Old 05-04-2011, 03:25 PM   #1
Westy99 OP
Oddometer: 221
TT 20mm Riser Install
I'm installing a set of TT 20mm risers today. For those that have done it...do you really have to take all the side panels and the beak off?
One other thing I want to verify is that bolts on the handle bar clamps are E10's correct?
Westy99 is offline   Reply With Quote
Old 05-04-2011, 03:45 PM   #2
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Nope. I installed these and there is no need whatsoever to take off the side panels.
I followed the TT directions with the exception of removing plastics.
Not sure on the bolts, but E10 sounds right.
Old 05-04-2011, 03:52 PM   #3
kaiden
Oddometer: 62
What? I guess is am a typical guy because I don't remember that part! I just put them on by looking at the photo. I owned a set on my last 800 and had no issues...
Anyone who takes off all that stuff needs to be smacked...
2015 BMW 1200GSA.....I want to die in my sleep like my grandfather. Not screaming and yelling like the passengers in his car..
kaiden is offline   Reply With Quote
Old 05-04-2011, 04:02 PM   #4
Westy99 OP
Oddometer: 221
I figured it was a simple straight forward install and then I looked at the directions...
By the looks of it I figured you could do it without the removal of all that shit.
Old 05-04-2011, 04:14 PM   #5
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,737
Its a piece of cake, Westy! Don't take off a thing. The back up nut (underneath) is a 17mm wrench size....or at least that's what mine is.
Either use a socket, or better yet, a small (shorty) combo wrench....i.e. open end/closed end. The shorty fits in there great and you'll have plenty of room to hold it with your hand, while you do the hard work from the topside with a socket wrench. I bought my shortys from Sears with a ratchet in the closed end. But, they are probably available at most hardware or tool stores.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 05-04-2011, 05:47 PM   #6
DonHS
Oddometer: 82
OK. Smack me. Noob just following directions. It's all a learning process for me.
DonHS is offline   Reply With Quote
Old 05-04-2011, 06:03 PM   #7
ebrabaek
Oddometer: 4,760
I would grease the bolts....before installing them........
http://advrider.com/forums/showthread.php?t=582776
Erling
Old 05-04-2011, 07:16 PM   #8
Ron Wardman
Beemerguy
Oddometer: 249
risers
It is straight forward but I did it without any help. Not enough arms to support the bars so I just took a couple of long adjustable straps, looped them over my garage door opener, put tension on them and it made it quite easy to add the risers.
Ron Wardman is offline   Reply With Quote
Old 05-04-2011, 08:49 PM   #9
Westy99 OP
Oddometer: 221
I had a good buddy (also a member on the forum) give me a hand tonight and we got 'em installed pretty quickly. Overall it was a piece of cake, we made it a little harder than we had to by putting one of the risers upside-down but after a few cold ones we noticed it. We flipped her around quick and I was good to go.
I had read the thread about the corrosion issues with the stock TT hardware so we lubed them up before assembly, they should be good to go now.
Old 05-04-2011, 11:39 PM   #10
thleon
Theo
Oddometer: 51
Be careful the instructions may be wrong, if they still have the old ones.
you may not use the the one set of washers
http://f800riders.org/forum/showthre...mm-Bar-raisers.......
thleon is offline   Reply With Quote
Old 05-05-2011, 05:58 AM   #11
Westy99 OP
Oddometer: 221
Interesting...I'll have to take a closer look at mine tonight. I had a short ride home last night and didn't notice any excessive movement in the bars but I'll double check to be sure.
Westy99 screwed with this post 05-05-2011 at 06:05 AM
Old 05-05-2011, 06:33 AM   #12
ebrabaek
Oddometer: 4,760
As explained above.... some early instructions came with .....ehhhh.... bad steps...... But all you have to do.....is have someone old the front wheel solid in place with their legs...... you then push.....and turn the handle bar...... You will NOT be in doubt if you have the the old instructions. The handlebar will be allowed to move quite a bit on the tripple`s rubber bushing....
Erling
Old 05-05-2011, 06:52 AM   #13
Westy99 OP
Oddometer: 221
Thanks Erling...I'll check it out this evening. I followed the instructions on TT's website as I picked these up second hand and they didn't come with any instructions.
Old 05-05-2011, 11:39 AM   #14
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,844
I used my old 07 r1200gs risers
" You need a new sig line."- H14
"I despise you and want my refrigerator magnet back!" - VB Divers ex-girlfriend
bloochdog is offline   Reply With Quote
Old 05-06-2011, 05:42 PM   #15
Westy99 OP
Oddometer: 221
I got a chance to check the risers today and there was a little more flex than I'd like so we took things apart and removed the washer per the link in this thread and things are much better now.
It took a couple attempts but I think I'm going to be happy with the finally result. We'll find out in a couple weeks, I leave the 19th for Southeast Missouri.
Times are GMT -7.   It's 09:58 AM.
