Old 06-17-2011, 08:40 AM   #31
yellowbirdrs
yellowbirdrs's Avatar
Oddometer: 966
probably not a good place for the box. After 300mls full loaded my box broke the bolt on the top of the caliper hit it :o
yellowbirdrs is offline   Reply With Quote
Old 06-17-2011, 09:31 AM   #32
2712
Oddometer: 374
It should be less wide, or it sould be placed inside the pannier bracket, maby without a lock but with the door on the pannier side so you have to deattach your panier to access it...
mmm if only i had a welding device...
2712 is offline   Reply With Quote
Old 06-18-2011, 05:46 PM   #33
lightfighter
where does this go?
Oddometer: 2,289
so noone has ever actually seen the Italian jobs? im not gonna build anything like this. It just isnt realistic for me. But im torn between ABS(of unkown thickness) and Aluminum. I sent an email inquiry to the GSemotion guy on shipping, hs website is a little 'informal' in the ordering department.
lightfighter is offline   Reply With Quote
Old 06-18-2011, 05:57 PM   #34
turnerm
Oddometer: 210
The tool case in the first picture looks pretty nice.
Its a shame that you need the Adv pannier brackets to install it.
Would be interested if there was a way to mount on a GS without those monstrosities, uh, I mean cases.
Am I the only one that doesnt like side cases?
Bike-less for the first time since 1998
turnerm is offline   Reply With Quote
Old 06-18-2011, 06:10 PM   #35
lightfighter
where does this go?
Oddometer: 2,289
if you didnt have side cases, this would be, well.... a small side case. wouldnt it?
Old 06-18-2011, 11:21 PM   #36
Longer
Longer's Avatar
Oddometer: 168
Loving this idea!
Anything out there that would fit with Jesse Odyssey boxes on an '04 - '07 R1200GS?
Slick!!!
Longer
Clap your hands whilst in the shower, this will spray water in all directions.
Longer is offline   Reply With Quote
Old 06-22-2011, 12:56 PM   #37
Mika S
JC & MC: Double Freedom
Oddometer: 169
Brilliant!!
Mika S is offline   Reply With Quote
Old 06-22-2011, 04:24 PM   #38
r2adv
r2adv's Avatar
Oddometer: 526
Another version
I did the same thing using a Pelican case. Here's my version:
Horizontally opposed to a vertical twin world
R12GSA, R100 GSPD, R80G/S, R75/5, R90S
r2adv is offline   Reply With Quote
Old 06-22-2011, 09:05 PM   #39
Snowbound
Oddometer: 877
I like the idea . But for now I ordered two of the small tool tubes from Agri-supply. (I tried the larger ones and they were too big ).
BMWMOA
ABC
Pikes Peak BMW Riders
2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72
1955 CJ-5 1975 F-250 Highboy
Snowbound is offline   Reply With Quote
Old 06-22-2011, 09:56 PM   #40
island808
We are 100% SNAFU
island808's Avatar
Oddometer: 423
'n' how's that open?
island808 is offline   Reply With Quote
Old 06-23-2011, 02:51 AM   #41
r2adv
r2adv's Avatar
Oddometer: 526
Pelican toolcase
The hinge is on the bottom of the case. You pop the two latches. The case cover pivots down onto the top of the tire like a shelf. I reach in behind the license plate from the left side. The tools are in a Kathy's roll up pouch. I also have the registration and a few emergency shekels tapped to the inside back of the case.
What I like: You still have tools if you run with out bags. Completely watertight. Even if you have her loaded down with camping shit you don't need to unpack anything to get to the tools.
Caution: I had to shave the cover of the case cause I had some interference with the rear mud guard. It doesn't lock but it is so hidden I don't worry about it.
Old 06-23-2011, 06:15 AM   #42
lightfighter
where does this go?
Oddometer: 2,289
pelican
have you pulled the shock and checked it for 'worst case bottoming out' tire clearance?
Old 06-23-2011, 09:10 AM   #43
island808
We are 100% SNAFU
island808's Avatar
Oddometer: 423
I just go like I always have... about 16 inches of 4 inch black pipe with a screw on lid clamped to the frame.
Works like a charm.
Probably about as much storage as the pelican, arguably harder to pack.
Old 06-23-2011, 01:14 PM   #44
hasenwerk
hasenwerk's Avatar
Oddometer: 1,324
As I use ammo boxes on my 1100 GS for panniers - I continued the theme for my tire repair / first aid box. Most of my tools are under my seat. Undo the latch at the front and it hinges off. Cost was under $20 - water proof and has functioned quite well for the last 25.000 km
David Marshall - Quesnel, BC, Canada - fastforward.ca
2006 BMW F650 "YZ" Dakar | 2013 BMW G650 "YZ" Sertao
hasenwerk is offline   Reply With Quote
Old 06-23-2011, 07:09 PM   #45
r2adv
r2adv's Avatar
Oddometer: 526
Pelican version
No but...40,000 miles later.....over many a Mexican topes.....
Times are GMT -7.   It's 03:30 PM.
