06-16-2012, 09:17 PM
#1501 | |
Oddometer: 1,157
Want Creative Adventure Products? - See Globetrottin.com Current rides - 03 ST1300 72k, 07 990Adv 33k, 12 500EXC 5k |
06-17-2012, 03:52 AM
#1502 |
Oddometer: 4,923
Yup, HDB. Fantastic design and production as usual from Paul. There is a thread on "rally navigation brackets" in the Racing subforum, he developed the design based on feedback from the experienced racers on there.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
06-17-2012, 04:42 AM
#1503 |
Oddometer: 451
Looks like the fairing/roadbook/light support brackets would sandwich right in for those of us who already have the standard HDB installation. Is that right?
2013 Ducati 1199 R 2012 KTM 500 EXC 2005 KTM 640 Adventure Φίλα μου τον κώλο. |
06-17-2012, 06:49 AM
#1504 | |||
Reforming Neandertal
Oddometer: 867
When all that's done I'll post up in Vendors for anyone interested. |
06-17-2012, 01:42 PM
#1505 |
Unpronouncible
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,402
Acerbis 5.3g tank install on XC-W
The tank is a bit skinnier than the stock tank with shrouds.
![]() First thing I noticed was a clearance problem with the Enduro Engineering radiator guards. ![]() A simple bend of the radiator mount relieved that issue. You may not want to do this. I'm okay with it. ![]() The second issue was up near the top of the radiator guard. It was rubbing against the tank. So I filed down the radiator guard so the surface was smooth and not a sharp edge. ![]() The pump dropped in very nicely and the two new mount bolts below aligned well(you reuse your old o-rings) and everything snugged up very well. The screws for mounting the electronic portion should NOT be tightened very tight. Be careful here. They say 2ft/lbs of torque. It is wider across the thigh for sure. ![]() The tank to plastic area has a gap. ![]() But overall I'm going to enjoy the range. ![]() ![]() Acerbis did a very nice job on this tank. Now I need to go for a ride! |
06-17-2012, 02:29 PM
#1506 |
oot & aboot
Oddometer: 25,819
So I got up early to get some wrenching in before we head up hiking in the mountains for the day... I wanted to get a mental grasp on what types of things I am still going to have to work out.. like wiring (yay! I have room to mount my horn
Here's a bunch more pics... ![]() ![]() Here's what makes this design so stout... notice our triple clamps have two holes on each side (I took this photo last night when doing a spring swap) ![]() Paul has designed his system so that the center bolts go through the risers like normal... ![]() ..but instead of the rear top clamp just bolting the clamp down, it goes all the way through and into that second triple clamp bolt meaning the entire system is bolted to the top triple with four 12mm bolts instead of two! ![]() ![]() Since I already have the HDB system for crash guards and top clamp installed on my bike; everything bolted straight up quickly
www.motogeek.com |
06-17-2012, 02:30 PM
#1507 |
oot & aboot
Oddometer: 25,819
Looking at the tree...
Looking down from the top - you can see how the tree mount extends in front of the HDB instrument guard ![]() The bottom of the tree goes in with two bolts to the existing holes in the lower triple ![]() The top of the tree mounts up with four bolts ![]() test fitting - everything aligns perfectly.
www.motogeek.com |
#1508 |
oot & aboot
Oddometer: 25,819
Roadbook system.
A big reason for me installing this is for Roadbook usage. The thing is, sadly that is only a small percentage of seat time. ...so for me the system has to 1) work and 2) be easy to remove! The roadbook installs on the machined tower sticking up from the top ![]() Here you can see how the mounting bracket on the f2r wraps around the pivot ![]() Then another machined clamp and 4 nuts and its mounted - obviously easy to adjust the viewing angle. ![]() ![]() With stock headlight mask ![]() ![]() ...then here is the cool part... 4 bolts (the tower bolts - not the roadbook's rotation bolts)... and in under a minute: ![]() the entire thing comes off. I'm going to come up with some sort of a bracket that goes across with a RAM ball so I can mount my GPS in the space. ![]() Now I'm back to regular "dirtbike" mode. ![]() btw.. the mount for the roadbook has multiple mounting holes so you can fine tune how high or low you want your road book to be. ![]() Combine that with all of the holes in the frame (the 6 holes by my thumb).. and you can fine tune the roadbook to exactly where you want it. ![]() If you want the roadbook further forward, just move the re-enforcement brace to the rear. ![]() Overall I'm impressed with how well thought out this solution is. Now I just gotta figure out my part of the equation.. how I want my brake line routed, my wiring loom positioned, etc.
www.motogeek.com |
06-17-2012, 02:31 PM
#1509 |
oot & aboot
Oddometer: 25,819
![]() That looks awesome! Have a pic of the left side? How big is the bulge where there's no exhaust pipe?
www.motogeek.com |
06-17-2012, 03:21 PM
#1510 |
Oddometer: 451
Hey Geek, thanks for the detailed write-up and photos of the HDB rallybook mount. I'm about halfway through the thread over here (http://www.advrider.com/forums/showthread.php?t=684282) where Paul's ideas took shape. That's also a fascinating read and I can't wait to get to the part where he reconsiders whether to mount to the frame or to use his existing topclamp. My interest will be mainly for the robust lighting and fairing mounting poins - so the fact that I don't need a rallybook also makes being able to remove it an advantage.
Looks like I'm just a couple of days behind you in mounting the 5.3g tank. So thanks also for sharing those pictures. -Stuart
06-17-2012, 06:52 PM
#1511 |
Unpronouncible
Oddometer: 2,402
Mock up shot in the garage will give you an idea of the left side.
06-18-2012, 06:35 AM
#1512 | |
Huh???
Oddometer: 980
So have you had a chance to ride any trails with this super-tanker mounted up? I'm curious about the handling....
.................................................. .................................... NMOHVA.ORG - Help to keep your trails open! Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
06-18-2012, 06:59 AM
#1513 | |
Cholla Magnet
Oddometer: 1,116
Sorry to hear about the fuel pump. EFI is the debils work! What did your 10 micron filter look like when you pulled it? What about the internal filter? I assume the internal filter is before the pump? Did you buy one of these? http://www.ca-cycleworks.com/fp-hus (edit:this may not be a replacement) You're bike problems are affecting my riding plans now, so let's get it fixed quick, m'Kay? chop. chop.
cross-country screwed with this post 06-18-2012 at 07:12 AM |
06-18-2012, 07:14 AM
#1514 | |
Unpronouncible
Oddometer: 2,402
![]() Here is a pic for you of the filter closest to the injector. I blew through it and it had significant resistance compared to the new 20 filter. I'm not sur the picture shows much. ![]() I did not look at the tank filter. I think I will need too. I'm having a bad month for stuff breaking. Hard drives, laptops, clutch hubs, subframes, fi pumps, cameras, and I don't even want to think about work
06-18-2012, 07:18 AM
#1515 |
Unpronouncible
Oddometer: 2,402
