Old 04-03-2013, 02:16 PM   #3691
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,684
Not sure what's being chased here? Desmog or not? ECU?
Anyway, how about some more pix? Dirtier the better but I do enjoy the garage and hop up pix .
Last week during a trip 600 miles and 9 hr north to the mountians of south west VA, I got my first chance to ride in the snow. 3 days, cabin was at 3100ft, 24-38' but was never cold and deepest snow was about a foot. OMG was it fun - I was like every time out. I was also shocked how much it was like riding in the sand. Biggest diff was elevation change and the frozen ground (at times) under the snow.
On the top of Mt Maximo looking over at Iron Mt range.
I parked in this pine forest to get out of the wind. Sun was out and the snow was still dumping - loved it.
Barn parking at night - too cold to thaw but it prevent any more snow - it caked up like tundra? The bike did fantastic.
Guns keep society safe.
Colemanfu screwed with this post 04-03-2013 at 02:39 PM
Colemanfu is offline   Reply With Quote
Old 04-03-2013, 02:37 PM   #3692
ossa
Oddometer: 17
I'm trying to get to the real understanding of the impact of de-smog and the relationship with ECU behavior. Ultimately yes, whether to de-smog or not...
And no, I don't see it as circular. If you have the definitive understanding, please share or point me to it. I have yet to see the topic clearly explained, or explained at all for that matter.
ossa is offline   Reply With Quote
Old 04-03-2013, 02:44 PM   #3693
Dirty in all
Adrenaline Junkie
Dirty in all's Avatar
Oddometer: 168
Well what is happening when you desmog is you are changing the mixture and the ECU doesnt know it or adjust for it. Idle is an air screw. When you plug up all the leaks you need to add air again via the idle screw. Not much more to say about it. I guess not obvious to some people but it has been covered. Maybe not in so many words... or less.
Dirty in all is offline   Reply With Quote
Old 04-03-2013, 03:18 PM   #3694
ossa
Oddometer: 17
Is the solenoid valve open only at idle or other throttle settings as well?
Thanks.
Old 04-03-2013, 03:47 PM   #3695
Dirty in all
Adrenaline Junkie
Oddometer: 168
Don't think thats a definitive answer but yes it has been thought to be open at idle with a full canister/rich condition no load, causing bad idle and stalling.
Old 04-03-2013, 04:16 PM   #3696
ossa
Oddometer: 17
Thanks very much.
Old 04-03-2013, 09:40 PM   #3697
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,144
Yeah, there is a small air leak through the canister at idle. This is very minor, but enough to raise the idle. When you plug the vacuum hose at the intake manifold the idle will drop, so you need to open up the idle a little to make up for it.
This doesn't effect the mixture. It doesn't know if the air is coming past the idle speed screw or leaking in through a vacuum hose. This is an open loop system, it knows rpm, throttle position, temps, vacuum, calculates what the mix should be and throws it down the hole.
The reason to remove this canister is the erratic running when the canister gets over full with fuel. When you drop the bike or ride down a steep hill liquid fuel will get blow out the vent and fill up the canister. Then it dumps this liquid into the engine instead of a little vapor. It will soak the plug and in bad cases (BMW) it will hydro lock the motor and bend a rod. It does remove VOC's from the atmosphere.
The other control, the SAS (air valve in the exhust) just adds fresh air to the exhaust and fools the test to make it seem there is less pollution coming out. It doesn't change the amount of pollution created, just lowers the percent of total gas coming out. It makes the back fires, but doesn't effect the running.
Hope this helps. Most of the weird running and flame out's go away after 15 hours.
"Son, you can't do both"
Old 04-04-2013, 02:35 AM   #3698
ossa
Oddometer: 17
It does help. Thanks!
Old 04-04-2013, 07:37 AM   #3699
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Another good reason to lose that canister and smog valve is that the larger 3 gal and up tanks all require them to be gone in order to fit. They take gas capacity space.
buls4evr is offline   Reply With Quote
Old 04-04-2013, 07:03 PM   #3700
yzedf
Oddometer: 84
Picked up my 2013 today!
Started with this in the morning
This in the afternoon
Went to Pachaug for the first time and found this
Awesome bike so far. Even with crazy tall 15/45 gearing this bike rips on top and good grunt down low. :cool:
Chris
2013 KTM 500 EXC
yzedf is offline   Reply With Quote
Old 04-04-2013, 08:18 PM   #3701
Dirty in all
Adrenaline Junkie
Oddometer: 168
You going to supermoto it too??
Bike rips with 17's on it as well.
Old 04-04-2013, 09:27 PM   #3702
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Those rims are cool
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 04-04-2013, 10:45 PM   #3703
BanhXeo
BanhXeo's Avatar
Oddometer: 337
Originally Posted by Ronin ADV View Post
Those rims are cool
Agreed Where did ya pick em up?
2013 KTM EXC-F SOLD
2013 BMW F8 GS FOR SALE
SmugMug: http://ktmrider.smugmug.com/
This is my WIFE, here are my BIKES, and these are my STORIES: http://www.advrider.com/forums/showthread.php?t=897188
BanhXeo is offline   Reply With Quote
Old 04-05-2013, 03:38 AM   #3704
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,684
I got my junk used the PO used it for SM only. So it came with little wheels and a waiting jail cell . 90% of the time it's sporting the knobs which were unused and came with the bike - Flori-duh road are like this _____________________.
No idea where he got the 17's? I have been offered as much as $1000 for em but don't plan to sell. I can make the swap in less than 30 min and will throw em in the back of the truck when I head north this summer.
YZ - welcome and congrats on the new ride!
Old 04-05-2013, 04:04 AM   #3705
Johnnyktm
Oddometer: 117
Congratulations, and enjoy the new bike!!!!
Johnnyktm is offline   Reply With Quote
Times are GMT -7.   It's 12:05 PM.
