Old 06-19-2013, 02:35 PM   #4186
mmjsport
Oddometer: 34
It's also the stock gearing in the US now for the 2014.
mmjsport is offline   Reply With Quote
Old 06-19-2013, 02:37 PM   #4187
Bungholio
Bungholio's Avatar
Oddometer: 786
Originally Posted by DiVango View Post
Installed the new 14-50 gears and chain. Very impressed with the new gearing. Now I can chug around the trails in 3rd gear and 1st is good for really tight stuff. 6th is now high gear instead of an overdrive. Chugs in 6th gear at 45mph which is perfect for most of my street use. Still can hit 75+ if I need the higher speeds. IMO this should be the stock factory gearing for this bike.
Sent from my SCH-I605 using Tapatalk 2
If KTM did that nobody would be spending money on new sprockets and longer chains
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is online now   Reply With Quote
Old 06-19-2013, 03:42 PM   #4188
DiVango
DiVango's Avatar
Oddometer: 109
That is the truth! Would not have a pretty Orange Sprocket and Gold Chain. I am pretty sure they make me go faster:)
There is no Traffic Jam on the Extra Mile (Zig Ziglar)
DiVango is offline   Reply With Quote
Old 06-22-2013, 06:00 PM   #4189
lukeinlondon
lukeinlondon's Avatar
Oddometer: 437
Originally Posted by Nomad View Post
sweet i actually just got an extra set of open back cycra guards in the mail.
Sent from my SPH-L710 using Tapatalk 2
lukeinlondon is offline   Reply With Quote
Old 06-22-2013, 06:15 PM   #4190
Vinnie the Snake
Oddometer: 1,094
Picked my EXC500 up today.....Hope this thing turns out to be a winner for me......all in now...
2007 - Vintage TAT - Ok, NM, Co
http://www.advrider.com/forums/showthread.php?t=233901
2008 - Vintage TAT - Ut, Nv, Or
http://www.advrider.com/forums/showthread.php?t=331983
2009 - Vintage TAT - NC, Tn, Ms, Ar
http://www.advrider.com/forums/showthread.php?t=507149
2010 - Unfinished Business Tour - TAT, CDR Shadow of the Rockies
http://www.advrider.com/forums/showthread.php?t=615279
Vinnie the Snake is offline   Reply With Quote
Old 06-22-2013, 06:20 PM   #4191
lukeinlondon
Oddometer: 437
I am still hopeful too although I have owned one for a few months
Old 06-24-2013, 10:24 AM   #4192
MasterMarine
Oddometer: 1,667
I broke my kickstand on the first day of an 8 day 1330 mile ride in Nevada last week. Does anyone have a suggestion on which aftermarket unit to buy? Damn thing fell over on the gravel shoulder of a paved road and folded the kickstand up under itself.
The bike was fantastic for the trip. I need to get it re-sprung and lowered a bit. I must have dropped it at least 10 times just because it is so tall and hard to get on and off of for me. Especially when loaded down with the Giant Loop and a tank bag. 14:50 gearing was spot on. I got between 40 and 50 mpg depending on how hard the trails were. Awesome bike!
MasterMarine is offline   Reply With Quote
Old 06-24-2013, 10:31 AM   #4193
YAHBO
Grip and rip since 1983
YAHBO's Avatar
Oddometer: 824
[QUOTE=MasterMarine;21714675]I broke my kickstand on the first day of an 8 day 1330 mile ride in Nevada last week. Does anyone have a suggestion on which aftermarket unit to buy? Damn thing fell over on the gravel shoulder of a paved road and folded the kickstand up under itself.
PRO MOTO BILLET. Done deal. Best unit out there.
I'm an asshole and I approve this message.
YAHBO is offline   Reply With Quote
Old 06-24-2013, 11:04 AM   #4194
trailjammer
trailjammer's Avatar
Oddometer: 381
Sounds like an awesome ride. Yeh, ProMoto is probably the best aftermarket choice for the kickstand. Sounds like your bolt may have just fallen out. :(
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 06-24-2013, 11:24 AM   #4195
LukasM
Oddometer: 5,427
If you want to replace the whole kickstand, PMB has the best and most durable one.
If you just want a bigger and more sturdy foot, Brap has an aluminum replacement.
Old 06-24-2013, 11:46 AM   #4196
MasterMarine
Oddometer: 1,667
I should have been more specific. The actual kickstand broke right at the pivot bolt. It kind of ripped as it bent. So, I need the whole setup. I had not seen in this or the other 500 threads where anyone had replaced a kickstand so thought I would ask for input.
It was an awesome ride and I will make a Ride Report for it but it will probably be a while. A lot of my life was on hold in preparation for the ride and now I am going to have to get some of that stuff done first.
Old 06-24-2013, 01:33 PM   #4197
Bengt Phorks
Oddometer: 275
Can you post a copy of the GPS track if you have one? It would be nice to see where you went.
Bengt Phorks is offline   Reply With Quote
Old 06-24-2013, 01:40 PM   #4198
YAHBO
YAHBO's Avatar
Oddometer: 824
PMB kickstand
The awesomeness:
Old 06-24-2013, 03:01 PM   #4199
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,271
Too tall seems to be a common theme with the EXC. I'm 5' 9" and while I could touch tippy toe style I felt for safety reasons to lower the rear shock 1". I had Factory Connection here in NH take an inch of travel out of the shock. I then slid the forks up the same amount to balance out the bike. I then reset the sag.
I can now "almost" flat foot when stopped. $240.00 for the work on the shock but I dropped it off and picked it up. I know Motolabdirtbikes ($200 plus $40 shipping) in AZ does the same thing and may be a better choice as it may be closer.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 06-27-2013, 08:11 AM   #4200
mtbmitch
Oddometer: 9
14/51 gearing
I run 14/51 gearing on my 13 350 xcf-w here in Idaho. I first tried a 14 with the stock 52 rear and found that the bike just revved out to quick and did not pull in the lower gears, then tried a 50 and could not go slow enough in 1st for the tight stream and switch back stuff (trials back ground). The 51 is just right for me. I also run a dirt tricks cooling fan. Like the idea of extra air over the radiator in the tight stuff.
Originally Posted by leippra8 View Post
Has anyone tried 14/51 gearing?
mtbmitch is offline   Reply With Quote
Times are GMT -7.   It's 11:29 AM.
