Old 04-10-2013, 11:55 AM   #3766
2on2off
Head'n somewhere new
2on2off's Avatar
Oddometer: 1,299
500exc electrical output
I am using my 500EXC more as an Adventure Bike these days and plan to spend more time riding in the high elevations of Nevada where it can get very cold even in the middle of June.
I was wondering if I can run heated gloves and jacket liner on my 2013 KTM 500EXC without running the battery dead.
Gerbing gloves are 2.2 amps and 27 watts
Gerbing jacket liner is 6.4 amps and 77 watts
Any input on this is appreciated.
Thanks.
P.S. I have three riding buddies also on KTM's. Two 525EXC's and one 450EXC. We are all interested in this.
Jim
I came to ride...........
2on2off is offline   Reply With Quote
Old 04-10-2013, 12:01 PM   #3767
LukasM
Oddometer: 5,418
Thanks.
Any fuel injected KTM/Husaberg will handle it fine, the 525s won't, neither the 450 if it's carbed.
Even with a Trailtech stator + flywheel upgrade the RFS bikes will make 120 Watts peak, vs. almost 200 Watts on the 500 (although fuel pump and FI will take some of that).
Old 04-10-2013, 12:09 PM   #3768
E-Ticket2
E-Ticket
E-Ticket2's Avatar
Oddometer: 116
Originally Posted by tricepilot View Post
Yes - by testing the subframe on Tim Morton's Baja Bound Tecate to Cabo ride in September
To give you a serious answer - no
Yup ... that should be a very serious and complete reliability test.
Tell Tim I'd said, "!Hola!"
E-Ticket
"... AYHIN ...."
Mine: '12 KTM 350 EXC-F; '99 Honda VFR 800i Interceptor
Wife: '08 KTM 250 XCF-W; '04 Honda CBR600 F4i
E-Ticket2 is offline   Reply With Quote
Old 04-10-2013, 12:14 PM   #3769
E-Ticket2
E-Ticket
E-Ticket2's Avatar
Oddometer: 116
Originally Posted by MJG2 View Post
Had air filter out of 13 - 500 exc other day and was looking forward into air boot
on top of the duct that runs to the throttle plate is a hole with a sensor coming in -I think its air temp sensor for the FI
It comes in at a hard angle- its not sticking down straight- I thought it looked bent to the side
Then looking out outside of duct/boot- you see it bolts on an angle
so I think thats just how it is
Next time you have airfilter out- look forward at little white sensor top inside duct -is your on a hard angle ?
I believe this is what you're referring to, sir.
Cheers! E-Ticket
And now ..... get ready for the "E-Ticket ride" into the belly of the wee beast ....
[Editor's Note: For the following special effect to work ... you have to scroll rapidly down the page of pics.
Sorry, but it's the best we could do with our very limited budget for "extras" like special effects.)]
Hey ... I told you we had a limited budget ... (grin)
On the Euro bikes, there is an intake restrictor just before the butterfly valve. It's like looking through a low-flow, shower head restrictor.
Fortunately, we do not have that on the US EXC models. You can look into throttle body and directly see the "butterfly" throttle valve
Just below the intake throat for the throttle body is a little sub-chamber.
That's where the air temp/density sensor resides.
"... AYHIN ...."
Old 04-10-2013, 02:50 PM   #3770
MJG2
Oddometer: 53
Originally Posted by yzedf View Post
item 22 ambient air sensor
on E -tickets pictures his are lower in air box and it comes straight in - as you can see in his picture
His bike is a 12-350
further looking shows 12 and 13 350 use same air duct boot
12 and 13 500 use different boot- and the air sensor is moved- interesting- wonder why
so it looks like they moved the air sensor up higher and it comes in at angle- look at your with filter removed and tell me what you see
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
07 Ducati Multistrada 1100 S
MJG2 screwed with this post 04-10-2013 at 02:57 PM
MJG2 is offline   Reply With Quote
Old 04-10-2013, 04:22 PM   #3771
MJG2
Oddometer: 53
Additionally- I'd be interested to know where the crankcase vent line enters the air duct on a 12 -500
My 13 - 500 comes in the bottom
If the 12 500 uses the other style duct -that incidentally is same part# as 12/13 350 - they vent the crankcase to the top of the duct
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
Old 04-10-2013, 09:41 PM   #3772
240nekkid
Oddometer: 29
halogen headlight bulb?
my bulb died and i don't quite have enough for the squadron yet. i was wondering if anyone has tried the halogen from sicass? are their other replacement options? i have a cycleworld close by and will drop in this weekend to check their selection. i don't ride at night much, but if i do of course i want to see better than the stock candle. man, that thing was just plain dangerous. thanks!
240nekkid is offline   Reply With Quote
Old 04-10-2013, 11:02 PM   #3773
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,024
Used the sicass Halogen for a while. I smelled hot plastic smell when ever I stopped. That passed after a while. Brighter, but same light pattern. Went Kablooie way too soon, but lasted 3x of the stock bulb.
"Son, you can't do both"
Old 04-11-2013, 06:37 AM   #3774
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,597
I'm on my 3rd bulb so I added an little simple "on/off".
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 04-11-2013, 07:29 AM   #3775
woodzrider
Oddometer: 585
I bought 2 halogens from Sicass. (one for a spare). Just finisehed a 450 mile dualsport ride with no issues so far. I too will spring for the squadron
when the money allows. it's not so much the bulb, or the halogen. It's the crappy reflector as it does not focus the beam well at all. in fact it scatters the crap outa the light . I have a Sicass light kit on my XC-W which allows the headlight to be turned off but the DRL stay on as well as the rear light. I merely left the factory switch wired in the circuit so I can turn all lights off when off road.
Woodzrider AKA vetracer1
"If it can't kill ya-it's not a sport"......It ALMOST killed me tho.....
Check out my crash report:
http://www.advrider.com/forums/showthread.php?t=500314
Baja report http://www.advrider.com/forums/showthread.php?t=641219
woodzrider is offline   Reply With Quote
Old 04-11-2013, 07:49 AM   #3776
SoilSampleDave
Oddometer: 1,993
Same here, waiting to spend the big bucks for a Squadron. But I saw this on sale at CG, and am thinking about giving it a try at only $60. Any tried one of these?
http://www.cyclegear.com/CycleGear/P...p/40457_425407
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is online now   Reply With Quote
Old 04-11-2013, 11:14 AM   #3777
2on2off
2on2off's Avatar
Oddometer: 1,299
KTM Watts Used
Thanks for the information. I understand my 500EXC will use approximately 130 watts when running, (that is what the KTM Dealer told me but I don't know if that assumes running the headlight, taillight, brake light and turn signals all at the same time) leaving me about 70 watts available at the maximum.
What would you guess I could save in watts if I do not run my headlight? I have a 35 watt bulb so I'm guessing I would save 35 watts. I don't think there is anything else to turn off to save watts if I needed 104 watts for heated gloves and jacket liner.
I'd really like to know if anyone out there has actually tried running heated gloves and jacket liner on the 500EXC. I guess I can always just buy the heated stuff and see what happens. I would only be using them during daylight hours so I don't have to run my lights. I have the Sicass headlight switch so I can turn off my lights while riding.
Jim
Old 04-11-2013, 12:42 PM   #3778
E-Ticket2
E-Ticket
E-Ticket2's Avatar
Oddometer: 116
You know ... you guys might want to rethink your policy of turning off your headlight when riding off-road.
Because head-on crashes ... absolutely SUCK.
Ask me how I know.
And anything you can do to catch the attention of someone coming at you around the corner of a fire-road or trail -- is a good thing.
Mmm-kay-y-y?
E-Ticket
"... AYHIN ...."
Old 04-11-2013, 03:40 PM   #3779
Stifdickerson2006
Stifdickerson2006's Avatar
Oddometer: 139
Subframe testing
Leaving for a 7 day Baja trip this sunday and was all loaded up. I just could not trust the subframe to hold this amount of weight. I am pretty sure that it would be alright but in Baja if it broke I did not want the hassle. I ordered a rack from RTE (www.globetrottin.com) they sold me a used one for a good price (thanks guys)and two day delivered it to my house just to be sure. I'm gonna install tonight and remount my luggage. but here is a pic of it set up before rack install. it seemed very sturdy and most of the weight is over the sturdier part of the subframe but in the back of my head I just did not want to worry about it. and with my back pack and gear on it was a little cramped for my 6'1" frame in the cockpit.
gps,chapstick and phone holder
for shorter rides and rides less strenuous on the bike. i would have no problem using this set up with out a rack. jmo.
No Matter Where You Go, There You Are.
Stifdickerson2006 is offline   Reply With Quote
Old 04-11-2013, 04:41 PM   #3780
Steve Lewis
Oddometer: 55
Globetrottin rack problem solved!
Steve Lewis is offline   Reply With Quote
Times are GMT -7.   It's 12:44 AM.
