Old 06-20-2012, 06:15 AM   #541
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,003
Originally Posted by Maineroot View Post
Nate and I did the Mexican 1000 with no roadbook or GPS. We used an app on his iPhone.
We are trying to see if the folks who made the app would be willing to let us test the software on an iPad mounted to the bike. It can't be any worse that how we did it last time!
I'd think since the unit is solid state, the only problems you would have would be protecting the unit, and powering it.
Thoughts?
USB to cigarette lighter adapter to the iPad, then wire in a cigarette receptacle off the battery. A quick run of electrical tape over the plugs to keep them together and you're good.
Just say'IN
crankshaft is offline   Reply With Quote
Old 06-20-2012, 07:54 AM   #542
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,067
All of this is awesome!
Now if I could just pull google satelite maps in quantity into the iPad for offline usage... I'd be making a roadbook every week. . I do have the accuterra maps but I find much better stuff with google earth...
I need to remember to add any lock combinations for locks I pick along the way in the tulips
Sent from iPhone using Tapatalk
Old 06-20-2012, 07:59 AM   #543
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,067
Just opened accuterra for the first time in forever... Turns out they've 'beensold' (yeah right) and now you have to subscribe to the data but no worries you get one year free.
Old 06-20-2012, 08:40 AM   #544
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,067
Will that roadbook creation app work on iPhone? Sure more fiddely usage wise but also much more Dirtbike friendly??
Old 06-20-2012, 09:14 AM   #545
wilkinsonk
soup de grimace
Oddometer: 842
MotionX has an ap for the iPhone/iPad that allows you to cache maps to your device so that you do not need a data connection.
http://gps.motionx.com/ipad/overview/
- Ken
wilkinsonk is offline   Reply With Quote
Old 06-20-2012, 09:17 AM   #546
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,067
Thanks Ken
I have motion X but unfortunately I don't need "maps".. I really need satelite data. Usually the trails we ride/explore in the mountains are not considered roads so map software doesn't have a clue. Hence why satellite imagery is so useful out here
For example: one of my favorite areas:
speaking of which... PFB... perhaps when we do our annual ride up there this summer we should roadbook record a route?
Geek screwed with this post 06-20-2012 at 09:33 AM
Old 06-20-2012, 09:26 AM   #547
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,685
Originally Posted by crankshaft View Post
Any words of wisdom on creating the RB and tips on using the software?
I think you'll find it takes a lot longer than you expect. Stopping for a couple of minutes at each waypoint to write the notes and select or draw a tulip means you won't get very far before the whole day is past. And that doesn't take into account all the planning needed ahead of time to figure out a good route. There's tons of talk here about cool tools, but not much actual use of them. I've tried a lot of different things to make the task easier. Most seem like great ideas until they are put to use. The real test is when the tool or technique is actually used in the real environment for a full stage or two. The next test is when you have to go back and insert a waypoint or make a change to a existing route. The fun factor can slip away pretty quickly!
BTW, there's a new rally roadbook creation tool under development by RenoMoto that takes a completely different approach than what we've seen here. If he gets it working, I think many will find it the tool of choice.
New desert racing frontiers
It will be Devilish !
HogWild is online now   Reply With Quote
Old 06-20-2012, 09:30 AM   #548
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,750
More info ?
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 06-20-2012, 09:30 AM   #549
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,147
Hey Aaron, the nice thing about the cigarette socket is you can get just about any adapter for it, but if you just need a USB I got this from an inmate here,
http://www.burnsmoto.com
It's a clean and easy install.
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 06-20-2012, 11:12 AM   #550
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,223
This.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 06-20-2012, 11:17 AM   #551
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,223
This
Old 06-20-2012, 11:37 AM   #552
crankshaft
crankshaft's Avatar
Oddometer: 14,003
I found a nice roadbook how to article on a rover site that I'll share when I get home from work. I've made many roll charts for rides, so I know it's a process.
It's a process I enjoy thankfully
I downloaded a few iPhone roadbook apps but nothing worked very well.
The app for the iPad looks like the simple and cheap option that some of you are already using.
Another thought I had was to create a nation wide D/S route in a roadbook format. There are certainly enough people on this forum spread all over to make it happen. Maybe Ghandi should have considered unity through Roadbook creation
Just say'IN
Old 06-20-2012, 01:26 PM   #553
crankshaft
crankshaft's Avatar
Oddometer: 14,003
Originally Posted by beechum1 View Post
This.
Thx Paul, that is much less ghetto than my solution!
Just say'IN
Old 06-20-2012, 01:37 PM   #554
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,067
ok.. so bit of a "eureka!" moment when I realized all those holes in the top of the tree would fit RAM balls
(at least until we all get off our arses and create a boatload of roadbooks so its worth while leaving the roadbook on the bike all the time... )
So yes.. I'm a bit of a ram whore
I have arms of different lenghts and holders for various devices
...so a few of these balls with bolts
First I tried one in the middle
with a short arm (I need to find a shorter bolt to make it look cleaner)
with a medium arm
Then.. I added a second ball (we talked about using two arms with the Ipad mount
With a long arm on the iphone holder
...or a short arm on the iphone
Here's my largest RAM mount (happens to be for a magellan gps - its about half the size of an iPad mount)
Magellan and spot...
So the options are pretty much endless - carrying an iPad should not really be an issue (make sure you have insurance ).
All of this would be protected by the rally fairing when Paul gets it done.
As for power:
If you have a powerlet on your bike, you can get a "powerlet to iphone" cable like the one I use on my 950.
or just mount up one of these weather proof USB ports that Paul posted a link to above and use a standard USB cable.
I hope my brain storming out loud helps someone
cheers,
Ed
Old 06-20-2012, 01:57 PM   #555
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,067
Looking forward to seeing it
Times are GMT -7.   It's 04:22 PM.
