Old 06-18-2012, 07:39 AM   #1516
cross-country
cross-country's Avatar
Oddometer: 1,677
Originally Posted by toddler View Post
I'm having a bad month for stuff breaking. Hard drives, laptops, clutch hubs, subframes, fi pumps, cameras, and I don't even want to think about work. All little stuff in the grand scheme of things, but they take time. I'll be back to full scale riding before the end of this month.
http://answers.yahoo.com/question/in...2222217AA7vQuU
cross-country is offline   Reply With Quote
Old 06-18-2012, 07:45 AM   #1517
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,752
Todd: looking at it... Two connectors inside the tank are spades... Maybe one came off?
Sent from iPhone using Tapatalk
Old 06-18-2012, 07:47 AM   #1518
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,752
Difference in thickness stock vs 13L where petcock mounts
Old 06-18-2012, 08:18 AM   #1519
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,213
Which one is the stock one? Top or Bottom
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 06-18-2012, 09:08 AM   #1520
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,745
Originally Posted by cross-country View Post
I guess that is better than swapping the FI and low fuel lights.
Please remove the curse and I'll change your next flat.
toddler is offline   Reply With Quote
Old 06-18-2012, 10:47 AM   #1521
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
Nice work on those rally brackets Paul! Very slick. Are you really using 12mm bolts though? Are you drilling out and re-tapping the upper trippleclamps?
jesusgatos screwed with this post 06-18-2012 at 11:27 AM
jesusgatos is offline   Reply With Quote
Old 06-18-2012, 11:43 AM   #1522
Mifune
Mifune's Avatar
Oddometer: 493
The topclamps Paul delivers with the risers that accommodate the Scotts steering damp have always used 12mm bolts through the pair of holes closest to the rider, so I expect the same topclamps are used here.
I don't need a rally roadbook mount, but the cleanness of this setp up to mount a fairing, lights, horn, and generally clean up the wiring rat's nest makes it look like a winner to me.
-Stuart
Misead your question I think. The bolts that pass through to the triple clamp are the stock size (10mm?), only unique point is that all four holes are used, instead of just two, which means that the bolts closer to the rider are too big to pass through the standard (8mm?) holes in the topclamp. The 12mm reference looks like a typo.
2013 Ducati 1199 R
2012 KTM 500 EXC
2005 KTM 640 Adventure
Φίλα μου τον κώλο.
Mifune screwed with this post 06-18-2012 at 11:50 AM
Mifune is offline   Reply With Quote
Old 06-18-2012, 12:40 PM   #1523
LukasM
Oddometer: 5,426
What Mifune said, they are the stock M10 size bolts, more than strong enough already.
Old 06-18-2012, 12:53 PM   #1524
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,752
Yes sorry.. 10mm typo on my part.
Steveo: the thicker one is stock.. it has much more substantial plastic in that location.
Old 06-18-2012, 12:59 PM   #1525
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,752
Got the bike back together and went for a ride
Here's what the rally frame looks like with two squadrons in it (and my horn mounted up nicely to the existing hole ) :
Old 06-18-2012, 02:02 PM   #1526
jtmajors
OCD with motorcycles
jtmajors's Avatar
Oddometer: 314
I have the xcw so have 13/50 gearing. I want to get a set of 17"s. What size rear sprocket do I need to be able to keep the stock chain. I want to get the tallest gearing I can out of it without changing chain.
jtmajors is offline   Reply With Quote
Old 06-18-2012, 02:39 PM   #1527
ABYSS
KTM
Oddometer: 1,198
14/48 can still use the original chain.
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 06-18-2012, 02:53 PM   #1528
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,387
The exc comes with 15/45 which is way tall... and everbody immediatley swaps them to 14 x 48 so you should be able to make a good deal... want mine?
KTM 500 EXC Yellow Vee Black DR650
A few others in the past
You dont quit riding when you get old, you get old when you quit riding.
I don't always ride street bikes, but when I do I prefer VStroms
Vico1 is offline   Reply With Quote
Old 06-18-2012, 04:00 PM   #1529
jtmajors
jtmajors's Avatar
Oddometer: 314
How much? Does the exc have a 118 chain stock? Also, is the cover on the coutershaft same on both bikes. I don't need a different one to put a 15 on do I? Do you think 15/45 won't be as tall with 17s?
Old 06-18-2012, 04:10 PM   #1530
Hukamosh
Oddometer: 105
15/45 is fine on the street w/ 17's
Hukamosh is offline   Reply With Quote
Times are GMT -7.   It's 03:58 PM.
