Old 03-20-2013, 07:58 AM   #3556
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,230
Originally Posted by Bengt Phorks View Post
On my shock the retainer unscrews right off the end of the shock without any problem. (2012 500 EXC)
Release preload ,remove spring, unscrew retaining ring.
2012 500EXC, not on mine. To replace the plastic screw, the whole shock had to come apart.... I even had the shock guy confirm this stupid issue. yes, the steel ring will come off, but not the plastic set screw....
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 03-20-2013, 01:17 PM   #3557
Enduro Outlaw
Enduro Outlaw's Avatar
Oddometer: 27
Maybe you went the wrong way by raising the fork tubes. It decreases the rake and trail which makes the front want to slide out. Think about mountain biking in the sand, its very hard to keep the bike going in a straight line without the front washing out. By lowering the fork tubes you increase the rake and trail which makes the bike more stable and stops the front end from skittering around and breaking traction.
Here is my setup. I weigh 250+ with gear. The fork tubes raised 8 mm in the triple clamps and I am using the the stock springs (4.2)
I have a 8.4 spring on the rear with 4.5 inches of sag and the rebound setting is 2 clicks harder than the comfort setting. When the bike was new the 7.6 spring felt too stiff and as it broke in I went to a 8.0 then to the 8.4. I took about 50 hours before the suspension settled in.
Tire selection goes from the Metzler Enduro Extreme to Dunlop 606's. Right now I am running a Pirelli Scorpion on the front. All the knobs on the edges have broke off but it doesn't seem to make any difference.
The bike is so stable I can darn near drag the handlebar in a corner while waving at the girls.
Your right.. I left everything the same except reset the compresion and rebound back to the "Standerd" possitions per manual and went for some laps. It turns better so I'm going to try to drop the forks back down in the clamps and try again. Handling is more important to me than being able to tip toe..haha
Just gonna have to revert to the old off balence bailout method from now on.. good thing I have radiator braces and good bark busters.
Enduro Outlaw screwed with this post 03-20-2013 at 01:24 PM
Enduro Outlaw is offline   Reply With Quote
Old 03-20-2013, 01:42 PM   #3558
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,714
Head light on/off project
On my old LC4 I had a switch that would turn the head light on and off, loved it - I wanted to do the same with my 500. 2 reasons so save my bulb, I'm on my 3rd and to be more stealth ha. Total cost = $4.00 for the switch, had the scrap aluminum hanging around.
I made a little box to hold a simple push/pull on/off switch.
We know the stock dash is very tight. I tucked it on the brace for the stalk for the left turn. The lip goes under the stalk and I'll use 2 mini nuts/bolts to hold it in place.
Here is a pix with the mask forward a bit. You can see how it wraps under the turn brace to give support when I pull the switch.
My question to the electrical experts is... what wire should I tap into? The brown on the side or the green or blue on the bottom of the light?
Guns keep society safe.
Colemanfu screwed with this post 03-20-2013 at 02:00 PM
Colemanfu is offline   Reply With Quote
Old 03-20-2013, 05:07 PM   #3559
2on2off
Head'n somewhere new
2on2off's Avatar
Oddometer: 1,321
Originally Posted by MJG2 View Post
You mentioned you have XCW map -its might not be #701 latest and greatest -actually a EU map
Id find out the # on your ECU map and before you add stuff like JD tuner or that magic mod get the #701 ECU map loaded at a local dealer- many people have only that Map and are very pleased -
701 map
set idle
check tps
that might do it
I have the following map installed on my 2012 500EXC with the FMF Factory 4.1 RCT muffler installed, desmogged, and it works great:
# KM787 EU12C 0601
On my 2013 KTM 500EXC, desmogged, with stock muffler and the end screen removed bike, I just installed the following MAP:
#KM787 EU12C 0701
I will be testing this map on the 2013 500EXC this weekend on a 3 day ride in Nevada with elevations ranging from 4,000 - 9,000 ft. and temps ranging from 19-70 degrees. This is the map that was recommended to me to cure the intermittent "flame out" I was experiencing.
Jim
I came to ride...........
2on2off is offline   Reply With Quote
Old 03-20-2013, 05:15 PM   #3560
2on2off
2on2off's Avatar
Oddometer: 1,321
Acerbis 5.3 is great
Originally Posted by team ftb View Post
For those that have ridden the 500 with both the Acerbis 3.0 gallon and the KTM Hardparts 3.4 gallon tank what were your ergonomic and riding experiences comparing the two?
Is the KTM slimmer at the tank/seat junction where you grip your knees and legs?
For example, when I rode my 525 with the Hardparts compared to a Clark the Hardparts felt nice and slim between my knees and the width of the shrouds showed their girth only when extending the leg up by them for turns. Whereas the Clark felt thicker through the middle but no shrouds cluttered the legs when motocrossing through turns.
Since Clockworks has done the new mold (to correct fitting problems that were documented on this thread) on their tanks for the 500 has anyone tried the new mold? Does it fit without issues, concerns? what are the latest impressions on the Clockwork?
I have not used the fuel tanks listed above but was waiting last year for the Safari 4.0 gallon fuel tank to be released. It was taking so long I finally decided to buy the Acerbis 5.3 and am I glad I made that decision.
I have exclusively used 4.0 gallon fuel tanks in the past on a DRZ400S and Honda XR650L. I liked them but like the fuel range of the 5.3 so much better and do not feel it is too wide for my 500EXC.
It is wider than the stock tank but that doesn't bother me the way I ride. Here is a few pictures:
It clears my KTM Radiator guards and is easy to install with no modifications:
Jim
Old 03-21-2013, 12:05 PM   #3561
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
I finally did something about that stock torture device of a seat
I had it made like my other Renazco seats, narrower on the front for control then wider in the back so I can slide back some for more comfort when I'm just cruising.
This is the third seat they have made for me and I consider this an essential mod on any of my bikes.
Its worth every penny.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 03-21-2013, 12:11 PM   #3562
ABYSS
KTM
Oddometer: 1,198
I have a brand new hard parts 13L
If anyone wants to unload a 13L Hardparts tank, or an Acerbis drop me a PM please.
never even out of the box. if your interested
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 03-21-2013, 01:01 PM   #3563
fasteddie23
Oddometer: 41
[/QUOTE]
Is that hi/lo switch for your headlight? Where did u get it and how did you wire it up?
fasteddie23 is offline   Reply With Quote
Old 03-21-2013, 01:14 PM   #3564
J.Johnson
J.Johnson's Avatar
Oddometer: 85
Originally Posted by fasteddie23 View Post
Is that hi/lo switch for your headlight? Where did u get it and how did you wire it up?[/QUOTE]
I am just guessing. But the hi/low is most often used for heated grips
Sent with this high tech chingadera!
“This is your life, and it’s ending one minute at a time.”
J.Johnson is offline   Reply With Quote
Old 03-21-2013, 07:27 PM   #3565
Bengt Phorks
Oddometer: 272
From the wiring diagram,
Blue wire - High beam
Green wire - Low beam
Brown wire - Ground
Put the switch on the ground wire.
Bengt Phorks is offline   Reply With Quote
Old 03-21-2013, 07:34 PM   #3566
Bengt Phorks
Oddometer: 272
When I first got my bike I kept tipping over when making a slow turn because i would stall the bike. I raised the idle and hold the clutch halfway in and that stopped most of the falling down silliness.
Old 03-21-2013, 07:57 PM   #3567
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
hey ronin, what handle is that on the side there?
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 03-21-2013, 08:47 PM   #3568
SoilSampleDave
Oddometer: 2,248
I threw the bike away a few times last weekend. Anyone have a right hand side radiator shroud and rhs front turn signal they want to part with?
I actually just broke the clear cover on the front of the turn signal. Those things will actually take a pretty good beating!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC, '08 990SD
SoilSampleDave is offline   Reply With Quote
Old 03-21-2013, 08:50 PM   #3569
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
pm sent.
2012 KTM 500 EXC
www.motoex.net
Old 03-21-2013, 08:55 PM   #3570
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 468
Not only is that a nice seat on that Ronin, but who makes the rear rack?
WRW9751 is offline   Reply With Quote
Times are GMT -7.   It's 10:52 AM.
