Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 05-05-2011, 06:44 PM   #1
seabee1 OP
we build, we fight
seabee1's Avatar
Oddometer: 2,478
plastic welder needed
so, i've tried all of the folks i know and nobody knows anyone who welds plastic. last ride, i developed a crack in my acerbis 6 gal tank, and need it fixed. anyone here do that?
"If guns cause crime, then all of mine are defective." Ted Nugent
www.dehmotorcycle.com
Motorcycle storage with a personal touch
seabee1 is offline   Reply With Quote
Old 05-05-2011, 06:52 PM   #2
4play
Next?
4play's Avatar
Oddometer: 2,537
I never found anyone either. I messed around with a heat gun, a soldering iron & a cheap plastic gas can until I was I was sure it was sealed. Mine worked, but I replaced it before I went to Baja last year just because.
I heard there is some stuff made for repairing RV holding tanks but I never went & looked at an RV place.
Family isn't always about blood
4play is offline   Reply With Quote
Old 05-05-2011, 07:09 PM   #3
seabee1 OP
we build, we fight
seabee1's Avatar
Oddometer: 2,478
just left a voicemail with a company in phx. who does this type of work, i'd just rather see the money go to an inmate. if i get a response before they contact me tomorrow, i'll go with it. if not, then the big company gets it again.
Old 05-05-2011, 07:11 PM   #4
4play
Next?
4play's Avatar
Oddometer: 2,537
I'd go with someone that does it for a living. I was just puddling plastic hoping for the best
Old 05-05-2011, 07:20 PM   #5
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,795
I used to weld plastic at a plastics fabricator. Definitely worth using some w/ the right equipment and skills.
johngil is online now   Reply With Quote
Old 05-05-2011, 07:24 PM   #6
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,035
+1 to 4plays comment. Especially considering:
#1; its your gas tank
#2; the somewhat "central" location it occupies. Sensitive neighborhood.
I have also looked into this endevour, lots of great info here:
www.urethanesupply.com
Search the site for the pdf file of "the book of plastic repair". Very comprehensive.
What local company did you come up with? Please post your reveiw after the job.
pfdskipper is offline   Reply With Quote
Old 05-05-2011, 07:46 PM   #7
seabee1 OP
we build, we fight
seabee1's Avatar
Oddometer: 2,478
this is the place i contacted. don't know them, just did a google search. i will learn how to post pics and show you guys the before and after.
http://www.philipsplastics.com/
Old 05-05-2011, 07:47 PM   #8
Salsa
Oddometer: 360
I repaired a RV blackwater tank that the inlet wes cracked 1/3 of the way around.
I got a hot glue gun (the bigger and hotter the better) and repaired it and it held until after I sold it.
I used a torch to heat the area around the crack and heated it until the surface got soft. Then I used the hot glue to add material to the crack. I built up the area about 1/4 inch.
By preheating the tank until it almost flowed, the hot glue "welded" to the tank.
Your mileage may vary!!!!!!!!!
Don
Salsa is offline   Reply With Quote
Old 05-05-2011, 08:21 PM   #9
seabee1 OP
we build, we fight
seabee1's Avatar
Oddometer: 2,478
thanks for the info salsa, but after reading the info and watching the videos on the website pdfskipper posted, i want to make sure to use the proper material for the weld, and that the proper technique is used in applying said material. i don't want to be pissing gas on the trail after a nasty section knocked my home made weld apart.
Old 05-05-2011, 08:55 PM   #10
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,361
Originally Posted by 4play View Post
puddling plastic
2007 XR650R
2001 Montessa 315R
Garthe is online now   Reply With Quote
Old 05-05-2011, 10:37 PM   #11
AZCPP
AZCPP's Avatar
Oddometer: 395
I bought the correct plastic welding stick's and thier cleaner and repaired a hole in my IMS tank still holding after 1.5 years. I made a tip for my soldering gun and tested my patience but, it worked. I have a bunch of the stick's if you want to give it a shot I'll send you a couple. They must be the same type plastic as the tank. PM me if I can help.
Chuck
'10 KLE650CA "Versys"
AZCPP is offline   Reply With Quote
Old 05-05-2011, 10:55 PM   #12
seabee1 OP
we build, we fight
seabee1's Avatar
Oddometer: 2,478
well, that's a generous offer. i might take you up on it, depending on what transpires tomorrow. i would give it a shot if i had no alternatives.
Old 05-06-2011, 06:47 AM   #13
BIG-E
AKA; Mongo-E
BIG-E's Avatar
Oddometer: 2,054
Hey Don,
I used "plastic weld" on my 640 tank. It works really well and you can sand and paint it if you want. Works just like JB Weld only for plastic. The prep is everything.
I still have some I think, you are welcome to it. I bought it at Checker for less than 10 bucks.
"If my Technique Improves, so will my riding"!
BIG-E is offline   Reply With Quote
Old 05-06-2011, 10:02 AM   #14
skag
ResistsEnlightenment
skag's Avatar
Oddometer: 353
PM sent
skag is offline   Reply With Quote
Old 05-06-2011, 12:31 PM   #15
seabee1 OP
we build, we fight
seabee1's Avatar
Oddometer: 2,478
phillips plastics contacted me this morning and told me it'd be about a 25.00 repair, just bring in the tank. looks like i'm gonna go that route. thanks for all the advise and suggestions.
Times are GMT -7.   It's 08:25 AM.
