Old 04-30-2011, 06:55 AM   #1
rumblefish OP
xxx
Oddometer: 68
Replacing damaged intake snorkel - advice?
Hi guys, I have to replace one of the black intake snorkels on my F800Gs that was vandalized (the black external plastic part that sits around the "tank"). How do I go about removing the body panels in that area? Is it as simple as just removing the bolts around the tank, or is there some trick I don't know about?
Thanks in advance.
rumblefish is offline   Reply With Quote
Old 04-30-2011, 10:02 AM   #2
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,735
Sucks that it got vandalized...
Start by removing the whole panel, it is easy. There are tons of little snaps and stuff inside so it would be hard to remove without the whole panel.
1. Remove seat.
2. Remove Center Trim (colored trim over battery).
3. Take off lots of screws... see below.
4. Reverse.
I took a picture of the inside of one of my old panels (had an argument with a tree...). You can see lots of snaps and screw holes that are holding the black intake runner onto the panel. Some of the screws may be missing from my old panel.
Good luck!
EnderTheX is offline   Reply With Quote
Old 04-30-2011, 10:17 AM   #3
rumblefish OP
xxx
Oddometer: 68
Thank you so much! That's so helpful. It was more complicated than I figured - I'm glad I asked on here first.
Where did you find those diagrams? Is there a workshop PDF or a site online for these kind of things? I just downloaded the BMW workshop DVD only to find it doesn't run on a mac.
Lucky you were around.
Thanks again!
Old 04-30-2011, 10:42 AM   #4
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,735
Thanks again!
Not too bad, the snaps are surprising though when you get in there.
I bought the BMW repair manual DVD...
Old 04-30-2011, 12:29 PM   #5
rumblefish OP
xxx
Oddometer: 68
Those snap things are a bugger! And a couple are held on with toothed washers (don't know the technical name). Doesn't look like BMW wants you to do DIY repairs.
Did it eventually though. Thanks again for all your help. I'll have to find a way to view that DVD through my mac somehow - it's handy...
Times are GMT -7.   It's 04:08 PM.
