Old 01-25-2013, 07:25 AM   #271
villageidiot
Oddometer: 1,827
Originally Posted by disston View Post
Where did you get the idea that Tink was ever going to be finished with this? He started over a year and a half ago.
He's getting close. And I see it in his eyes at the vintage bike meet every month.
villageidiot is offline   Reply With Quote
Old 01-25-2013, 07:41 AM   #272
TINK OP
Oddometer: 730
The day is coming when I too shall be an AIRHEAD rider
Ya, eyes glass over every time I look at an airhead ... and I droll a little too
TINK
TINK is offline   Reply With Quote
Old 01-25-2013, 08:21 AM   #273
groop
So much to ponder
groop's Avatar
Oddometer: 3,287
Originally Posted by TINK View Post
Center stand has been repaired and installed!
Let's rewind... here's the center stand with "dragging" damage.
If you ever need a fabricator and are in the Orange County area check out Jim Shirley. He does great work and is very reasonable
Now back to our show,,, Jim's hand work
TINK
Tink, I've got my centerstand off now and doing some welding/repair work and I'm thinking of doing the flat bar stock arm that your welder did. I like the look. Now that you have the pipes and kick stand back on, have you noticed any issues with clearance?
Because you cannot eat a salad with a spork.
groop is offline   Reply With Quote
Old 01-25-2013, 09:15 AM   #274
TINK OP
Oddometer: 730
Center Stand Tab Loacation
The only caveat is that I removed the original BMW side stand and I'm only using the aftermarket Brown side stand. The tab "could" interfear with a BMW side stand, I did not check for this clearance on mine.
Looking at this old photo when I still had the BMW side stand on the bike I would have to say the new tab location I chose would most likely interfear with an OEM BMW side stand.
better photo, with text...
TINK
TINK screwed with this post 01-26-2013 at 12:23 AM
Old 01-25-2013, 12:34 PM   #275
Kai Ju
Kai Ju's Avatar
Oddometer: 1,890
Tink, that's not a BMW sidestand in that picture.
Kai Ju is offline   Reply With Quote
Old 01-25-2013, 01:58 PM   #276
TINK OP
Oddometer: 730
What you see...
I know, it's not a good shot, but, I was looking at the BMW side stand foot that is just showing itself below the muffler directly under the heal shifter, not the Brown side stand that the bike is sitting on. If you look closely inboard of that you can see the centerstand crosstube that I welded my flat tab to.
TINK
Old 01-25-2013, 02:13 PM   #277
groop
So much to ponder
groop's Avatar
Oddometer: 3,287
Thanks Tink! I'll keep that in mind.
Old 01-25-2013, 03:54 PM   #278
Kai Ju
Kai Ju's Avatar
Oddometer: 1,890
TINK
I (side)stand corrected
Old 01-25-2013, 04:09 PM   #279
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,661
It really does look like it's getting close, Tink.
---Albert Einstein
disston is online now   Reply With Quote
Old 01-26-2013, 12:05 AM   #280
TINK OP
Oddometer: 730
Eh? Fender Bug
My solution to the question; how do you protect the newly painted front fender during storage and transport... make it into a BUG ;-)
Rubber washers to protect the paint.
Add some old socks and it's back to the rafters for now.
TINK
Old 01-26-2013, 07:57 PM   #281
TINK OP
Oddometer: 730
Wicked It's alive!
Fired up PROJECT-S today!
First there was something in the float needle (old fuel hose I suspect) that held the needle open and allowed gas to stream out onto the ground.
Fixed that; then with full choke I thumbed the starter... she spun but no fire. Turned the choke off, added a little throttle to clear her out, thumbed the starter, Voila, SHE'S ALIVE!!!
Set the throttle stop to high idle and after a minute she settled into a nice idle.
What! GEN light (green) is on!? Put the volt meter on the battery, 12.8v at idle, 14.2 at 3500 RPM. She's charging... will figure that out later.
Pipes turned a nice shade of blue... Some smoke from the cleaners I had used... All in all she's happy to be alive once again.
Miller Time!
Almost there...
TINK
Old 01-27-2013, 12:59 AM   #282
Kai Ju
Kai Ju's Avatar
Oddometer: 1,890
Tink, GEN light is red, OIL is Yellow, NEUTRAL is Green, at least on my '77
Put it in gear and see if your GEN light goes out
Old 01-27-2013, 08:23 AM   #283
TINK OP
Oddometer: 730
D'oh! You are correct, green light is NEUTRAL... silly me, another senior moment .
As you can see, the paint on the lettering has faded (photo actually makes it look better than in real life) and I've not yet memorized the colors.
Old 01-27-2013, 11:07 AM   #284
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,680
I like the brake failure light. That would be really handy on a long stretch of road. On a steep and curvy down-hill section, not so much
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 01-27-2013, 01:25 PM   #285
regomodo
Oddometer: 185
100 years from now when I take the controls off the handle bars I'll know to look for the wedge as it falls onto the ground.
TINK
Originally Posted by melville View Post
Duane's not quite right on that one--my 1975 /6 does not take a perch wedge, and I understand later models may only need a wedge on one side. Make sure both perches have room for the wedge--this one does not:
What the hell is the wedge for? I remember it lying around on my bench after a disassemble thinking "where the hell did this come from?"
Just by coincidence I found it at the bottom of a box earlier today whist looking for a missing centrestand bushing (i don't use the stand but might build a "paddock stand" type thing) and again wondering what the hell it was for.
regomodo is offline   Reply With Quote
Times are GMT -7.   It's 10:02 PM.
