Old 05-03-2011, 01:12 AM   #16
warewolf OP
Tyre critic
warewolf's Avatar
Oddometer: 2,585
Thanks for all the suggestions. I think I'll try get the aircraft-style primer.
One of the issues with heatshrink and other wraps is thickness. Most of the WP fork 10mm bolts are in recesses that a cheaper socket is too thick to fit in. I've just bought a higher quality but thin wall 3/8" drive 10mm socket to suit my torque wrench for snugging up the forks.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 05-03-2011, 01:41 AM   #17
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,505
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 05-03-2011, 07:22 PM   #18
spafxer
spafxer's Avatar
Oddometer: 2,633
When I worked in aircraft, I wanted to identify my tools, but not put my name or any other identification on them.....
Fingernail polish worked great....... No great preparation needed, just clean and paint...
spafxer is offline   Reply With Quote
Old 05-04-2011, 01:45 AM   #19
warewolf OP
Tyre critic
warewolf's Avatar
Oddometer: 2,585
Skippii... man of few words!
Cheers,
Colin
The Stable
Old 05-04-2011, 04:22 PM   #20
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,916
hockey tape, comes in any color you want, offers dexterity to spin a socket with your fingers, when it gets filthy replace.
You can also write the size of the socket with some marker if you need.
HaChayalBoded is offline   Reply With Quote
Old 05-04-2011, 04:44 PM   #21
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,009
Originally Posted by mgdavis View Post
This is the same thing I do. Red for metric, blue for SAE. Try to avoid the shit with glitter in it.
I have virtually NO SAE tools in my box. These days I never need them!
For color, you really need to prep the surface first, and use an appropriate paint.
Jim
PS ALL of my tools are engraved with JVB on them.
Old 05-04-2011, 09:05 PM   #22
Human Ills
Useful Idiom
Human Ills's Avatar
Oddometer: 23,951
I would have never thought of fingernail polish. I'm going to try that out.
Human Ills is offline   Reply With Quote
Old 05-05-2011, 07:44 AM   #23
the_gr8t_waldo
Oddometer: 2,114
something that works, is to use a dremel tool to cut notches/letter in a part of the tool that won't compromise the strength...then paint the snot outa it. if you use tools (as in earning a living with 'em) most of the paint will chip off..but the notch/letter will retain paint for a lifetime.
the_gr8t_waldo is offline   Reply With Quote
Old 05-07-2011, 02:23 PM   #24
omeier
omeier's Avatar
Oddometer: 365
This is a similar problem for climbers. We often pool our gear, carabiners, pickets etc. As some suggest, finger nail polish works well, and withstands rock scrapes etc surprisingly well. The other solution is a wrap of electrical tape, comes in all colors and stands up decently well too. Some stores with climbing gear sell like tape strips to mark your gear as well, but in this case its just really expensive electrical tape...
omeier is offline   Reply With Quote
Old 05-08-2011, 01:30 AM   #25
warewolf OP
Tyre critic
warewolf's Avatar
Oddometer: 2,585
Yeah I've used modeller's paints to mark my caving gear (again, just what I had handy), but then I changed to white 'leccy tape as it is more visible. Doesn't last though.
Cheers,
Colin
The Stable
Old 06-23-2011, 06:58 PM   #26
mgdavis
Oddometer: 365
Stopped by Lowe's today to pick up a hex bit socket and saw that they're rolling out a refresh of their socket line that copies my red/blue marking strategy. They screwed up though, they accidentally made red SAE and blue metric - aren't they going to be embarrassed when they realize they got the colors switched.
K7 DL650 w/ AltRider bars & skid, Caribou hardbags, corrected speedo face, custom scratches.
'96 DR350SE
mgdavis is offline   Reply With Quote
Old 06-23-2011, 07:46 PM   #27
squish
Out of the office.
Oddometer: 6,267
My pop worked in a windtunnel, his tools all used reflective tape
This did two things, one marked the tools as his, what ever tape he used stuck
And he could flash a light down the test section of the tunnel and in a second know if anything got left behind.
This same strategy works really well to be able to find that dropped 8mm wrench on the ground, in the dark, in the glow of your headlamp.
On vacation for a spell
squish is offline   Reply With Quote
Old 06-23-2011, 09:01 PM   #28
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,618
Perfect excuse to buy a cheap hobby powder gun.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 06-24-2011, 10:20 AM   #29
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,012
I paint all my MM tools red. Have done this since Chevy starting using both SAE and MM fasteners on their trucks. I just clean the chrome with acetone and spray with Rustolium Industrial spray paint. It last long enough, some will always be stuck on the tools somewhere so I can tell them apart. and I keep a can of the stuff around when repaint is needed.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 12-06-2012, 12:12 AM   #30
warewolf OP
Tyre critic
warewolf's Avatar
Oddometer: 2,585
Checking in!
Originally Posted by Flashmo View Post
You would be surprised how long spray paint will stick to sockets (it does not stay pretty, but lasts).
After what, 18 months or so, I can say that my initial crude clean 'n' paint has done well. Lasted so well I've not even thought about re-painting, and I'd completely forgotten about chasing some primer
All the 8s, 13s and 27s are orange, and the 10s are white. I should paint the 12s something else, as I seem to use those for lots of non-bike jobs for some reason.
Cheers,
Colin
The Stable
Times are GMT -7.   It's 03:04 AM.
