05-17-2011, 04:50 PM
#91 |
Oops...
I dont think the wheels look bad at all. I'd PREFER great big truck tires, just havent found any screaming deals. Yet. I've decided that unless the price goes way down, theres just not enough rubber left on the tires to justify the rims, 'specialy with the one boogered like it is.
Todays progress! Played hookie from school today, fixed the mustang in the morning, then went the "Three Piggie Opera", then had lunch with my wife, then about 4 other things... Busy morning. Finally got to head in to town to pick up some tools and parts! ![]() ![]() ![]() Installed the new seat. Before: ![]() after! ![]() Still think they look okay... but time to come back off. ![]() Yanked the grill off. ![]() And bolted the engine to the stand. Not sure if I trust it yet. SUPPOSEDLY the engine wieghs 560 lbs. The stand is sposed to hold 750, but it sure seems small for that engine... ![]() Anyone know anything about rust converter? Does it work? Should I bother?
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. |
05-17-2011, 05:11 PM
#92 |
Oops...
Yes, I *really* like those black rims as well. Those are cheap enough that if I found a really good deal on some rubber I'd consider doing that.
Got one other thing done today that I've been putting off for WAY to long- Changing the oil in my coveralls. Hope the washing machine can handle it.
05-17-2011, 05:26 PM
#93 |
Syndicated
Oddometer: 11,285
Mmmmm, nothing like a freshly-surfaced flywheel. Dowels? You can prop up the hanging end of the motor with a piece of timber and a floor jack. Just wash a load of white t-shirts afterward to clean out the drum ![]() |
05-17-2011, 10:25 PM
#94 |
Oops...
Dowels?
![]() I might be in trouble... The coveralls oil change didnt go so well. ![]() ![]() On an unrelated topic- My coveralls are BLUE. Who knew!? ![]() Spent the last hour searching for radiators. LMC- I think the cheapest one was just under $300. Next cheapest I could find was in the $150 range. FINALLY found one for $75 shipped from Shepherds auto. Fingers crossed... You get what you pay for. Thats the bad thing about buying a cheap truck- you never want to spend money on it cause every part you buy cost MORE THAN YOU PAID for the dang truck!
05-17-2011, 10:53 PM
#95 | ||
Oddometer: 6,915
Or, get a wheel and tire package super cheap. I got a set of steel wheels for my Camry for $46 each when I bought my snow tires. Quote:
05-18-2011, 05:49 AM
#96 | |
Oddometer: 868
05-18-2011, 06:20 AM
#97 |
Syndicated
Oddometer: 11,285
05-18-2011, 06:58 AM
#98 |
Jellyfish Proctologist
Oddometer: 1,946
Is your old radiator so bad that a radiator shop couldn't fix it? I've had better luck with a well-serviced original radiator than with any cheap replacement. Even if it needs a lot of work, the materials are so much better in an old radiator (heavy brass end caps, etc) that you end up with a better product at the end for the same (or usually much lower) price.
05-18-2011, 07:52 AM
#99 | |
Careening forward
Oddometer: 5,662
I've heard good things about this stuff, which I'll try at some point. http://www.eastwood.com/rust-solutio...FQzNKgod6UBGEA
KLX 400 dual sport Tune in, turn on, drop out. |
05-18-2011, 08:32 AM
#100 | |
Oddometer: 5,627
KTM 640 LC4E KTM 200 MXC XT200 |
05-19-2011, 01:16 AM
#101 | |
Q.E.D.
Good job on the repairs, im sure it will last you a loooong time!
Not necessarily. My 92 Rodeo is only worth 300$ KBB. But I put in some $1600 into it knowing that it would outlast any other cheap car nowadays. So in a way you are paying more than its worth but if you had another car- well lets just say-- YES they are worth more and YES the parts to repair are ALOT. So your winning here My costs plus labor at my repair shop, something like: $150 replace brakes plus new rotors. $300 replace brakes (drum- yuck!) the brake cylander was leaking too, had that replaced. $500 replaced timing chain. (You ever wonder why most cars nowadays have belts??) $600 replace front axle plus boots. Was $300 but had to drop out differential to take it completely out. Anyways I think your doing a good job, would like to do that stuff except the parents wouldn't like that too much!
05-19-2011, 05:05 PM
#102 |
cool hand fluke
Oddometer: 316
Nice truck!
I think the Dentsides were my favorite Ford, and that 300 is bulletproof. You might be interested by this however: http://www.ford-trucks.com/forums/25...y-300-six.html 6.5 Chevy Turbo - the injection kit from a newer 300, injectors from a 302 and you are rolling ;)
Adrian, Central & South America, 2011/2012 02 GS I know violence isn't the answer. I got it wrong on purpose. |
05-19-2011, 05:27 PM
#103 | |
Oddometer: 8,167
05-19-2011, 06:25 PM
#104 |
Oops...
I've thought about doing the chev turbo. Havent been able to scrounge up a cheap useable turbo yet though. Think I could do the 6 carb conversion for a lot less than what I've seen turbos go for. Most likely it'll stay stock for now, although I'm considering either the chev rocker arm swap or a cam... No progress yesterday and likely none tonight. Hopefully I can spend some time on it on Saturday.
The radiator shop said my rad wasnt worth fixing. The cheapest they could find me was around $180.
05-19-2011, 08:53 PM
#105 |
Oops...
Okay, I lied. Went out to tidy up the shop a little and got sidetracked...
![]() Decided to trust the engine stand so I put the hoist away. While I was at it I popped the thermostat out and the water pump off and drained the rest of the coolant. The truck would NEVER warm up... unless I had the rad completely covered. I figured it had a bad t-stat, but it looks fine other than its about 35 degrees colder than the stock one! Water pump looks okay too, but they are cheap and its off, so I'll put a new one back on.![]() I had the engine rolled over on its side for a bit and you can see where the oil is leaking... Right where the dipstick goes into the oil pan. Too much gunk to see what the deal is there. Man, I wish my pressure washer parts would show up!
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. dorkpunch screwed with this post 05-19-2011 at 08:59 PM |
| Thread Tools | |
