Old 03-12-2012, 10:53 AM   #256
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,710
Originally Posted by RuckedUp View Post
I just received my F2R roadbook in the mail today direct from Portugal.
I have a few questions on power options. The directions says to wire into a switched line. I was wondering if this unit could be wired into a fuse block I just ordered that is unswitched?
Mine is unswitched; I just have to remember to unplug it if left overnight, but even then, the led backlights take barely any juice.
Remember that it has to be wired to the DC side.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 03-12-2012, 11:32 AM   #257
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Ok, thanks for the info. I'll start looking at the bikes wire diagram. I would like to have it switched since I know I'll forget to unplug even if I had a neon sign plugged in reminding me!
My SPOT tracker link: SPOT
14' KTM 690R
13' R1200GS "Wasser Baby"
10' KTM 450EXC
84' Honda 500VT Ascot
RuckedUp is offline   Reply With Quote
Old 03-14-2012, 08:29 AM   #258
Karl772
Rally Nut
Karl772's Avatar
Oddometer: 26
@theantipaul regarding the frame bracket which you machined from billet for the navigation tower. Am i able to but one exactly like and/or would you be able to custom build one to my specific needs and measurements?
If so what would a rough price be?
Cheers
Karl772 is offline   Reply With Quote
Old 03-14-2012, 12:17 PM   #259
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,119
Cheers
Hi Karl, sending a PM
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 03-19-2012, 04:29 PM   #260
Gregg Wannabe
Just killing time
Gregg Wannabe's Avatar
Oddometer: 2,378
Originally Posted by theantipaul View Post
I'm still working on a frame mounted fairing/light/roadbook version and will throw it out there for comments and criticisms, but I have a busy day today, need to go out and play with this and the roadbook switches and motor driver.
Paul- Interested in seeing what you come up with for a frame mounted version.
btw- I bought handguards, mirror, switches and bar clamp from you last year for my Husaberg entry in the Baja 500. For those you you that have not seen Paul's stuff you are missing out. It is well designed and built!
Gregg Wannabe is offline   Reply With Quote
Old 03-20-2012, 11:38 AM   #261
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Road Book Prep
I got my brackets in the mail today from RMS. Here are a few photos of the moc up. I just wanted to slap it on and have a look at it.
Side View
Front
I was wondering if the cables look ok or will I have to pull them down and zip tie them off so they dont flex into the back of the F2R. I still ned to figure out where I'm going to mount the IOC as I'm not sure if the road book bracket will show up in time. I was thinking of using heavy duty velcro and just stick it on the top of the F2R for a quick mounting option.
And with the F2R stuck on the cross bar.
If anyone sees something I'm missing our should make sure of please give me a shout out.
14' KTM 690R
10' KTM 450EXC
Old 03-20-2012, 11:45 AM   #262
lastplace
lastplace's Avatar
Oddometer: 891
The ICO or odometer really should be above the left side of the roadbook. Just above the mile/kilometer note on the roadbook. Velcro won't work to stick the ICO to the top of the roadbook, but here are some instructions on a cheap method that has worked on thousands of miles of rally routes for us:
http://www.rallymanagementservices.c...oadbook-reader
A new F2R roadbook option, designed more for racing, is coming soon. The older version will still be available. I'll post in Vendors. We almost always have lots of navigation stuff in stock.
fun fun
Charlie
lastplace is offline   Reply With Quote
Old 03-20-2012, 11:58 AM   #263
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
I'm in it
Ill start the install in the morning. I'm down to 30 days till I roll out to Greece.
14' KTM 690R
10' KTM 450EXC
Old 03-20-2012, 12:05 PM   #264
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,866
Looking good.
On the break cable routing. We cut off the outer sleeve and use these pipe clamps to secure to the triple.
c.vestal is offline   Reply With Quote
Old 03-20-2012, 12:44 PM   #265
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Originally Posted by c.vestal View Post
Looking good.
That's more wrenching than my weak ass tool box can handle. Do you think I will have a problem with the cables where they are run now? It's the Evia rally in Greece and it looked to be a lot of dirt track trail.
14' KTM 690R
10' KTM 450EXC
Old 03-20-2012, 12:50 PM   #266
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
Is there no way of routing them in front of the X2 headlight?
TALES FROM THE BIVOUAC
TWOONEZERO
Brodovitch is offline   Reply With Quote
Old 03-20-2012, 12:54 PM   #267
lastplace
lastplace's Avatar
Oddometer: 891
When your front forks are compressed, your brake line, in the normal routing, will come up and possibly get caught on your navigation equipment, causing all kinds of interesting troubles. Take a good look at it. If there is any chance of the brake line getting caught, an easy short-term solution is to take some beefy zip-ties and cinch the brake line to the bottom triple clamp (with the forks fully extended, wheel off the ground). Often the hard outer coating on the brake line down there is flexible enough to let the brake line bow out below the triple. But this is not an ideal solution. The best way is to strip the hard coating and to run the brake line down the right fork, across the bottom triple, and then to the wheel, like Chris said. This way it will bow out and hopefully not get caught up in the wheel. Use the p-clamps like in Chris's photo.
Old 03-20-2012, 12:59 PM   #268
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Good deal
Ill head down to the hardware store and see if I can find some clamps. I'll have a better look at it in the morning. Thanks for all the input.
14' KTM 690R
10' KTM 450EXC
Old 03-20-2012, 01:26 PM   #269
nfranco
over macho grande?
nfranco's Avatar
Oddometer: 769
Charlie,
Do you know if the new F2r roadbook will fit the existing Crux Studio bracket you sell ?
Thank you.
Edit: never mind, I saw on your website it does.
nfranco screwed with this post 03-20-2012 at 03:12 PM
nfranco is offline   Reply With Quote
Old 03-21-2012, 11:55 AM   #270
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
F2r pwr up
Just checking to make sure the F2R works. I'm still on the hunt for some pipe clamps to route the brake cables over the triple.
14' KTM 690R
10' KTM 450EXC
Times are GMT -7.   It's 08:16 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
