Old 05-02-2011, 02:51 PM   #1
Sir Not Appearing OP
That's no ordinary rabbit
Sir Not Appearing's Avatar
Oddometer: 1,111
Need help plugging a tire
The rear tire on Daytona had a slow air leak and I finally found the problem last night after looking at the tire a dozen times. There was what appeared to be half of a staple (construction type, not desk) through the tire.
I guess my issue is that I have a plug kit, but the plug tool is probably 15-20 times larger in diameter than the staple I pulled out. Should I really ream it out that large?
I know the correct answer is to buy a new tire, but that's not going to happen at least this week and I want to plug it temporarily.
1998 Triumph Daytona
1991 EX500
2007 Suzuki S50
Sir Not Appearing is offline   Reply With Quote
Old 05-02-2011, 02:58 PM   #2
T
stay classy
T's Avatar
Oddometer: 5,325
You'll never get that plug/tire thread in there if you don't "ream" it out. Just fixed one like this two days ago. The staple was in a tread block in the middle of the tire. So far after two hundred miles everything is good.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 05-02-2011, 03:00 PM   #3
sieg
sieg's Avatar
Oddometer: 2,812
Hell yeah ream it out!
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 05-02-2011, 03:20 PM   #4
Oddometer: 1,111
OK, sounds good. Going to try it tonight or tomorrow. I just felt odd putting an even bigger hole in something that holds air. I
1991 EX500
2007 Suzuki S50
Old 05-02-2011, 05:11 PM   #5
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,506
I would just put a patch on the inside rather than ream out that tiny hole.
Basically, I'd rate the solutions as follows, though they probably will all work as well as a new tire:
Correct: New Tire
Cheap: remove tire, and patch from inside
Cheap and Lazy: Snotstring plug
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 05-02-2011, 05:39 PM   #6
shu
Oddometer: 999
I've had very good results with the brown, gummy worm plugs. Run the reamer through once or twice- don't go crazy with it. Use some glue to lube the hole and the string and stick the string in. I cut it off about 1/8 inch above the tire: this forms a 'mushroom' on the outside of the tire that bonds to the tire with the heat of running. It should bond well inside the tire as well, and be good as long as the tire lasts.
The worst thing that can happen is you'll get another slow leak there but in my experience (3 tires) these plugs hold fine. Check your air regularly and ride.
...........shu
shu is offline   Reply With Quote
Old 05-02-2011, 09:03 PM   #7
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,576
Ream it out, put cement on the string plug, put the plug in, fill with air, ride it.
Flashmo is offline   Reply With Quote
Old 05-04-2011, 09:03 AM   #8
ST-DocLizard1
Serial Monogamist
ST-DocLizard1's Avatar
Oddometer: 837
Originally Posted by flashmo View Post
ream it out, put cement on the string plug, put the plug in, fill with air, ride it.
+1
ST-DocLizard1 is offline   Reply With Quote
Old 05-05-2011, 08:53 PM   #9
Cheap Weenie
Oddometer: 19
Ream the crap out of it and use a mushroom plug.
Cheap Weenie is offline   Reply With Quote
Old 05-05-2011, 09:01 PM   #10
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,236
http://www.jimvonbaden.com/Tire_Plugging.html
Jim
JimVonBaden is online now   Reply With Quote
Times are GMT -7.   It's 11:47 PM.
