Old 02-25-2013, 07:33 PM   #3361
boostracer
Oddometer: 32
Originally Posted by charlie27 View Post
From what I understand that (screen) is not part of the spark arrestor.
Correct, I've had mine apart, they have a round tube screen inside.
boostracer is offline   Reply With Quote
Old 02-25-2013, 07:52 PM   #3362
Notaduke
Migration to offroad
Notaduke's Avatar
Oddometer: 36
Thanks again ...
I haven't yet got the various things needed to fine tune, or even identify the map...its bone stock right now and in Canada I would be surprised if they loaded the unrestricted Euro map, so that all seems consistent with people's comments.
Will pick up a JD tuner after I get the gearing sorted. I've never done single track before, and had it out on the weekend for the first time, with the stock gearing. Was absolutely amazed how easy it was to work through some non-trivial (to me) stuff, but would definitely have been better off with lower gearing.
Notaduke is offline   Reply With Quote
Old 02-25-2013, 09:07 PM   #3363
RSinBC
Oddometer: 183
Screen
Hey notaduke, my screen fell out as well on the first ride, i also found it. It is not part of the spark arrester, but it is for reducing the noise of the bike. It leans the bike out even further once it falls out, so it will pop more. I have installed the JD tuner and it definitely helps with the performance of the bike, but has not stopped it altogether.
I will be taking the bike to Holeshot to get the unrestricted euro map from the XC-W installed (I think the exc and xc-w unrestricted maps are the same??) I will also get the TPS settings checked.
It seems a lot of guys are skipping the JD and just remapping, the JD might be good if you change the exhaust as well?? and need to add more fuel.
I am waiting for some more bits to arrive so i can finish the bike and get it out to the dealer.
Regards,
Richard
RSinBC is offline   Reply With Quote
Old 02-25-2013, 09:42 PM   #3364
Notaduke
Notaduke's Avatar
Oddometer: 36
Maps/Tuner
Richard, thanks, and good to hear from a local with the same bike. I have to learn more about options with tuning vs maps on the KTM. I'm familiar with Powercommanders and Trimming programs on my streetbikes, but it sounds like this JD tuner is something a bit different. I'm not likely to change the exhaust in the short term, but would like to have it run a bit richer in more-or-less stock form. Sounds like the unrestricted map is worth looking into.
Regards,
Jeff
KTM 500 EXC
Ducati Multistrada 1200S
Ducati 999S
Old 02-25-2013, 11:06 PM   #3365
dentguy
dentguy's Avatar
Oddometer: 1
Remapping
Can somebody please tell me if or what shop in Southern California will re-map my ecu? I've called a few shops and they said CARB will fine them if they get caught doing the mod. I called a shop in LasVegas and they said bring it down, no problem. Wtf CA? PM me so the CARB nazis don't find out. Thanks - D
dentguy is offline   Reply With Quote
Old 02-26-2013, 09:53 AM   #3366
justlookin
Oddometer: 270
Schematic ?
I have a new XC-W and would like to find or buy a copy of the schematic. Asking here because the EXC should be very close with a few additional parts. Any ideas wher I can find this or possibly other fuel injected KTM's with similar schematic?
By the way, I don't have any specific electrical issues, just want to be prepared for when I do.
justlookin is offline   Reply With Quote
Old 02-26-2013, 11:43 AM   #3367
Bengt Phorks
Oddometer: 255
Originally Posted by Notaduke View Post
Great, thanks. That solves that part of the puzzle, although this pie pan with a pie in it seems like a pretty bizarre piece of engineering.
I guess I can't say with 100% certainty until I get a new screen installed, but it seems to me that losing that screen has an amazingly big impact on the backfire situation. Must be right on the edge with it installed.
If you still have the smog equipment on then you have to drain the charcoal canister. What happens is the canister fills up with gas from the vent tube when you tip the bike over. It backfires because the gas in the canister flows into the exhaust instead of just the fumes. The exhaust screen makes extra back pressure which reduces the flow.
You can drain it by removing the plug from the tube that comes out underneath the bike.
Way back in this thread there are instructions on how to remove the smog equipment for test purposes only:)
Bengt Phorks screwed with this post 02-26-2013 at 11:53 AM
Bengt Phorks is offline   Reply With Quote
Old 02-26-2013, 11:54 AM   #3368
cross-country
cross-country's Avatar
Oddometer: 1,679
Originally Posted by bmgyver View Post
grease on splines
Does it say that in the manual? That seams to me like it could only cause trouble. The pressure between the sprocket and the CS would push out any grease and it would attract dirt to the area around the seal, possibly causing it to fail.
cross-country is offline   Reply With Quote
Old 02-26-2013, 08:24 PM   #3369
2on2off
Head'n somewhere new
2on2off's Avatar
Oddometer: 1,315
2012 500EXC and 2013 500EXC Flame Outs
I have both a 2012 and 2013 500EXC.
I fixed the 2012 flame out problem by installing the Euro Map. Smog removed and an FMF slip on installed.
My local KTM mechanic said he thought it was a bad idea to mess with the TPS. He is a chief mechanic for a sport bike racing team. My flame out was fixed once the Euro Map was installed.
When I bought my 2013 500EXC, I was told KTM had fixed the flame out problem with the 2013 stock KTM MAP. Not true. I have de-smoged and removed the screen from the end of the stock slip on muffler. Back firing was fixed with the de-smog but I have some minor flame out issues.
If I install the Euro Map for the 2013 500EXC, which I believe is a different MAP number then and MAP for the 2012 EXC, will that fix my flame out problem? Would like to know if anyone has done this.
My 2012 500EXC runs perfect after the Euro Map was installed. It cost me $45.00 to have it done and I see no need for a tuner.
Jim
I came to ride...........
2on2off is offline   Reply With Quote
Old 02-26-2013, 09:14 PM   #3370
bmgyver
Oddometer: 59
Light greasing of the splines is to prevent the the splines on the countershaft from degrading over the life of the bike. Extra grease tends to go into the void behind the domed washer. In 75,000 miles over 3 ktm 4strokes I have never had a countershaft seal fail.
bmgyver is offline   Reply With Quote
Old 02-26-2013, 09:38 PM   #3371
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,148
Close, but the fuel from the canister is sucked into the intake.
The other emissions hose allows air into the exhaust, this is just like a huge exhaust leak and ignites the rich exhaust fumes. This makes the popping noise.
"Son, you can't do both"
Old 02-26-2013, 10:58 PM   #3372
boostracer
Oddometer: 32
[QUOTE=2on2off;20819919]
QUOTE]
I had the Euro done on mine & it fixed it, runs great!
Old 02-26-2013, 11:06 PM   #3373
Bengt Phorks
Oddometer: 255
Right, but drain the canister to stop the popping.
Old 02-27-2013, 04:35 AM   #3374
Harley Beemer
Harley Beemer's Avatar
Oddometer: 93
[QUOTE=boostracer;20820556]
QUOTE]
Does the EU map work okay with the stock muffler once you remove the end screen?
Or are more mods required?
12' KTM 350 xcfw
09' Genuine Blackjack
Harley Beemer is offline   Reply With Quote
Old 02-27-2013, 09:21 AM   #3375
PatrickM
Oddometer: 366
Decided to try and desmog my stuff in a few steps to see what had the biggest bang (and because I didn't have the right crows foot wrench at the time to get to the SAS)
With the stock ECU and the little noise screen in, there was little back firing but it's more muffled and a lot less noticeable / annoying.
Removing the charcoal canister (without touching the Evap solenoid) didn't do anything. When I removed the silencer from the muffler, it actually seemed to increase the back firing and was obviously more noticeable. Taking the SAS out of the equation didn't help at all.
Then had my ECU remapped and went for another spin. Again, nothing if not worse when backing off of the throttle - aggressively.
But the biggest win? Shutting down that Evap solenoid. If anything that would seem to have cured the situation.
Regardless, removing the charcoal canister, the SAS, the Evap solenoid (and air intake to the cylinder head) and finally remapping...
Woo hoo. I'm riding it on the street these days (if you see a rider in BMW gear in Sunny CA...)
...and trying to keep my license. I can so see how this would get someone pulled over. Multiple times.
For cities, you're not going to need to get past 100 and you have so many gates, err lights, and you can hook up really easy with some dual sport tires.
Soooo many people are waving and motioning me to pop a wheelie...
Originally Posted by MJG2 View Post
I plan to de smog and remove canister /hoses and solenoid valve -anyone find a nice cap for the plug that goes to the evap solenoid- Id love a cap that snaps in for a nice weathertght seal -I bet there is something out there thats OEM harness plug
I see some guys put grease in there and then elec tape it up -I'd like something cleaner
Same here.
So much joy regardless!
PatrickM screwed with this post 02-27-2013 at 04:08 PM
PatrickM is offline   Reply With Quote
Times are GMT -7.   It's 11:26 AM.
