Old 04-27-2011, 01:56 PM   #1
chacha OP
CAT Herder
chacha's Avatar
Oddometer: 2,387
Send a message via Yahoo to chacha
Aprilia SR50 Basket Case Rebuild
Just picked up a basket case SR50.
This scoot has been floating around between friends for a little while. The one that owned it first is mechanically inclined but financially challenged. He is the one that tore her down and then didn't have the cash to buy the parts to fix it.
He then sold it to friend "2", who says he is mechanically inclined. Friend "2" has had the scooter for about 2 years. In the same condition as when he bought it from friend "1". For some one that use to work at a motorcycle shop as he says I figured he would have worked on it a little more in the past 2 years. Either way, he did buy the new top end assembly and put the gaskets in the head, but that is as far as he went with it from what I have seen.
Now, I own it. I think I'm looking at a total tear down since the engine has been open for over 2 yrs so who knows what has collected inside it.
Here it sits after I got it home.
The old piston.
"Your gonna cut my hours bitch I'm gonna milk you like a cow." My wife, about her boss.
Ducati Hyper 796
chacha is offline   Reply With Quote
Old 04-27-2011, 02:29 PM   #2
biketherapy
si se puede
biketherapy's Avatar
Oddometer: 495
looks like a big project. Is this the fuel injected one?
biketherapy is offline   Reply With Quote
Old 04-27-2011, 03:09 PM   #3
chacha OP
CAT Herder
chacha's Avatar
Oddometer: 2,387
It's the carb model. I've been researching on it today and it has the Minarelli 50CC liquid cooled engine.
My wife wants to help with the rebuild so it should be a good little project for us or be the cause of a divorce
Ducati Hyper 796
Old 04-27-2011, 07:47 PM   #4
B02S4
Aye
B02S4's Avatar
Oddometer: 490
PM inbound.
B02S4 is offline   Reply With Quote
Old 04-30-2011, 09:09 PM   #5
btcn
btcn's Avatar
Oddometer: 2,835
Yep, a BIG project! But as long as you enjoy it it'll be fun! Good luck and look forward to seeing it come together.
btcn is offline   Reply With Quote
Old 04-30-2011, 09:12 PM   #6
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 4,456
Send a message via AIM to skibum69 Send a message via Skype™ to skibum69
I'm waiting for the extra cash to order a 70cc big bore kit for mine
Riff Raff 2012, 2011, 2010, 2009
Skibum Soiree 2012
Skibum Soiree 2011skibum soiree '10
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 05-01-2011, 09:41 AM   #7
chacha OP
CAT Herder
chacha's Avatar
Oddometer: 2,387
I just ordered a gasket kit, oil seals, as well as a new plastic cover that goes over the supply oil pump/ magneto area.
The parts won't be here for a week or so. I have to leave for work this Weds for 3 weeks. When I get back I hope to have the motor apart and cleaned before having to leave again a few days later so this thread might be a slow mover for a bit.
Ducati Hyper 796
Old 05-03-2011, 06:33 AM   #8
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 3,896
Cool, good luck with it.
It's one of the best and fastest 50cc scoots on the market for years now, will
do over 50mph stock, should be good for about 6hp with stock exhaust and
reacts well to leovince zx or rr pipe (15-20% more power).
'12 Kymco Downtown 300i ABS, '08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125
My Flickr gallery
Cortez is offline   Reply With Quote
Old 02-13-2012, 08:08 AM   #9
chacha OP
CAT Herder
chacha's Avatar
Oddometer: 2,387
Well it's been a long time since an update but here it goes. It's winter here and been cold and snowy so I finally got around to putting the top end back together this week. I was originally going to split the case and do a full rebuild but the main bearings still rotate very freely with little play so I decided to skip that.
I did pull the flywheel and magneto to replace the oil seal on the crank and also to inspect the oil pump plastic drive gear. All that looked fine. I did find a small metal pin stuck inside the flywheel and magneto. It is over an inch long and I have no idea what it goes to. It seems to have been there for a while as the inside of the flywheel shows wear from this pin rolling around. I didn't have the flywheel holder tool so I improvised.
Photobucket
I got the new piston and cylinder on and the engine bolted back into the frame. I don't have pictures of that since my camera battery was dead and I just wanted to get it done that day. But here she is before I loosely bolted the seat, fuel and oil tanks back on.
Photobucket
I spent pretty much all day yesterday findling with the carb and wiring to make sure I had spark and fuel. Most of the hoses where brittle or the wrong length. The oil pump hose was cut so I had to redo that. I didn't have a key for the scoot so I removed the key lock then turn the switch with a screw driver.
Photobucket
Photobucket
But she does start and Idle now. I'm missing a lot of body hardware but that is easy to replace. I will need to make some brackets and I am missing the airbox so I will have to find on of those. I've been looking into it and I also think that somewhere along the line some one replaced the carb with a different one. The model number is not the same as the info I can find about a stock motor.
Ducati Hyper 796
Old 02-19-2012, 01:21 PM   #10
btcn
btcn's Avatar
Oddometer: 2,835
Wow, looking good! A LOT better than it started out!
85 Honda Shadow 700, 86 Honda Elite 150 deluxe, 2001 Honda Elite 80, 07 CRF 100, 07 CRF 50, 07 DRZ 250, 78 CB 400 Automatic [Project Bike]
Old 03-02-2012, 08:02 AM   #11
mamba24
ScRaM pUpPeT
mamba24's Avatar
Oddometer: 140
any update on the build?, planning to buy one on cl and pretty excited on riding it this spring.
mamba24 is offline   Reply With Quote
Old 03-03-2012, 01:28 PM   #12
chacha OP
CAT Herder
chacha's Avatar
Oddometer: 2,387
It's on pause at the moment since I am out of town for work until mid March and then I have to refinish some furniture when I get home first.
I will be ordering some different size jets to play with the carb settings. It starts first kick and idles fine. I just can't get over 1/4 throttle or it dies.
Ducati Hyper 796
Old 06-01-2012, 05:39 PM   #13
chacha OP
CAT Herder
chacha's Avatar
Oddometer: 2,387
Okay so this has been on pause still but I ordered a few items today. I toyed with the idea of trying to dial in the aftermarket 19mm carb that is on there. I think a 19mm is too big for a 50cc scoot. So I found a new 12mm carb which is listed as the stock size in the manual and I also found the stock airbox online so I figured that would be a good baseline.
Now it's just waiting for the parts to arrive.
Ducati Hyper 796
Old 06-01-2012, 10:11 PM   #14
brianwheelies
Iron toocus
brianwheelies's Avatar
Oddometer: 935
12mm is stock? That seems awfully small. I think the aircooled minarelli's run 14 to 16.5mm stock.
2009 Aprilia SR50 R Factory
2012 Bont Vaypor Custom 2pt
My drivel
http://chillislives.blogspot.com/
brianwheelies is offline   Reply With Quote
Old 06-02-2012, 12:12 AM   #15
chacha OP
CAT Herder
chacha's Avatar
Oddometer: 2,387
This one is a liquid cooled minarelli. I thought it would have a 17.5 mm but after finding a parts fiche for the 97-2000 model years it is listed as a 12mm. Even when I e-mail AF1racing asking about a stock carb he sent back a link for a 12mm.
I'll have to see how it goes then.
Ducati Hyper 796
Times are GMT -7.   It's 01:40 PM.
