Old 05-08-2011, 01:37 PM   #1
rockycraig OP
Oddometer: 180
Eek Tubed Tire question??
In a pinch does the slime tire sealant actually work for a punture on a tubed tire? I'm looking for a temporary fix for a flat on a tube tire without actually taking off the wheel and changing the tube. We ride in the middle of nowhere so there won't be a truck coming in and picking the bike up. Any suggestions would be great, I seen the tubeliss system, not sure about that, wish the 800 had tubeless tires seems so much easy to fix with a puncture kit.
rockycraig is offline   Reply With Quote
Old 05-08-2011, 06:31 PM   #2
GJGSRider
carver
GJGSRider's Avatar
Oddometer: 67
Tyre guardian
Check this out : http://www.advrider.com/forums/showt...=tire+guardian
I have used tyre guardian for 8000 miles or so. No flats, but no punctures. I don't notice anything. I bought it again for my new tires. Time will tell but after reading I think it's worth a shot.
RJeff
05R1200GS then 09F800GS now
GJGSRider is offline   Reply With Quote
Old 05-09-2011, 06:16 PM   #3
spafxer
spafxer's Avatar
Oddometer: 2,326
I have used Slime one time.. A 16 penny nail had punctured the tube early in the day. It worked great, and lasted until I wore that tire out.
Others complain about the mess when changing the tire out, maybe they used it on a tubeless tire, I don't know.
For me, Slime worked great, and I still carry some with me. Along with patches, and new tubes.
spafxer is offline   Reply With Quote
Old 05-10-2011, 01:09 PM   #4
sturgeon
sturgeon's Avatar
Oddometer: 745
Aren't there tubeless and tubed versions of Slime?
The tubed version probably eats naked rims for lunch
sturgeon is offline   Reply With Quote
Old 05-11-2011, 03:20 PM   #5
tmex
tmex's Avatar
Oddometer: 2,039
I've tried it three times, and it worked once. Probably depends on the nature of the wound. Worth a try if you have it handy.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 05-11-2011, 03:25 PM   #6
BikePilot
BikePilot's Avatar
Oddometer: 10,901
I've never seen slime work in a pinched tube. Also note that if you get a flat while riding and don't get stopped before the air is all gone you'll probably have lots of pinches and a torn-out valve stem. Personally if I have a tubed tire go flat i stick in a new tube, no screwing about with patches, slime or other gooey substances
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 05-11-2011, 09:32 PM   #7
toowheels
on a mission...
toowheels's Avatar
Oddometer: 837
I've used Slime (tubed) twice.
Got it from a bicycle shop at the time.
First time it didn't hold a 100% as it was a nail that went through and made two (big) holes in the tube. It would hold air for about 30mins so I would stop, pump it up and go again. I was out on a logging road, in the eve., so I didn't feel like fixin it out there in the dark...and I didn't have to because I could make it home...eventually
Didn't find it too messy either.
Second time it worked perfectly! Like someone mentioned above I ran it until the tire was dead. It stayed in there for at least 3000km's and then I had it switched out with new tires on my way to Baja. No problems on the highway either.
I still carry one with me at all times now (in my MOD tool box on the skid plate).
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
& Giant Loop for Canada
www.motooverland.com
toowheels is offline   Reply With Quote
Times are GMT -7.   It's 04:28 AM.
