05-06-2012, 06:26 PM
#406 |
Allergic to Asphalt!
Oddometer: 5,987
or a dab of silicone.
Good tip. Thanks.
05-06-2012, 06:33 PM
#407 | |
(formerly GSNorCal)
Oddometer: 833
Dave
Rally Management Services is the source for Dakar-proven rally parts, bike builds, assistance, and training. Rally Navigator - Roadbook Navigation powered by Google Earth. Create. Print. Share. |
05-06-2012, 07:19 PM
#408 |
Reforming Neandertal
Oddometer: 862
So I've been playing around with a few different ideas with the help of Crankshaft and Pilo, here's the next iteration, the roadbook mount can rotate in the event of a crash if tightened just right, but I plan on an adjustable turn buckle kicker for mine. The side plates bolt onto a plate sandwiched between the upper triple and the lower handlebar clamp that cantilevers out front, on the rider side there is a subplate that the damper mounts to that is adjustable. On KTM's this stackup mounts with all 4 M10 bolts in the upper triple making it pretty strong. The lower mount goes to the 2 M6 threaded holes in the lower triple.
![]() ![]() With 2 Baja Designs Squadrons, these have 4 Cree XML LED's pull only 44watts and are very bright. ![]() ![]() The second Squadron comes into use with the removal of 4 small screws that hold the bezel of the headlight mask, then reattach the stock bezel, will be refining that. The headlight mask can mount on either the top or bottom Squadron. Trying to keep a street legal looking setup to keep the scrutiny down. ![]() ![]() Night time veiw of the Squadrons. They are very nice! ![]() Only been able to take it out a few times after work and have yet to do a long ride with it, but so far I haven't noticed any strange handling from it, and for the time being I have the brake and speedo lines ziptied to the handguards as there doesn't appear to be anything for them to hang up on except branches and bushes. I'd like to find a 3-3.5" HID that has a good focus to replace the lower Squadron for better throw, might end up trying to make one. The next version w/frame mount, if I can stop dicking with the rest of it. ![]() ![]() Let me know what you think and as always be brutal. |
05-06-2012, 08:16 PM
#409 |
Beard Bros Racing
Oddometer: 10,158
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8"If you french fry when you shoulda pizza'd,your gona have a bad time".
05-06-2012, 11:35 PM
#410 |
Armature speller
Oddometer: 6,769
05-07-2012, 12:15 AM
#411 | |
Team f5ool
Oddometer: 13,992
![]() Two suggestions/questions. 1. include some form of bracket so that an ICO/rally trip can be fitted above the road book - if this bracket is laterally adjustable enable to move and fix the tripmeter so that it's display can be alingned with the printed distance column on the roadbook (some roadbook formats have this in slightly different places) then that would be ultimate! 2. is it posible to mount this unit to a headstock mount; off the frame steering head tube (similar/same as the Raid Designs mount) - in order to get the weight off the steering/bars (not that this set up looks overly heavy). With these two adaptations, I would think that this would be an ideal (optimum) "Rallye Lite" set up for navigation/roadbook rallies, where a "full" Dakar set-up is not required. Lean mean fighting machine! Nice job!
Quote: Originally Posted by zenjen "It's one of those nuts and uncles deals..." ![]() |
05-07-2012, 04:41 AM
#412 | |
Rally Dreamer
Oddometer: 1,580
My trusty roll of duct tape came to the rescue and held it together for the rest of the race.
follow my journey: Dreaming of Dakar Special thanks to my sponsors: Freedom Cycle of Concord NH BRP Renazco Racing MX1West Help support my racing addiction and look cool doing it! Buy a T-shirt or hat from the Dakar Dream Store |
05-07-2012, 08:44 AM
#413 |
Oddometer: 5,987
Looks great Paul.
What are the two additional holes in the Squadron mask seen here: ![]() Looks lamost like you made room for 2 of the 4 additional Squadron LEDs to shine through.
05-07-2012, 09:05 AM
#414 |
Guns are for pussies
Oddometer: 13,783
Try the watchdog Doug, very rugged.
Just say'IN |
05-07-2012, 09:08 AM
#415 |
Oddometer: 13,783
Looks great Paul!
Just say'IN |
05-07-2012, 09:17 AM
#416 |
Rally Dreamer
Oddometer: 1,580
I have one on my enduro bike, hate the buttons. Otherwise it is fine.
05-07-2012, 09:41 AM
#417 |
Oddometer: 862
You left before it was done Aaron, so is it close to what we were talking about?
05-07-2012, 09:49 AM
#418 | ||
Oddometer: 862
![]() ![]() Sort of a cage for the roadbook, the added weight would be offset by smaller displays. Still working it, hope to move them closer once I get the electronics. ![]() On the frame mount, the Raid setup looks like it works with SE's, but that clamp setup wouldn't work with most smaller bikes I know of, no room to clamp. I'm more of a fan of welding to the frame, then bolting right now. Is this the one you meant?
05-07-2012, 09:57 AM
#419 | |
Oddometer: 862
All this still needs quite a bit of refinement and I getting buried with work, so that's backburner stuff. |
05-07-2012, 09:59 AM
#420 |
Safari Scramble!!!!!
Oddometer: 3,194
I'll think on this a bit but it looks like a good idea to me...helps strengthen the roadbook mounting bracket and provides clean mounts for the computer mounts.
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
