Oddometer: 62
How many of the 2-3 wire connectors did you end up using for that set up? Do you need one for each strip?
Thanks, Dan |
04-23-2011, 10:53 PM
#12 | |
Not quite done yet, but thanks!
But... that's just "right now". I'll be playing around with it once the connector is wired to the bike (hopefully tomorrow), so that may change a bit. In any event, I don't foresee needing more than three connectors. |
04-23-2011, 10:57 PM
#13 |
Out of the office.
Oddometer: 4,949
You might want to blur out your SO's name, age and birthday on her films
especially if your worried about the bike's license plate that you blur it...
On vacation for a spell |
04-23-2011, 11:11 PM
#14 | |
![]() >cropped original< Thanks! |
04-24-2011, 06:57 AM
#15 | |
Nobody Home
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
