Old 05-24-2013, 02:32 PM   #1471
michael1968
michael1968's Avatar
Oddometer: 833
Originally Posted by Gany View Post
Thanks for the responses! I just need to find an economical way of reproducing the housings. Anyone know what type of plastic is ideal for this application? The prototypes are CNC ABS plastic, however Im concerned that ABS will break too easily on impact. Any other plastics preferred to ABS? If I go the casting route instead of CNC, what about epoxy vs polyurethane?
Hey Gany,
We use cast polyurethane for guards etc at work (mining oem) quite a bit. It's extremely tough but not hugely stiff. The stiffness might me fine for this application, we use it in sheets of about 1m square.
The switch block looks great by the way, I might have to line some up with you for the beemer.
Cheers,
Michael
michael1968 is offline   Reply With Quote
Old 05-26-2013, 08:03 AM   #1472
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Does anyone know where to get the metal gears to upgrade the plastic gears in the TouraTech Roadbook Holder?
Yellow Pig is online now   Reply With Quote
Old 05-26-2013, 09:06 AM   #1473
cross-country
cross-country's Avatar
Oddometer: 1,679
I have a set, PM me your address.
cross-country is offline   Reply With Quote
Old 05-27-2013, 02:36 AM   #1474
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,823
Hi Gany,
Nice switch,
There are some PU which may be suitable for this application but you should play with hardness to make sure the material withstands the hits. If you go plastic, take into account the flexibility of such materials, they can have a serious effect when in service/crashing etc...
High impact thermoplastics are good but the injection mold is not cheap ...
Keep up the good work,
D.
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 05-27-2013, 03:54 AM   #1475
SafariBerg
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,063
Originally Posted by Happe View Post
I took Dave's version as inspiration and mounted the second pickup at the brake caliper bracket.
We ran dual ICO's like this for 7 years and around 170,000 rally km all up, only failure was the occasional cable snagged up near by the fender by bushes, but that's why we ran x 2 sensor units & cables
never a single magnet issue, a blob of silicone on the back circlip always kept them in place
2013 Husaberg FE501
2014 Arctic Cat Wildcat Z1 1100T Rallye
SafariBerg is offline   Reply With Quote
Old 06-06-2013, 01:30 PM   #1476
Muecke
Muecke's Avatar
Oddometer: 75
After a few month of waiting yesterday I got my groundplate for Touratech roadbook, IMO and Garmin Quest III (but now Montana).
Special thanks to 640 Armageddon for his great job. 640 Armageddon made a great job with the CAD-programm. Without him I saw no chance to get such a strong groundplate.
Now my metal worker made me a good plate and I just checked if everthiny fits and hope getting to install it at the weekend on my BMW G450RR.
Let's show some fotossss...
Muecke is online now   Reply With Quote
Old 06-06-2013, 04:39 PM   #1477
watagans300exc
watagans300exc's Avatar
Oddometer: 114
Wow!!!
That ground plate is awesome.
Say, 640 Armageddon, are you planning on selling those?? If so, how much??
Cheers,
watagans300exc is offline   Reply With Quote
Old 06-07-2013, 12:50 PM   #1478
640 Armageddon
-oo-
Oddometer: 2,823
Nice one Sven, glad it worked out ok,
Get the details that I e-mail you sorted and then it will be rock solid
Originally Posted by watagans300exc View Post
Wow!!!
Cheers,
Actually no. Not yet at least
A website will be online mid June? sth like that. In which we will have an announcement that will change the way people navigate with roadbooks .
Tower plates will be present to this website, and we will see if we can keep up by doing customised jobs such as Sven's with details from customers. It is a long shot, so we have to see how it goes...
Follow the vendors forum and I will update everything as soon as the news are online...
D.
Old 06-08-2013, 03:09 PM   #1479
Muecke
Muecke's Avatar
Oddometer: 75
My metal-producer said that it was not as easy as we expected. He needed to modify the files in order read it in his machine. So it was a little bit more work for him. He uses a 3mm aluminum in very good quality. The problem is that my metal-producer has good and big machines to produce but 4mm or more is very rar to produce in his job.
I know that the welds are only on points but in the moment it seams so strong and if it is not working I know the address to tune it up. :)
Tonight I have just painted it with clear finish (paint) because the plate was glass bead blasting before. Now it has a nice look.
If somebody want to buy such a plate. No problem. Contact me. I can produce them. But it is not very cheap and trust me I do not want to earn money with it.
Old 06-08-2013, 04:25 PM   #1480
DaveRMS
DaveRMS's Avatar
Oddometer: 1,194
Most roadbook prints have the distance on the left and the notes/cap headings on the right. Is there a reason why this plate has the IMO on the right and the GPS on the left? Seems reversed from common placement.
Just curious...
Dave
DaveRMS is offline   Reply With Quote
Old 06-09-2013, 04:19 AM   #1481
Muecke
Muecke's Avatar
Oddometer: 75
Just curious...
Dave
It just the history way... :) I always had the IMO on the right.
Old 06-10-2013, 04:38 AM   #1482
MakS
MakS's Avatar
Oddometer: 84
tower
Navigation Tower for CRF 450 X.
MakS is offline   Reply With Quote
Old 06-10-2013, 06:56 AM   #1483
DaveRMS
DaveRMS's Avatar
Oddometer: 1,194
Mak,
I'm looking for some replacement lights like those. Where did you get them? My sources are coming up dry.
Honestly, I'll probably just switch to LED, but these are the original ones.
Thanks,
Dave
Old 06-10-2013, 10:39 AM   #1484
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Mak,
Thanks,
Dave
I've got a VisionX hookup...
PM or email me.
Sent from my Galaxy Nexus
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 06-10-2013, 12:46 PM   #1485
LukasM
Oddometer: 5,426
Mak,
Thanks,
Dave
Hey Dave,
You can get those Triom lights from any KTM dealer, as they were used on a couple of bikes including the first 660 Rallys.
Part number is 58414001000, list price is around $150 but you can find them for $118 here:
http://www.cheapcycleparts.com/products/746433
Cheers,
Lukas
Times are GMT -7.   It's 01:11 PM.
