Old 01-01-2014, 12:29 AM   #1756
ROKIT_71
Gone Orange
Oddometer: 225
Originally Posted by Deadly99 View Post
I'm in the same boat. Ordered an hdb setup (thanks Paul ) but haven't pulled the trigger on lights yet. The BD ones seem excessive for me as I rarely ride at night.
If you find an alternative I'd been keen to know
Ted I used the Baja lights on my bike and yes they a great. But lots $$$$$
My team mate used these which fitted in fine to the HDB tower and a 1/4 of the price and there light output is good enough.
http://www.ebay.com.au/itm/2-x-CREE-...item3a889e7c35
If you look at Paul's homepage I'm bike 77 with the Baja's and Damian is 46 with the Cree lights.
http://www.highwaydirtbikes.com/HDB_...aberg_Team.jpg
From what Damian told me the were a little bit to skinny but some spacers sorted that out easy enough.
Cheers Ben.
ROKIT_71 is offline   Reply With Quote
Old 01-01-2014, 09:05 AM   #1757
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,917
Perfect, thanks
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 01-01-2014, 09:45 PM   #1758
geoz
Orange rules
geoz's Avatar
Oddometer: 238
I used a set of projectors, that was a lot cheaper too but also gives me a proper dipped beam. Not sure if you have to pass some sort of MOT compatibility test but I wanted to be compliant just in case.
I think I posted a picture on the HDB thread in the vendor section.
http://www.advrider.com/forums/showt...php?p=21137796
cheers hg
cheers
hg
geoz screwed with this post 01-01-2014 at 09:57 PM
geoz is offline   Reply With Quote
Old 01-01-2014, 11:38 PM   #1759
Freakingreen
Freakingreen's Avatar
Oddometer: 27
handle bars
Originally Posted by theantipaul View Post
For the frame mounts the main ones are 3/8", then the ones that bolt to the RB mount are 1/4".
The triple mounts are 1/4" and have no problem holding all the weight of lights and nav gear.
Slightly off the office tower subject but what handle bars do you have mounted up with that top clamp system? They look sweet.
Freakingreen is offline   Reply With Quote
Old 01-02-2014, 01:27 AM   #1760
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,712
Are you talking about the Flexx Handlebars?
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 01-02-2014, 01:51 AM   #1761
rmhrc628
rmhrc628's Avatar
Oddometer: 2,570
Maybe unrelated but where can you get the rallye type bar ends like in Dakar?
rmhrc628 is offline   Reply With Quote
Old 01-02-2014, 02:08 AM   #1762
640 Armageddon
-oo-
Oddometer: 2,712
Talking about sth like that
http://www.twistedthrottle.com/barkb...ar-end-weights
or that?
http://www.vibranator.com/dirt_bikes_s/22.htm
If it is to reduce vibrations, HDB makes a hodden one with so far the best results from what I have tested.
D.
Old 01-02-2014, 02:17 AM   #1763
rmhrc628
rmhrc628's Avatar
Oddometer: 2,570
or that?
D.
Old 01-02-2014, 06:11 AM   #1764
Freakingreen
Oddometer: 27
Sorry I should of clarified. The top picture, the handle bars with the square mounting shaft and the flat bar style cross brace. What brand are those and where do you find them?
Old 01-02-2014, 06:14 AM   #1765
640 Armageddon
-oo-
Oddometer: 2,712
They are called Flexx Handlebars
Can find them here
http://www.fasstco.com/shop/flexx-handlebars-mx
D.
Old 01-02-2014, 12:17 PM   #1766
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,168
Originally Posted by StepOnIt View Post
As I see in you pictures of the farting with two iPhones ( very nice setup BTW) it looks like you have quite a lot of room up front. Could you go to a tablet and gps vs iPhone? The price of tablets are way less an much bigger for older guys with bad eye sight lol. I know that iPhone app is not on google play yet. Or even go to an iPad cost about the same as an iPhone? There is a tablet out there that does road book navigation via PDF files. Thinking of an all in one device up there lol.
Great work wish I had the money for stuff.
Here's an iPad mini I was testing an RB app on, ran it for a while. Did a great job of moving out of the way when I went down.
This has cellular and standalone GPS which was needed for the app, don't know if most tablets out there have that.
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 01-02-2014, 12:32 PM   #1767
theantipaul
Oddometer: 1,168
Get out for a few days and you guys get busy!
Cheers Ben.
Hey Ben
Yes to all that, the BD Squadrons are pricey, but IMHO the best, if you're not riding much at night, then overkill. We'll be making an adapter for ADVMontser style lights that would be much cheaper solution for those not doing much night work.
Can find them here
D.
Dimitri is right on that, and I love my Flexx bars, but will be switching back to the standard style guards, those proto's transferred too much impact force to those pricey bars.
Old 01-02-2014, 12:34 PM   #1768
theantipaul
Oddometer: 1,168
cheers hg
HG, how tough was it to get those light adapted?
Old 01-02-2014, 02:52 PM   #1769
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,025
Gps
As for the GPS Garmin makes a blue tooth one that should adapt to almost and tablet that has blue tooth. So it does not even need to be plugged In or close.
As for the lights I have the advmoster ones. The rear heat sink unscrews where the bracket is. I cut a price of aluminum bigger then the light. Then used a hole saw the size of the heat sink. Drilled 4 holes in the corners of the aluminum and then used thick wall gas line as spacers to hold it off the faring. It is hard to explain and is kinda a hack job but works lol. Should be able to do something like that with your setup. I have an old trail tech X2 light that I used for it, tool out the old lights.
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 01-04-2014, 09:56 PM   #1770
geoz
Orange rules
geoz's Avatar
Oddometer: 238
Very simple, actually they fit pretty well.
cheers hg
cheers
hg
Times are GMT -7.   It's 09:02 PM.
