Old 05-19-2013, 06:36 PM   #3991
MJG2
Oddometer: 53
Originally Posted by spagthorpe View Post
Has anyone read what's changing in the 2014 models? Supposedly they'll be here in another month.
http://www.ktm.com/us/enduro/500-exc-eu/highlights.html
look here and click on the links on bike picture like -engine
shows new benefits
mention new lighter cam and valve train- mentions titainium valves -but it already has that
looks to have new piston and rings -I do recall some guys mentioning smoking etc -so new style rings makes sense
also excel wheels and some new from brake master cyl
looks like some small upgrades to an alreaady great machine
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
07 Ducati Multistrada 1100 S
MJG2 is offline   Reply With Quote
Old 05-20-2013, 05:38 AM   #3992
MJG2
Oddometer: 53
con rod and bearing on 12/13
Does the 12 /13 model 500 EXC use the con rod with plain bearing lower
or is it conventional roller bearing
I see the 14 model will use it
ANd some of the prior year MX engines have used it
anyone know for sure what lower con rod bearing in a 13 500 EXC
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
Old 05-20-2013, 09:13 AM   #3993
Red Barron
Red Barron's Avatar
Oddometer: 24
Mileage
Originally Posted by MJG2 View Post
I have EU map, desmog and Akro exhaust
What do you think my range is with stock tank
2013 500 EXC
2012 500 EXC
124.6 miles.
Wonder how I know that exact number.
Always do the right thing. You never know if you will get another opportunity.
Red Barron is offline   Reply With Quote
Old 05-20-2013, 10:12 AM   #3994
MasterMarine
Oddometer: 1,566
2013 500 EXC
With the stock tank de-smog, and stock exhaust, the light came on for me at 88 miles and I was getting worried at 100 on my first tank. It had about 30 miles on it with stock programming and then was switched to the euro map for the rest of it.
I have seen mileage ranging from 36 to 47 mpg depending on the terrain. The last was 40 mpg over about 3 gallons over last weekend. I did some semi technical 2 track, lots of gravel roads and some pavement. I was pretty aggresive with the throttle and will certainly get better mileage if I concentrate on my throttle management. I have stock gearing right now.
I think I am at about 380 miles and the back tire is pretty much shot. What a fun machine!
MasterMarine is offline   Reply With Quote
Old 05-20-2013, 10:22 AM   #3995
MasterMarine
Oddometer: 1,566
I know there is some discussion in this thread somewhere about gearing. I am wanting to get some more current discussion going about it.
I have a 2013 500 EXC. It has the stock final drive ratio. As everyone knows, it is way too high. The highest gear is too high to use even on the highway. The only time it is useful is at speeds that are way higher than I should be running on this bike. I have no control of my speed while descending steep loose terrain.
So, I am going to use the bike for a 1300 mile mostly offroad ride in Nevada in about a month. I was planning to try to leave the stock gearing but it has become obvious I need to fix it. I need to gear it down. I also am going to use the bike to ride tight twisty single track trails here in WA. I would like to get some sprockets for both of these uses. I am not opposed to having 2 different front or rear sprockets and switching them out depending on the use. I would like to try to maintain descent mileage numbers to keep the overall fuel range as high as possible. And I would like to retain the stock chain if possible.
So what are your ideas? What are you running?
Old 05-20-2013, 01:17 PM   #3996
MJG2
Oddometer: 53
stock chain and I put 13 48 on it from day one -still does over 80 mph
not much riding yet but seems good all around for tight trails and open fire roads -I ride mostly woods trails -I like it so far -if anything Id go 49 or 50 next time -
side note -XC w comes 13-50 stock
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
Old 05-20-2013, 02:37 PM   #3997
boostracer
Oddometer: 32
You can go 14/48 & keep the stock chain. I'm running 15/51 which is approx. the same ratio, (added a couple links), did it to keep chain off swingarm protector as much as possible. This gearing works great for offroad also.
boostracer is offline   Reply With Quote
Old 05-20-2013, 04:49 PM   #3998
Bungholio
Bungholio's Avatar
Oddometer: 661
13/48 or 49 seems to me to be as low as i need for any trails or climbs i have ridden. I switch between 15/49, 14/49, 13/49 dependjng where i ride the most. I feel if you need lower than 13/48-50 you're riding too timid and slow. Yes it will do 80 on the highway or wherever but that engine is wound up over 6000RPM and thats probably not good to maintain for long.
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is offline   Reply With Quote
Old 05-20-2013, 05:46 PM   #3999
Dirty in all
Adrenaline Junkie
Dirty in all's Avatar
Oddometer: 168
It's very terrain and rider dependant. Up here in the rocky woods of Ct at 43, I'm running 13/50 (requires a chain) when in dirt trim. It's nice to lug around without dealing with the clutch in 1st or 2nd gear and it still has a decent cruising speed for uneventful parts of the ride. It's also a good gearing for the deep water crossings with basketball and beach ball sized rocks hidden in murky waters. I was running 14/48 (stock chain) last year and found myself looking at Rekluse auto clutches but the new gearing has changed that mindset.
Little off topic but I also run the bike in supermoto trim with 15/48 gearing and again we have tiny little technical roads but I also made a trip down to the Dragon area and it was perfect.
I'm probably not in the best shape either and it's a good thing to have a bunch of snap on hand with lower gearing.
Dirty in all is offline   Reply With Quote
Old 05-20-2013, 08:27 PM   #4000
Too Tall
Too Tall's Avatar
Oddometer: 190
The Owner's Manual, in Chapter 22-Technical Specifications, states the lower connecting rod bearing is a roller bearing. Fortunately, I have not had to verify this.
Gearing wise, I've been running 14/50 which still allows a top speed over 90 mph. Required a longer chain to accomplish this.
www.2wheel-adventure.blogspot.com
2014 KTM 350EXC-F
2012 Triumph 800XC
2010 KTM 990 SMT
2007 Suzuki DR650
Too Tall is offline   Reply With Quote
Old 05-20-2013, 09:55 PM   #4001
Wentjo
Wentjo's Avatar
Oddometer: 419
I run 14/48 and love it. Does well in the technical sections too. Cruises nice at 75 down the highway.
Wentjo is offline   Reply With Quote
Old 05-20-2013, 10:08 PM   #4002
avconnect
Oddometer: 111
Gearing wise, I've been running 14/50 which still allows a top speed over 90 mph. Required a longer chain to accomplish this.[/QUOTE]
I am running 13/50 with a longer chain. I hit the last gear when on the street and find myself wanting more gears so it is way to low for freeway use but that is not what I bought the bike for. A few weeks ago I tapped it out and hit over 90 mph with that gearing but sustaining that speed is not a good idea. Anything over 55 or 60 mph feels like the engine is revving too high. Off road is an entirely different matter. How often do any of us sustain speeds of or 50 mph off road for more than a minute or two. 99% of my riding will be off road and at consistent speeds of less than 45 mph. For that my gearing is spot on. Don't forget that 13/50 is the stock gearing for the 500 XCW. 13/50 is not a crazy low choice for gearing.
avconnect is offline   Reply With Quote
Old 05-20-2013, 10:37 PM   #4003
MasterMarine
Oddometer: 1,566
Thank you everyone for the input so far. If you haven't given your thoughts on your gearing choice yet, please weigh in. You comments really help too.
The thing is that I will be running for considerable distances on long straight dirt roads at or around 50 - 60 mph. I think the average speed is around 45 mph on the trip I have planned.
I found a sweet sprocket ratio document on JT's website.
I think I am leaning toward a 49 or 50 on the rear. Then I will get a 14 front and have the stock 15 to fool with. That should slow the bike down quite a bit. I don't know. Still thinking...
Old 05-21-2013, 12:53 AM   #4004
Bungholio
Bungholio's Avatar
Oddometer: 661
I rode the first part of the mex2can ride last year, Tecate to Fallon NV. Lots of dirt roads and a bit of hiway through socal and death valley. Started with 15/49 but changed to a 14 cs after first day. It worked fine but i felt i should have stayed with the 15 cs.
Old 05-21-2013, 06:03 AM   #4005
Dirty in all
Adrenaline Junkie
Oddometer: 168
Heres my favorite one ....
http://www.sprocketcalculator.com/
Times are GMT -7.   It's 04:25 AM.
