05-01-2011, 12:09 PM
#16 | |
Fast and Far
Oddometer: 6,882
+1 Used to stress me out and freak friends out who would say that my bottom end was fried....but now I just live with it and keep riding, that was thirty thousand km's ago.
www.GravelTravel.ca Canadas Source For Overland Routes Tales From The Bivouac Rally Print Publications TCAT Trans Canadian Adventure Trail 15, 000 km GPS route across Canada |
05-01-2011, 12:32 PM
#17 |
Oddometer: 166
You guys almost have me convinced and judging by those on this thread there seems to be plenty of expert opinion, however mine just suddenly started making noise and didn't have any for the past month....at all. Ok, so the start up noise from the cct is normal, point taken. What about clatter after its warm and ridden for awhile? My most accurate description of yhe sound would be a "vibrating coil spring sound ". This is a constant sound that was not noticable before and developed after the start up racket. Again every opinion is appreciated. 33
05-01-2011, 12:37 PM
#18 | |
incognito
Oddometer: 16,374
The LC8 sounds like a bucket of bolts at idle. Cam chain noise can come and go, hot or cold, it's not always consistent. |
05-01-2011, 01:14 PM
#19 | |
ow, my balls!
Oddometer: 4,624
Now I just put in earplugs and ride.
Riding the Americas: No Fumar Español - Terminado. ![]() _____________________________________________ |
05-01-2011, 01:32 PM
#20 |
more north, more wet
Oddometer: 3,678
It's the cam chains, my bike does the exact same thing and I had the same reaction at first...
I think there was a TSB on it, and some people had luck getting it "fixed" at dealers and others didn't
2006 KTM 950 Adventure "The pen & sword, in accord." "It's never over in a Rover." |
05-01-2011, 01:41 PM
#21 |
Exactly bro you are right, that´s how KTM 990-950 sounds.... and like you said, as long as it goes away in a few seconds other wise you should check oil level or pressure or the hydraulic cam chain tensioners.
Once you ride Off road you will never want to go on road again ![]() ![]() ![]() ![]() Alejo From Costa Rica Centro America |
05-01-2011, 03:23 PM
#22 |
Urban Adventurer
Oddometer: 610
I've noticed that using a 5w50 weight oil significantly reduced my start up clatter.
05-01-2011, 04:23 PM
#23 |
Oddometer: 166
Update.
Let run for 5 minutes and sit for 5 minutes. Checked oil again. Oil is half between max and min. Oil is light btown and very foamy. Waterpump seals? Would this make oil viscosity so thin, thus explaining the clatter? Hmm.... |
05-01-2011, 04:43 PM
#24 |
Lefty tighty.
Oddometer: 6,413
If the main filter is damaged by coolant, this can cause improper oil flow, marginal oil pressure, and associated camchain noise. I assume you're oil pressure warning light is unlit, but you cannot always trust the idiot light for marginal pressure. It's quick to check the main filter and inside of outer clutch cover for evidence of coolant ingress. As I said, camchain noise is a symptom of marginal pressure (among other things, including the hydraulic operation of the CCT), so you may have a marginal pressure issue if you are getting consistent noise.
05-01-2011, 08:03 PM
#25 |
Orange Caveman
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,101
OBL is dead
If the filter is clogged enough to restrict flow, it will be obvious on visual inspection.
![]() -cp DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt. |
05-02-2011, 10:29 AM
#26 |
All Terrorist Must Die!
Oddometer: 153
I'm glad I found this thread
, 5th and 6th do not like anything under 4K rpms .
A word to the wise ain't necessary - it's the stupid ones that need the advice 2010 BMW R1200GS Adventure 2002 KLR 650 Green/Black "Number 2" She's mighty farkled up 2006 KTM 950 Adventure "Sold" 2008 KLR 650 "Sold" |
05-02-2011, 10:49 AM
#27 |
Ride that nasty thing
Oddometer: 1,436
Yeah, always a rattle can
"04" 950 Adventure S 34,000+ miles Smokin Hole Rally 1,2,3,4,5,6...upcoming 7 Cromag 05, 08. "The Grim Brothers" Where's my 690 rally replica |
