Old 05-07-2011, 07:15 PM   #1
dj_00 OP
GunkL
dj_00's Avatar
Oddometer: 20
Laugh Dual MSR 1L Fuel Bottles + Vario Cases + Wolfman Carrier
Finally got around to installing my fuel bottles. This involved some big guesses to get it working. If you notice, there's some clearance inside the case between the mechanics of the expansion and the actual sides of the case. You can't screw anything through the vario portion and expect any strength. So the right side (larger) case was the only option.
On the other side, the screws stuck out too far. I also used large washers where I could, just for extra strength, but after seeing how thick the plastic is, just a washer and lock nut (and blue lock tite) is probably sufficient.
Before trimming:
After trimming:
Finished product, bottles mounted. I strapped bottle #2 to bottle #1 using creative strapping. The left side straps for bottle #2 strap to the right side of bottle #1, and the right side straps of bottle #2 strap through the footman loops across to the left side of bottle #1.
Finished, mounted on bike, with the right case expanded:
Case in shrunk form:
Final note.. I'm going to place a piece or two of harder foam packing between the bottle holders and cases with double sided tape, that way they won't move up and down as much-- this happens by the nature of using webbing straps with footman loops, there's not much force preventing up and down movement, and there's about an inch to two inches of play.
2010 BMW F650GS "MOTOSUV"
2000 DRZ400S
http://www.alaska2011.com/
dj_00 is offline   Reply With Quote
Old 05-07-2011, 07:17 PM   #2
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 14,218
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 05-07-2011, 07:27 PM   #3
zouch
part-time wanderer
zouch's Avatar
Oddometer: 1,674
nice.
you're carrying the margarita makings next trip. a couple of bottles of añejo should fit in there just about *perfect*.
just a guy...
'02 GS Adv
zouch is offline   Reply With Quote
Old 05-08-2011, 07:42 PM   #4
trizzo
Oddometer: 207
what kind of reflective tape are you using on the back of your varios? solas prismatic?
trizzo is offline   Reply With Quote
Old 05-09-2011, 11:44 AM   #5
dj_00 OP
GunkL
dj_00's Avatar
Oddometer: 20
3m reflective vinyl. my buddy with a vinyl cutter and I designed the pattern.
2000 DRZ400S
Old 05-10-2011, 09:08 AM   #6
Manventure
Oddometer: 136
Nice. I myself am trying to figure out how to do this with the expandable mechanism on my cases.
If I think of anything that would work better I will take pics and post, if not I will shamelessly copy yours.
Manventure is offline   Reply With Quote
Old 05-10-2011, 06:06 PM   #7
greggNJ
wannabe adventurer
greggNJ's Avatar
Oddometer: 100
Question Rivets?
What do you guys think about using rivets (w/washers)? They'll protrude into the case less than bolts & nuts.
Gregg
'03 F650GS Dakar-SOLD
2012 JKU Rubicon
greggNJ is offline   Reply With Quote
Old 05-11-2011, 09:54 AM   #8
dj_00 OP
GunkL
dj_00's Avatar
Oddometer: 20
As long as the rivets are sufficient for the forces involved, I don't see why that would be a problem. Bolts and nuts as shown work perfectly. You just need to be careful of placement to avoid interference when replacing the front piece of the cases.. Part of the process I didn't document was unscrewing the 6 torx screws on the back of the cases, which allow you to pull the whole front off along with the expansion mechanism.
2000 DRZ400S
Times are GMT -7.   It's 08:28 PM.
