Old 05-02-2011, 06:31 AM   #1
rallyelc4 OP
rallyelc4's Avatar
Oddometer: 143
KTM lc4 cranks
Hi guys whats the diference between the round crankwebs (eg2004) and the 05+ ones with the cutouts?
While i've got you can you use the black cylinder(02) with the gray bottom end and highflow head?
Cheers guys
2004 KTM 640lc4 enduro/rallye cam/FCRRGV rims
came with a sxc comp pipe
rallyelc4 is offline   Reply With Quote
Old 05-02-2011, 09:05 AM   #2
bmwktmbill
Traveler
Oddometer: 5,040
Rally,
You must like mysteries,
I have asked the same question to myself and on the forum and still don't know the answer?
To your question I will add, Who makes the valves and seats for the LC4 cylinder heads?
They are too expensive from KTM!!!
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 05-02-2011 at 10:27 PM
bmwktmbill is online now   Reply With Quote
Old 05-02-2011, 11:23 AM   #3
Tseta
Lost
Tseta's Avatar
Oddometer: 669
The newer crank, with the cutouts, has superceeded the older, full circle crank for "all" LC4 applications.
-T
Tseta is offline   Reply With Quote
Old 05-03-2011, 02:09 AM   #4
rallyelc4 OP
rallyelc4's Avatar
Oddometer: 143
Originally Posted by bmwktmbill View Post
Rally,
bill
I have read somewere that kibble and white has something for us
http://www.advrider.com/forums/showt...=632893&page=5
ha here and it was you
I am keen on some valves anyone else? ,,,You??
Old 05-03-2011, 02:21 AM   #5
rallyelc4 OP
rallyelc4's Avatar
Oddometer: 143
-T
T
thanks mate you have a fair few beers lineing up here in oz when you get here
so are the newer ones better? why did they s/s??
btw i did check the online fiche but not good enough
SOOOOOO,,,,,,,
I've got a carrelo rod on its way and have the 04 round crank
what are my options guys?? what would you do
Old 05-03-2011, 03:02 AM   #6
LukasM
Oddometer: 5,384
Originally Posted by rallyelc4 View Post
T
SOOOOOO,,,,,,,
If you want to keep the bike for a long time and can afford it, I would have the crank lightened a bit and then get it balanced along with the counter balancer to get rid of the vibration the old LC4s are known for. There are three people I know will do good work, GWR in Belgium, Thumper Racing and Cut7 Engineering in the US.
By the way, you know that the Carillo rod comes without bearings and the pin, right?
Here is a KTM stroker crank I had done by GWR. Standard full circle:
After lightening, welding, balancing:
LukasM screwed with this post 05-03-2011 at 03:11 AM
Old 05-03-2011, 07:06 AM   #7
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,694
My gosh, that is freaking art right there!
RB Designs out of Portland Oregon has treated me well in the past, I'm sure they could do that work as well. http://www.rb-designs.com/
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is offline   Reply With Quote
Old 05-03-2011, 07:35 AM   #8
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,117
holy crap, Astro. What sort of scratch did that cost? Did the motor smooth out as well as you had hoped? Must have really helped the beast spin up quickly with that much mass gone.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 05-03-2011, 11:20 AM   #9
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,368
were did you get the stroked arm? i emailed carrillo and they said they only made stock, 78mm.
i spoke to Cut7 a few days ago about my engine and all the things he could do. the big one was blancing and lightening the crank. that and a little head work and it's a whole new monster. not cheap though......
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 05-03-2011, 11:33 AM   #10
rallyelc4 OP
rallyelc4's Avatar
Oddometer: 143
my ones 78mm
Old 05-03-2011, 11:59 AM   #11
LukasM
Oddometer: 5,384
In case that was not clear, my crank is a factory SXS stroker (78mm) for an RFS engine and not an LC4.
If anybody is interested in crank work, you should probably contact GWR (Glenn Woodman in Belgium) yourself to get a quote, but it was much more reasonable than I thought and cheaper than all the other options. His email is woodie (at) skynet (dot) be
GW-Racing Parts (Grosswächter Racing in Germany, not to be confused with the above ) has a stroker pin kit for the LC4 according to their website. I have had a similar kit from them in a SX crank, very nice item. It uses a normal length rod and shorter piston to get the increased stroke. They sell to dealers only I believe, but GWR can get them for you.
CT-KTMLC4-strokeConrod-KitKTM LC4 Conrodkit with eccentric Pin and silver bearing for longstroke342,86
Old 05-03-2011, 12:18 PM   #12
4runner
4runner's Avatar
Oddometer: 203
My '00 crank was not hardened and when pressed back together would not hold true, had to replace it with a new style crank, which is hardened, So, old crank, kinda sketchy on rebuild, new crank, good to go.
'00 LC4E
The rarest Hodaka in the WORLD
RF900
'73 TX650
4runner is offline   Reply With Quote
Old 05-03-2011, 02:52 PM   #13
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,420
Interesting that the GW-Racing conrod has the single oil drain groove per side on the big end like the old LC4 rod, new version KTM ones have 3, you can see the top 2 in this pic, the other one is at the bottom:
Unless I decide to buy/make the equipment to press together a crank myself, next time I do a rod I'll probably get a whole new crank/rod assembly. That should be 90K km away for the 640 though
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 06-06-2012, 05:33 AM   #14
bittervrug
bittervrug's Avatar
Oddometer: 1
Laugh links
hi im from south africa and have bee a member on this forum for a while now. i have a question that may seem funny, i need links to online shops for a rebui;d on a lc4 adventure, im a bit slow when it comes to this sort of shopping as we dont really do it in africa, please help me with links to cool online shops for shopping the parts i need to do a compolete rebuild on this great bike!!
bittervrug is offline   Reply With Quote
Old 12-06-2014, 09:06 PM   #15
NevBlu
Oddometer: 65
ProX connecting rod with crank rebuild
Hope my freshly rebuilt round style crank will be ok. Picture for a 1000 words.
Next step is a counter balance modification to lower the vibration. This hopefully will allow me to keep and enjoy the 2001 LC4 640E for next 10 years. Its a keeper.
Thumper Racing rebuilt this crank and did all the valves and guides too. www.ThumperRacing.Net
2003 BMW R1150 RTP, 2001 KTM LC4 640, 1991 ATK 605, 1968 BSA B50SS
Ride with Wings of Passion
NevBlu is offline   Reply With Quote
Times are GMT -7.   It's 08:15 PM.
