Old 01-06-2014, 05:13 AM   #1771
Franklin
Enjoy the mud....
Oddometer: 4
Hella Projector lights
Originally Posted by geoz View Post
Very simple, actually they fit pretty well.
cheers hg
I used two Hella Projector lights, same as on the KTM 690 RR, best light I've ever had on a bike! The lights came with a paper mould to make your own bracket. My tower and navigation bracket are old school, steel bracket welded to the frame en the navigation tower is made of 4mm aluminium.
Franklin is offline   Reply With Quote
Old 01-06-2014, 12:36 PM   #1772
toro618
toro618's Avatar
Oddometer: 949
Handle bar width
What bar width do most of you have with a full rally control(s) setup? My 350 exc came with a 32" bar, but I cut it down to 31" for single track riding I do.
toro618 screwed with this post 01-07-2014 at 06:56 AM
toro618 is offline   Reply With Quote
Old 01-06-2014, 08:06 PM   #1773
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by Franklin View Post
I used two Hella Projector lights, same as on the KTM 690 RR, best light I've ever had on a bike! The lights came with a paper mould to make your own bracket. ...
Hello
Could you please confirm the part number of those Hella lights ???
Regards ..
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 01-06-2014, 08:23 PM   #1774
emmodg
emmodg's Avatar
Oddometer: 131
Are these the Hella Lamps?
http://www.rallylights.com/hella-60mm-projector-headlamp-module.html
I don't know that I could run them - 65watt...
Nuova Strada
2000 R1150GS
2007 KTM 450 EXC
2003 KTM 525 EXC (SOLD)
2008 KTM 690 Enduro (SOLD)
emmodg is offline   Reply With Quote
Old 01-06-2014, 08:50 PM   #1775
mrwwwhite
mrwwwhite's Avatar
Oddometer: 401
Originally Posted by Gros Buck View Post
Hello
Regards ..
Paul Jr
60mm Module Low Beam Lamp998570001
60mm Module High Beam Lamp998570021
60mm Module High Beam Lamp with Position Lamp998570031
These are the typical Hellas used on the KTM 690/450 RFR.
I have the 90mm (almost the same) version on my 690R with Linx fairing. The power output is superb and can be upgraded to xenon for more substantial dough. Otherwise they are quite cheap for the quality.
I plan to test in my future project the cheap Chinese xenon projector that the eBay is full of and report back.
mrwwwhite is offline   Reply With Quote
Old 01-07-2014, 02:09 AM   #1776
Franklin
Enjoy the mud....
Oddometer: 4
Hella 60mm projector light module
[QUOTE=emmodg;23154028]Are these the Hella Lamps?
These are the ones I've used on my bike! They were used on the Aprilia Factory Rally bike as well. Bear in mind that the low beam and high beam modules have very different shape, the brackets are therefore not the same. The units are also a bit heavy and quite large too. And at 65 Watts each, I haven't tried to power them both at the same time..
Old 01-08-2014, 07:03 PM   #1777
Gros Buck
Gros Buck's Avatar
Oddometer: 847
Thanks. Confirmed what I had in mind.
I am more 90 mm then 60 ... I know Hellas are comming with LED 90 mm can't wait to see real ones ...
Paul Jr
KTM690r 2011
Old 01-08-2014, 09:46 PM   #1778
mrwwwhite
mrwwwhite's Avatar
Oddometer: 401
Paul Jr
Cheers, the LED looks awesome but at 500E per piece it will take ages till the price will drop and 1000E to kit a bike with lights is KTM Factory Team territory not privateers or amateurs.
Old 01-09-2014, 11:15 AM   #1779
Muecke
Muecke's Avatar
Oddometer: 69
can make some more fotos of your bike? also with the cockpit front.
Muecke is offline   Reply With Quote
Old 01-09-2014, 01:06 PM   #1780
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,086
Paul Jr
The 90mm hella LED have been out for retail for a while
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 01-09-2014, 09:10 PM   #1781
Baja Dad
Baja Dad's Avatar
Oddometer: 1,908
how do I hook up a garmin 60csx to a ertf repeaters
I am trying to set a Honda 450 x rally bike up for a Buddy to ride the Jimmy Lewis Nav school in 10 days
his bike was raced in Dakar back in 2010
2014 support: GPR,IMS Aurora Rally Kriega, Raiden LS2,100Goggles,SIDI,Seat Concepts, Rally Raid Products UK,Precision Concepts, MX1West,Dunlop
Baja Dad screwed with this post 01-09-2014 at 10:40 PM
Baja Dad is offline   Reply With Quote
Old 01-09-2014, 09:28 PM   #1782
DaveRMS
DaveRMS's Avatar
Oddometer: 1,090
his bike was racer in Dakar back in 2010
Tony @ RNS can make you a cable/adapter.
Dave
DaveRMS is offline   Reply With Quote
Old 01-09-2014, 10:39 PM   #1783
Baja Dad
Baja Dad's Avatar
Oddometer: 1,908
Dave
Thanks Dave
I sent him a pm!!!!
Old 01-09-2014, 11:43 PM   #1784
Mudguts
Mudguts's Avatar
Oddometer: 2,086
Paul Jr
Try
http://www.giantlight.com.tw
Old 01-10-2014, 05:34 AM   #1785
Linusp3
Linusp3's Avatar
Oddometer: 175
Ho there.
I'm thinking of rebuilding the front of my -06 BMW Dakar... I have been riding a few roadbook rallies using a hand driven roadbook holder and would like to expand the activity.
During this off season I'm changing the OEM front forks and triples to a set from a Yamaha YZ426F, and it would be nice pushing it a bit furher. The original dash are showing signs of giving in and I have got a Trailtech Vapor as replacement instrument. I came across a MD roadbook holder and ICO at a fairly good price.
Now my (main) question are; will the original frame mount be able to hold the weight of a nav-tower? The weight of the original dash, lights etcetera are just below 4kilos (8,8lb US). Keep in mind the bike will not run any desert or hard enduro stretches but mostly gravel roads and trails. It needs to be street lethal.
The Rookie :)
Linusp3 is offline   Reply With Quote
Times are GMT -7.   It's 05:19 AM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
