Old 02-14-2014, 07:07 AM   #1891
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,846
Good point on that Dave. Indeed, thread lock will attack the nylock. I remember that nylocks are to be used only for one application. i.e. no screw-unscrew a trillion times, since the plastic is permanently deformed once it enters a thread. You can actually tell the difference between a used one and a fresh one by the difficulty it enters the bolt. I am not replacing every single time, but if it the damage from a loose nut is big, every single time I put a fresh one....
If in doubt, safety wire everything. It would be difficult on the inside but hey, you have to be thorough when proposing solutions eh?
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 02-14-2014, 07:47 AM   #1892
Baja Dad
Baja Dad's Avatar
Oddometer: 2,041
I Like this !!!
where can I get one ????
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-14-2014, 09:09 AM   #1893
drc42
Rally Dreamer
drc42's Avatar
Oddometer: 1,853
I agree that welding probably has an advantages. But I am certainly glad that JMo didn't weld hers on since the JVO kit from her bike is now sitting in my garage
I didn't know the bit about loctite + nylock. Lots of good info in this thread.
follow my journey: Dreaming of Dakar
drc42 is offline   Reply With Quote
Old 02-15-2014, 01:57 AM   #1894
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,441
Jenny Morgan likes this!
Jx
JMo (& piglet) is online now   Reply With Quote
Old 02-15-2014, 08:40 AM   #1895
Mike_MRS
Oddometer: 409
We've found no need for welding (and have had some epic crashes )
a radiused mild steel block inside the headstock a bit like the one Gany posted (slightly simpler design than that though), drilled and tapped to M8, and on the outside, a shaped ally block with countersinks in the front. Dab of Loctite 243, bolt in, job done. We've found no loosening, no vibration issues, nothing, just a rock solid tree. If at some future point it was to loosen for any reason, the bolts can come out of the front with no dramas, or tightened easily. No need to remove anything.
Nylocks on the side plate bolts, no issues there either. The back block needs to be different depths and shapes depending on the bike for clearance reasons though.
Moto Rally Services UK
Mike_MRS is offline   Reply With Quote
Old 02-15-2014, 05:22 PM   #1896
wrk2surf OP
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,950
man i love this thread !
wrk2surf is offline   Reply With Quote
Old 02-16-2014, 01:16 PM   #1897
Hagenblad
Hagenblad's Avatar
Oddometer: 87
VERY much like my design. I crash-tested it in Marocco 2010 and it works great.
http://www.raiddesigns.com/en/produc...mrsfb5551.html
http://www.raiddesigns.com/en/produc...-services/mrs/
Hagenblad screwed with this post 02-16-2014 at 01:56 PM
Hagenblad is offline   Reply With Quote
Old 02-16-2014, 02:03 PM   #1898
Mike_MRS
Oddometer: 409
Hagen, your block looks like ally but is tapped? You find the threads to be strong enough? We chose steel for the backing block
Can I ask why 5 taps in the side of the block? They look like m6?
Old 02-16-2014, 02:21 PM   #1899
Hagenblad
Hagenblad's Avatar
Oddometer: 87
Yes, It can brake by bike flipped upside down on my rb holder.
The MRS isa module system, you use the holes you need. I used the lower 3 for a HID bracket.
Old 02-16-2014, 02:24 PM   #1900
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
I have one of the MRS blocks here, the thread is re inforced with a steel insert
cu
Stefan
KTM Lc4 660 Rally MY98 pre e-start; KTM EXC450 MY14 Torque Rally Conversion; KTM EXC450 MY04 HDB Rally Light; Honda XRV750 RD04 MY91 AfricaTwin -for Sale-
Happe is offline   Reply With Quote
Old 02-16-2014, 02:31 PM   #1901
Hagenblad
Hagenblad's Avatar
Oddometer: 87
cu
Stefan
Oh, sorry. Yes T6-aluminium with stainless steel threads (glued).
And yes 30 mm m6 straight through thread on the outer block.
Old 02-16-2014, 04:13 PM   #1902
rmhrc628
rmhrc628's Avatar
Oddometer: 2,670
I have a dumb question. What's the touratech part in the circle attached:
rmhrc628 is offline   Reply With Quote
Old 02-16-2014, 04:25 PM   #1903
Mike_MRS
Oddometer: 409
Ah ok, makes sense
Rm, it's the bracket for an ertf gps
Old 02-16-2014, 06:38 PM   #1904
wrk2surf OP
wrk2surf's Avatar
Oddometer: 6,950
Ah ok, makes sense
also the one they use at the Dakar and other FIM races
Old 02-17-2014, 06:55 AM   #1905
MakS
MakS's Avatar
Oddometer: 88
Front low fender
our fresh product
MakS is offline   Reply With Quote
Times are GMT -7.   It's 03:56 PM.
