05-10-2012, 02:07 PM
#436 |
Oddometer: 1,214
rally navigation experiance event in 6 weeks hosted by Dakar stage winner Jonah Street
Where can I get info on this??????????????????????
Thanks for the 2013 support:GPR Stablizers,Seat Concepts,Kriega.us, Precision Concepts, Acerbis, AME Grips,Rally Raid UK TLD, Klim,Oakley, Sidi-Motonation, Dunlop,ZLT Three Brothers Racing KTM,Multitool FOREST PLYWOOD SALES |
05-10-2012, 06:26 PM
#437 | |
Allergic to Asphalt!
Oddometer: 5,996
Seems like I always hear about this stuff after the fact or just too late to get organized. We need a Rally Roadbook Event Calendar
05-10-2012, 08:56 PM
#438 | |
Armature speller
Oddometer: 6,777
05-11-2012, 06:07 AM
#439 |
Team ⌘R
Oddometer: 3,161
Just a quick tip on where to reinforce the stock KTM navi bracket, which I find to be perfect for a Rally Lite setup.
You need to weld extra material to (A): in my case, square stainless steel rod of 4cm length and 5mm thickness, and (B) add a bit of material to the little cutoffs that remain after they machine the whole thing at the factory... they are notorious for starting little cracks there, which from vibration will ultimately snap the two front supports off the tower, and get you into deep trouble Thought I'd share this today as I picked up a friend's tower from the local welder, hope it helps. They aren't the prettiest looking welds, but they get the job done ![]()
05-11-2012, 12:27 PM
#440 | |
Safari Scramble!!!!!
Oddometer: 3,199
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE Seth S screwed with this post 05-11-2012 at 12:34 PM |
05-11-2012, 01:35 PM
#441 | |
Rally On
Oddometer: 4,583
x2 on all that below.
I lost power to the F2R before during a past roadbook ride. The F2R knobs make it real easy to just take your left hand and slide up both knobs and advance the roadbook real fast. (and safe) Quote:
05-11-2012, 01:40 PM
#442 |
Rally On
Oddometer: 4,583
Paul,
I really like the direction you are heading with this one. On thing that sticks out relates to my recent post on the F2R. Your bracket around it will not allow for easy manual rotation of the knobs. I feel it is important to be able to easily rotate them if something comes up. Again, did not skip a beat when I lost power to the F2R in a roadbook ride once. Just took my left hand and slid it over the top of the 2 knobs. Real fast and safe. |
05-14-2012, 12:43 PM
#443 | |
Oddometer: 3,199
now be sure to test it with 100mm width paper
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
05-14-2012, 02:16 PM
#444 |
Scott Whitney
Oddometer: 2,230
You mean the standard 6" (150mm) roadbook size right? Ya, the internal belt system gets in the way.
05-16-2012, 08:59 AM
#445 | |
Oddometer: 3,199
yes, that is what I meant...just check my australian road book...was thinking it looked smaller than 6"
05-16-2012, 12:30 PM
#446 |
Oddometer: 5,996
Here is my new weekend racer set-up
Scored a used TT RB holder on ebay, got the regular DS version of the ICO and used a HDPE cutting-board as the base. ![]() Used two steel brackets mounted to the hand-guard mounts to support the RB holder. With the BRP dog bones there is no way to use a handlbar mounted system like the one Rally Management Services provides. ![]() ![]() ![]() ![]() ![]() Lexan rally fairing mock up ![]() Finished Lexan rally fairing. ![]() The whole setup is on/off in 20 minutes
05-16-2012, 02:32 PM
#447 |
Oddometer: 869
Looks really nice, YP! Shows that you don't need to spend much to put together a workable setup. A few comments: Most people like the roadbook further forward and pointing more upward so that it is easier to read while standing. The ICO DS can't read in KM like the VRL can. fun fun Charlie |
05-16-2012, 05:39 PM
#448 |
Oddometer: 5,996
Thanks for the pointers Charlie.
I can easily adjust the angle by bending the brackets, just need to do a test ride to figure out the optimal angle. Yes the ICO DS only does miles, but it's 1/2+ less than the VR Rallye. When I end up doing an actual rally I'll fork out for the Km version. When you guys do your training runs are the RBs set up in Km or Miles or both? Thanks, Dan
05-16-2012, 05:47 PM
#449 |
BITD/Rallye
Oddometer: 5,311
the ktm stock ODO that was used in 03 pn 58314069300 I used in the Mex 1 K has two trip meters, the trip 2 is adjustable and has MI and Km capability.. it also has a clock, av speeds, lap timers, max speeds and if a certain wire is cut can countdown as well...
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
05-16-2012, 05:58 PM
#450 | |
(formerly GSNorCal)
Oddometer: 833
HogWild's fancy roadbook-a-majig can print any route in either format. Dave
Rally Management Services is the source for Dakar-proven rally parts, bike builds, assistance, and training. Rally Navigator - Roadbook Navigation powered by Google Earth. Create. Print. Share. |
