Go Back   ADVrider > Riding > Regional forums > Australia > OZ Vendors
Old 05-03-2011, 06:40 AM   #1
Aquatic OP
Aquatic's Avatar
Oddometer: 1,587
Uniden UH076/78 Lockable Radio Mount
At the request of a fellow inmate I designed and made a mount for his Uniden radio. To be a viable project I made extra.
I have received more than enough interest from other inmates that the extras have been sold and I will now be manufacturing more units in my spare time.
- The rear mounting holes are M5 in a standard 'AMPS' configuration(As used by RAM and Techmounts)
There are 2 Ram Mounts that have the same AMPS hole pattern:
RAM-B-347U - http://www.ram-mount.com/CatalogResu...5/Default.aspx
RAM-B-202 - http://www.rammount.com/CatalogResul...0/Default.aspx
- The unit is made from black Acetyl plastic and stainless steel, so no corrosion or earthing problems
- The pin on the back of the radio slides into the slot and is held in place with a spring loaded hook. Once mounted, it can be locked into place with a 2mm allen key or a T8 torx driver. So no need to remove the radio, for fear of theft, when you stop at your favourite watering hole/coffee shop. Also no chance of it vibrating loose even on the roughest corrugated dirt roads
- Here is a album of some mounting examples - http://s932.photobucket.com/albums/a...uaticDawg/UHF/
password - uniden
- A BMW F650GS with custom dash mount - http://advrider.com/forums/showpost....&postcount=102
- Other compatible radios that will fit are:
Uniden UH073sx, UH075, UH076sx & UH078sx
Uniden VHF marine handhelds Atlantis 250, Atlantis 260 & Voyager
- The mount is compact enough and allows for the use of the 12V clip on charger
The mounts go for $98.00 each
Plus $12 postage.(Up to 8 in a bag. If they are all going to the same place I will only charge once for postage)
Total for 1 = $110.00
Total for 2 = $208.00
Total for 3 = $306.00, etc.
Or pick up Buddina, Sunshine Coast to save on postage.
Kindly send a PM, email or call should you require a mount. craigkrantz@gmail.com - 04 three 4 three 75 325
Feel free to discuss the mount here. All feedback, good and bad, will be appreciated
Please take note: Uniden have recently changed the design of the location pin on the radio.
Have a look at the photo below. The left pin is the old style and the right is the new style. You can see the chamfer that has been added(tip of the pen)
The new style has interference when sliding into the mount. The chamfers are varying sizes so some fit tightly and others don’t go in at all.
If you have the new style pin I will send you an old style pin that you can swop out on you radio. Please just let me know when you place your order.
Aquatic screwed with this post 12-03-2013 at 09:26 PM Reason: Postage
Aquatic is offline   Reply With Quote
Old 05-05-2011, 05:21 AM   #2
Aquatic OP
Aquatic's Avatar
Oddometer: 1,587
It works on other models too
Discontinued models that will also work on the mount are Uniden UH073sx, UH075, UH076sx & UH078sx.
The Uniden VHF marine handhelds Atlantis 250, Atlantis 260 & Voyager also use the same set up.
Old 05-07-2011, 03:39 AM   #3
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,731
Is this the ram mount to suit?
Might be worth a group buy to keep shipping cost per unit to a reasonable level as part cost is only about AU$6
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John is offline   Reply With Quote
Old 05-07-2011, 06:24 AM   #4
Aquatic OP
Aquatic's Avatar
Oddometer: 1,587
It's perfect!!!
I've been looking for the perfect ram mount and found this
http://www.ram-mount.com/CatalogResu...0/Default.aspx
M5 x 16 stainless capscrews will work perfectly with that ram mount.
M5 x 20 would be just too long, but could work with a little bit of shortening
Aquatic screwed with this post 05-13-2011 at 06:17 AM Reason: Fixed Link
Old 05-07-2011, 03:43 PM   #5
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
Linky she no work
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C is offline   Reply With Quote
Old 05-13-2011, 03:15 AM   #6
Sleepy John
Grumpy Adventurer
Oddometer: 3,731
My wife just found the zippy bag with the radio mount in the centre console.
Maybe not such a good idea to write the price on it.
Just saying...
Sleepy John
Old 05-13-2011, 06:13 AM   #7
Aquatic OP
Aquatic's Avatar
Oddometer: 1,587
Eek Oooops Sorry Mate
Totally unintentional.
Tell your Mrs that that is $98 Zimbabwe
Just saying...
Old 05-13-2011, 06:17 AM   #8
Aquatic OP
Aquatic's Avatar
Oddometer: 1,587
Originally Posted by Mike.C View Post
Linky she no work
Fixed Boss
Old 05-13-2011, 01:37 PM   #9
Sleepy John
Grumpy Adventurer
Oddometer: 3,731
I told het it was a life saving device.
Anyway I bought tea last night so all is well again.
Sleepy John
Old 05-13-2011, 03:59 PM   #10
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
And with the radio
Cheers, Mike
Old 05-19-2011, 06:21 AM   #11
Aquatic OP
Aquatic's Avatar
Oddometer: 1,587
The next batch is a go
The material arrived today for the next batch of mounts(30)
The plans is to put in some time on Sunday.
Watch this space
Old 06-06-2011, 10:00 PM   #12
griffo1962
griffo1962's Avatar
Oddometer: 1,498
mount locking screw
Hey Craig, what are the dimensions of the locking screw please? Mine has "gone west" and I want to buy another tomorrow before I leave on my trip.
cheers
g
griffo1962 is offline   Reply With Quote
Old 06-07-2011, 05:41 AM   #13
Aquatic OP
Aquatic's Avatar
Oddometer: 1,587
Stainless M3 x 12 - thread length is 12mm
2 choices
M3 x 12 socket head capscrew - uses a 2.5mm allen key
M3 x 12 Button head capscrew - uses a 2mm allen key
What happened? If I may ask? An error on your part or did it vibrate out?
Otherwise how is it working for you?
cheers
g
Old 06-07-2011, 05:58 AM   #14
griffo1962
griffo1962's Avatar
Oddometer: 1,498
2 choices
Cool, thanks for that.
I went to screw it up yesterday and it wasn't there. It as the first time so it must have just vibrated out in the last couple of weeks.
cheers....
Old 06-07-2011, 06:57 AM   #15
Aquatic OP
Aquatic's Avatar
Oddometer: 1,587
I will look into preventing that from happening in the future
cheers....
Times are GMT -7.   It's 06:24 PM.
