Old 04-25-2011, 08:42 PM   #1
g r a n t OP
g r a n t's Avatar
Oddometer: 642
R1150GS Is this a main seal leak?
Hi.
I have a 2000 R1150GS with 38,000 miles. Since about 25,000 I have been noticing a very sllight amount of graphite colour residue seeping from between the engine case and the clutch/transmission case. This black coloured leak is very dry - almost creeping out between the cases.
I have seen a few other posts with this very similar condition. One post indicated it was a main seal leak.
Tonight, when I got under the bike with a flashlight I also noticed a dark brown oily residue up and under the clutch area. The oxygen sensor sticks into this area from the catalytic converter. This leads me to think this is a different leak all together. The leaking if very slight, but I ultimately want to nip it in the bud before it gets worse.
I am not noticing oil loss more than you might expect; maybe a quarter pint over about 2500 miles of hard, highway riding.
I am not noticing clutch slippage.
In the first pic you can see the oily residue in past the starter.
In pic two Arrow 1 points to the brown oily residue and Arrow 2 points to the black, graphite coloured leak on the case.
Thoughts? Should I be ordering a main seal etc? What about the brownish leak at the bottom?
Thanks in advance!
g r a n t
g r a n t screwed with this post 04-25-2011 at 08:55 PM
g r a n t is offline   Reply With Quote
Old 04-26-2011, 01:37 AM   #2
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
The rear main seals rarely leak on Oilheads. You more likely have a clutch slave failure or transmission input shaft seal failure. If you have enough fresh oil to get a drop on your finger smell it. If it is gear oil you will know, that stuff stinks. If there is almost no smell then it is the clutch slave leaking.
The dry residue is usually dust from the clutch.
Beemers Uber Alles
9248 Mike Garcia Drive
Manassas Va 20109
(571) 318 2472
Indie BMW Maintenance
www.beemersuberalles.com
GeorgeinVA is offline   Reply With Quote
Old 04-26-2011, 07:55 AM   #3
g r a n t OP
g r a n t's Avatar
Oddometer: 642
Hi GeorgeinVA,
Thanks for taking the time to offer your thoughts.
I will take a look at it tonight.
Cheers,
g r a n t
g r a n t
Old 04-26-2011, 08:34 AM   #4
Kawidad
Kawidad's Avatar
Oddometer: 4,987
You can pull the starter motor very easily (2 bolts) and take a look inside. The view is very limited, but might give you a better idea of what you've got.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 04-26-2011, 08:45 AM   #5
g r a n t OP
g r a n t's Avatar
Oddometer: 642
thanks too! that is also on the list tonight!
g r a n t
Old 04-26-2011, 08:52 AM   #6
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,772
Transmission input seal leak.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 04-26-2011, 08:52 AM   #7
Dark Helmet
Dark Helmet's Avatar
Oddometer: 709
On my 1200 it was the input shaft seal on the tranny. Your description was identical. In reality though it doesn't matter which it is, you still have to do about the same amount of labor to fix either.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD -40. If it shouldn't move and does, use the duct tape
BMW 1200 GS Adventure
BMW 1970 R75/5
Suzuki DRZ 400S
Dark Helmet is offline   Reply With Quote
Old 04-26-2011, 09:11 AM   #8
drcool
R.I.P. Dave
drcool's Avatar
Oddometer: 3,072
You might bleed the clutch with some fresh fluid and check the colour of the old. From what I've read Black fluid will indicate a slave on it's way out.
Good luck
drcool
Originally Posted by Isplat2 "When ALL the movies, video's and home theater is in 3D ....porn will become a whole lot different...."
Trailering your bike is a sickness, for help.....Call 1-800-scaredtoride
drcool is offline   Reply With Quote
Old 04-26-2011, 06:42 PM   #9
g r a n t OP
g r a n t's Avatar
Oddometer: 642
So let's see - tonight I could have done my almost overdue taxes or go play with the GS. So, let me tell you about the oil.
I crouched down and stuck my finger as far into the underside of the transmission area as I could [At this point I remembered I was long overdue for my annual physical].
The oily residue appeared mostly black but this was due to all the dirt and particulate in the oily film. When I brushed away the particulate I would say the oily film had a slight brownish/gold colour.
Despite remembering my overdue Doctor appointment I sniffed the oil. Certainly did not smell like tranny fluid. To be sure I opened a fresh bottle of BelRay 80W90 hypoidal gear oil. The vintage was uncertain but it was no beaujolais. Anyhow, my finger smelled nothing like the bottle. I am wondering how much the oil will still smell like transmission after sitting on the case exposed to the air for a few weeks. Nevertheless, it did not smell like transmission fluid.
I going to do my taxes and then go back down and inspect the clutch fluid reservoir.
Cheers,
G
g r a n t
Old 04-26-2011, 06:54 PM   #10
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,859
clutch fluid will darken over time, as it becomes contaminated, this occurs naturally. See if the fluid is low, but you need to know it was full recently. I had a slave leak on me, and bled it out once, not knowing that the slave was failing. The a few months latter the pressure was low once again, well then I knew it was the slave. Had it replaced quickly before the clutch disc was contaminated, trust me you don't want to replace the clutch due to a leaky slave. the labor for the slave isn't too bad, but replacing the clutch.....you'll be hoping BMW dealer had very small fingers, he won't for that!!!
Hope it's not the rear seal or tranny seal.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 04-26-2011, 06:57 PM   #11
mkino
diGS
Oddometer: 60
Listen to GeorgeinVa.
He knows whereof he speaks!
mkino is offline   Reply With Quote
Old 04-26-2011, 07:05 PM   #12
rebake
rebake's Avatar
Oddometer: 1,062
When my 1200 gs started doing this,i called the tech at Gateway.He told me to pull the starter and shine a light and look for anything that looks wet.Said it would be easy to see if there was a lot of oil or just a dusty powdering inside.Mine was the latter.I don't like that it does it,but i don't worry about it anymore.Ed
amish people think i dress funny
rebake is offline   Reply With Quote
Old 04-27-2011, 08:42 AM   #13
g r a n t OP
g r a n t's Avatar
Oddometer: 642
Clutch Master Cylinder
The Dot 4 fluid in the master cylinder is super clean and clear.
G
g r a n t
Old 04-30-2011, 06:16 PM   #14
g r a n t OP
g r a n t's Avatar
Oddometer: 642
Pulled as much apart today as I could. Will upload some pics and details soon.
g r a n t
Times are GMT -7.   It's 02:57 PM.
