Old 08-29-2013, 09:14 AM   #4456
RSinBC
Oddometer: 213
Map Info
These are the older maps, the one under the XC-W column is what i have installed
Have your dealer install the EU map for your machine:
DisplacementEXCXC-W
500KM787EU12C0651KM787EU12C0601
450KM781EU12C0651KM781EU12C0601
350KM775EU12C0652KM775EU12C0601
These are the newer Maps, the one i could not get installed, yet!
Again you need the EU unrestricted map, the US map may work but i would still stick with the EU version
USA, XCW > KM787US12C0701 stock, Unrestricted> KM787EU12C0701
USA, EXC > KM787US12C0651 stock, Unrestricted> KM787EU12C0701
Euro EXC, EXCF > KM787EU12C0651 stock, Unrestricted> KM787EU12C0701
Aus EXC, EXCF > KM787EU12C0701 stock, Unrestricted> KM787EU12C0701
You will only get the re-map done by a dealer who has the factory computer, VX-1 unit??? can't remember the name??? not all dealers have this tool, mostly dealers who sell streetbikes as well as the dirt bikes.
Find out if they have the re-programming computer then ask if they have any of the above EU maps available, MUST be the XC-W unrestricted one!!!!!
Good luck, it is worth it even if you do not add the map switch it will make the bike run better.
Hope this helps.
RSinBC is online now   Reply With Quote
Old 08-29-2013, 10:18 AM   #4457
bill1960
Oddometer: 365
DisplacementEXCXC-W
Hope this helps.
I had my 500 xcw remapped from day 1 with the KM787EU12C0601 map.
As GSeh outlines, that map is now superseded by the KM787EU12C0701
map.
The map switch only alters the ignition, not the fueling.
The stock XCW map is not overly lean like the stock EXC map, but neither will allow the ignition curve switch to work.
You need the EU map for that.
The dealer tool used to remap is the XC-1 tool.
bill1960 is offline   Reply With Quote
Old 08-29-2013, 12:26 PM   #4458
No_Good_ID
Oddometer: 15
Freight?
Does anyone know what the standard freight charge is in the US for 2014 EXC 500? Thanks.
No_Good_ID is offline   Reply With Quote
Old 08-29-2013, 05:58 PM   #4459
AussieClay
AussieClay's Avatar
Oddometer: 59
Mapping
I have the EU 0701 map installed (2012 EXC) and the switch works - you can feel a slight difference in the aggressiveness of the power response. I first had the US 0701 map installed and can confirm the switch does not work.
I also run the JD tuner and now it's set up, the bike performs well. Without the tuner I used to still get flame outs, the occasional backfire, etc.
It took a lot of trial and error and $ messing around but I'm now very happy with the way the engine performs. I also went from standard 15 -45 to 14 - 48 and that was a big improvement for the woods riding. I would ideally have gone to a 50 or 52 rear but will wait until the next sprocket and chain change.
AussieClay is offline   Reply With Quote
Old 08-29-2013, 06:01 PM   #4460
lowpro
Oddometer: 10
DisplacementEXCXC-W
Hope this helps.
So is it safe to say that any (Orange Level Service) KTM dealer would have this XC-1 tool?
lowpro is offline   Reply With Quote
Old 08-29-2013, 06:41 PM   #4461
ecarnell
ecarnell's Avatar
Oddometer: 394
Wow.
Stock EXC gearing is pretty tall,
Raced a little bit agaisnt a uncorked XR650 tonight - I couldn't pull top 6th gear - he would just start to pull away (156km/hr indicated) - then had to down shift to 5th and slowly creep by.
This is will a 2014 stock EXC, stock exhaust, stock gearing, smog equipement all installed, - just with extra 701 map (though no switch installed).
I just finished up desmog, map switch installed, and just checked valves.
Exhaust was .16-.17mm both sides, Intake was .12mm and .13mm. No worth adjusting.
Tomorrow after work should be fun!
2014 KTM 500 EXC
2011 KLR
2012 Dacre Challenge -Team Explore the Bruce - 8th (i.e last) Place. 17:59
ecarnell is offline   Reply With Quote
Old 08-29-2013, 07:03 PM   #4462
lowpro
Oddometer: 10
Interesting. So it still backfired and flame outs after the EU 0701 map? Was it still backfiring after de smog? I was told you shouldn't need the JD tuner once it was de smoged and EU 0701 map
Old 08-29-2013, 07:10 PM   #4463
lowpro
Oddometer: 10
Originally Posted by ecarnell View Post
Wow.
What kind of oil are you using for break in? Synthetic or regular mineral oil?
Old 08-29-2013, 07:23 PM   #4464
AussieClay
AussieClay's Avatar
Oddometer: 59
Mapping
Sorry, forgot to mention, the bike was desmogged before remapping and the JD tuner. The desmog made the bike a lot better. Only an occasional backfire but still too many flame outs. JD tuner eliminated these issues altogether. Mapping made the most difference in performance.
Old 08-29-2013, 07:36 PM   #4465
ecarnell
ecarnell's Avatar
Oddometer: 394
The "expensive" "good" "motrex" ktm gold stuff - as recommended by manufacture.
I couldn't wait till tomorrow - took the bike out for a quick spin the dark. Definetly feel a different in roll on power in first compared to the mild and wild settings. The bike may have been running smother due to the desmog also - cant really tell until I get out on a good ride.
May have to drop down a tooth in the front.
2014 KTM 500 EXC
2011 KLR
Old 08-29-2013, 07:58 PM   #4466
SoilSampleDave
Oddometer: 2,062
I have a 2013 350EXC with the Euro 701 map installed and desmogged. Runs perfect, have not felt the need for a JD Tuner. Make sure your TPS is set correctly and idle is high enough if you are not happy after flashing to the 701 map.
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is online now   Reply With Quote
Old 08-29-2013, 08:10 PM   #4467
AussieClay
AussieClay's Avatar
Oddometer: 59
Mapping
I adjusted the tps on mine but was still having flameouts.
Old 08-29-2013, 08:23 PM   #4468
SoilSampleDave
Oddometer: 2,062
It does seem that every bike is a little different. My TPS was fine, but turning the idle up a little was the last little thing that it seemed to need.
'08 530EXC
Old 08-30-2013, 01:04 PM   #4469
jack82
jack82's Avatar
Oddometer: 282
Originally Posted by Hank.SD View Post
How would a 500exc compare to my first gen wr450 for single track and trail duty? My wr is plated but I'm sure the exc would go down the road better. Am also considering a 350 but geez for 9 lbs more..... I need to ride both...
Sent from my portable Altair 8800
The 500 is better everywhere.....especially in single track. I ride mainly single track and fire roads and can't fault the bike. Great stock suspension, turns well and feels light to ride. Get one.....
jack82 is offline   Reply With Quote
Old 08-31-2013, 02:50 PM   #4470
2on2off
Head'n somewhere new
2on2off's Avatar
Oddometer: 1,310
WR450 vs. 500EXC
Had a dual sported WR450 and now a 500EXC. The 500exc is better off road and on road in every way for me. The 500EXC is lighter and more powerful and much better on the pavement because of the 6 speed transmission. I can cruise all day in 6th gear on the freeway if I want. I added one tooth to the counter sprocket and that works great for me in every situation where I ride.
Jim
I came to ride...........
2on2off is offline   Reply With Quote
Times are GMT -7.   It's 09:25 PM.
