03-31-2012, 03:42 PM
#811 |
fishing with dynamite
Oddometer: 2,066
Huh. Think the 500's are a lot better looking than the '08-11 bikes, but would say the opposite about the 3.4 gallon tanks that Acerbis makes for each of those bikes.
03-31-2012, 05:14 PM
#812 |
Oddometer: 215
which loctite where?
I finally got the 14 c/s from my dealer yesterday and am going to put it on tonight. I have red and blue loctite. I have read on different threads about bikes needing the splines and the nut loctited. Of the people that have changed out the c/s did you use blue on the splines and red on the nut or none on the splines and blue in the nut? First time to change out a c/s so I just don't want to have it come off, or not be able to get it off again if I want to go to 13 or back to 15 later.
12 KTM 500EXC |
03-31-2012, 05:43 PM
#813 | |
Uses lotsa band-aids
Oddometer: 9,684
04-01-2012, 09:54 AM
#814 | |
King of all manfu
Oddometer: 2,729
I dig a more basic KTM look - what's with all the stickers? ![]() And the white tank !Do they make some black plastics?
Guns keep society safe. |
04-01-2012, 07:17 PM
#815 |
Oddometer: 215
flame out!!!!!!
So I went out to a little place today called Northwest OHV park, run by the city of Bridgeport, TX. Decent little place, some 25 or so miles of trails, some rock gardens, jumps, open areas. A lot of jeeps, few quads and only one other kid on a little 2 stroke.
So I end up in one of these rock gardens by way of a decent down hill and the bike decides to take a dirt nap. Not a hard get off. I get up, turn it off (still running) and pick it up. Won't start without throttle open some. Dies EVERY time I left off on the gas for the next 30-40 minutes. Ok past just opened, but slow down and I have to keep the clutch and revs going. I did the air injector removal last night before the trip but didn't get to the canister removal. Does this sound like the typical can flooded with fuel after dirt nap that will be resolved with desmog? I plan on doing it anyway, but damn was it frustrating to push it up a rock garden. Also, changed cs to 14 but still have the 45 rear. It was very "on/off" with the throttle response at slow speeds. Still had to use a bit of clutch. Do I need to go full bore 14/48 or 13/50 so smooth it out or will the desmog help smooth things a bit... my wife was already asking me if I meant for the front wheel to go up as much as it did?! Ummm, yea. So I can't imagine how lofty it would be with shorter gearing. I just want it a bit smoother.
12 KTM 500EXC Lulu7404 screwed with this post 04-01-2012 at 07:51 PM |
04-01-2012, 07:19 PM
#816 |
Oddometer: 215
clutch lever
On another note. After the dirt nap (right side), I was stopped for a bit and noticed the the clutch lever, when pushed out with my hand, would go all the way to the stock hand guards. I hadn't noticed this before the nap and was just wondering if everyone else's clutch lever is very easily pushed away from the grip to the hand guard... It feels like something broke, but I cannot see anything broken or loose.
Thx
12 KTM 500EXC |
04-01-2012, 07:40 PM
#817 |
Oddometer: 215
Sumo!!!
On a third note. My wife's CRF230M came with 17" wheel set up. It is a little hoot commuting to work on it, all though very small physically for me to ride. I was wondering if anyone had tried a SUMO set up on the 500 yet? The hard parts catalog has a few options. Entry to street and a bit more advanced and then a full on race version with huge rotor and 6 pot calipers etc.
I had considered just getting some distanzias in the 21/18 sizes, but changing tires is just a pain in the ass, that often. I found a link somewhere to some people using the cast tubeless rims for the CBR250R little ninja with a brake caliper relocation bracket on some ktms. The ktm parts are $$$ about $1500 and up to $2000+ I think. I just want some 17" rims... suggestions?
12 KTM 500EXC |
04-02-2012, 07:07 AM
#818 |
Hopelessly addicted
Oddometer: 368
Fuel in your smog canister from a tip over or over fueling will cause a flame out. Get rid of that thing, check your fuel filters, don't use Cheveron gas. Did you get remapped at your dealer for the XC-W mapping? You might have to sign a waiver saying that it is off road only, but it's an improvement over stock. My seat of the pants was improvement value... (SOPIV ?)
1. exaust tip screen 25% 2. desmog 75% 3. remapping 10% ______________________ Total improvement: 110%
GS 1200, 12' EXC 500 PDMC 38x |
04-02-2012, 10:20 AM
#819 | |
Hopelessly addicted
Oddometer: 368
Oil change
Just a little bit more on the oil change for reference: KTM filter vs Tusk . Minor difference in detent portion of filter. Won't change performance in any way. The KTM kit came with a crush washer and o-ring. ![]() KTM on Right, Tusk on Left ![]() ![]() Where it goes... ![]() A better shot... ![]() The owners manual said to position the bike on it's Right side, add oil to the filter housing and soak the filter prior to install. Here's what I did. "Honey, where's the ottoman for the chair?"
04-02-2012, 12:10 PM
#820 |
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 1,570
Why no Chevron ?
![]() Chevron (with Techron) is usually one of the gas brands most people recommend.
'10 Husaberg FE570 '10 BMW R1200GSA "30th anniversary edition" '08 KTM 950SE-R '08 Ducati Hypermotard 1100S |
04-02-2012, 12:39 PM
#821 |
Hopelessly addicted
Oddometer: 368
chevron
My dealer and his mechanic, who both race, are 100% against use of this fuel. I was told that they have more problems with bikes that run this brand than any other. It was one of those, "I told ya so" in advance conversations.... I don't want to start a gas war thread, but he uses ARCO or other high octane fuels and stays away from small mini-mart types. He was pretty insistant on it. I'm running a Golan filter inline and use a tank sock filter too so I'm hoping it's just a particulate issue...
04-02-2012, 12:47 PM
#822 | |
Oddometer: 16
04-02-2012, 12:59 PM
#823 |
Hopelessly addicted
Oddometer: 368
Thread index
The thread index is posted in a new thread, and up for review with GB. Once reviewed, he will place the link as a sticky in 'THUMPERS'. We can continue to post anything and everything here, but if you want me to link a good thread to the index just PM me and i'll add it.
GS 1200, 12' EXC 500 PDMC 38x heetseeker screwed with this post 04-02-2012 at 01:01 PM Reason: i'm fricken hungry |
04-02-2012, 01:32 PM
#824 |
Oddometer: 50
I have the Warp 9's on my 500 EXC. I would post a picture but just wasted 3 hours of my life trying to figure out how. I put a search in on how to post pictures as I have noted it but not read it in the past. The search page came up empty. I guess I need help. I wanted the option to switch from single track knobbies to paved road and gravel capable DS rubber. I plan on ridding the WABDR in Aug. I jumped at the price of the warp 9's but found that this kind of rubber is very limited in 17" wheels. I would recommend buying another set of KTM wheels and open yourself to a wide variety of tire choices. I have not had it out on a gravel road yet, it rains a lot in WA, but they ride well on the paved commute to work. I did have to add a rare earth magnet ( 64-1895 at radio shack) to the rotor so the speedo will work. I also reset the wheel size to 1860 so that it is more accurate. I also had to cut the white plastic fork protectors to allow for the 120/70 17 tire. So now I have a gravel friendly semi SUMO option in about an hour by swapping wheels and relocating the front caliper. I am sure I will get faster at swapping in time...Oh, also put on a 44 tooth rear sprocket. I run the very popular 14/48 as raved about on here. I have the stock 45 tooth sitting it the pile of parts I have changed, so the 44 gives me one more gearing option. So far I like it. Little geek help and I will post the pictures.
12 KTM 500 EXC 06 Kaw ZX 14 05 HD Fatboy CVO When there is a fork in the trail, take it. |
04-02-2012, 02:35 PM
#825 |
Oddometer: 50
Warp 9's
I Guess I'm not as dumb as I look I am? Figured out the pic posting. lol ![]()
