Old 10-01-2011, 08:57 AM   #46
ebrabaek
Oddometer: 4,745
It would be interesting to see a diagram of the inside of the RR....... Anybody have one?????
Erling
Old 10-01-2011, 02:53 PM   #47
LukasM
Oddometer: 5,418
I haven't seen a diagram but due to the part number I am quite sure that it's just a regular Shindengen shunt type R/R like 95+% of other bikes have - prefix SH. Some of the higher tech jap bikes get the MOSFET ones stock - prefix FH.
LukasM screwed with this post 10-01-2011 at 03:09 PM
Old 10-02-2011, 09:54 AM   #48
Toadride
Toadride's Avatar
Oddometer: 836
I don't think I chimed in here about my stator replacement.(last week) Still had three months warranty left so I got in under the wire. I guess it was losing it slowly for some time now as I can remember some low battery events like engine turning over and locking at TDC well over a year ago. Figured it was just the orig. battery slowly giving up and when it increased a couple of months back, I replaced it. Then the new one lost charge in a few days so I looked further to see my stator output was 11.9 V. Anyhoo, all is well and happy again as I got a service at 50,000kms., stator replacement, valve check and new cover gasket replacement (it was leaking too) all for 2 bills. The valves were fine with no need of adjustment and the mechanic, who used to fix a lot of Ducatis back in the day with stator burnouts said they solved the problem by running a ground wire from the regulator to the frame. He did specify it is key to grind away the non conductive coating on the regulator to get a good ground. Same for the frame, of course. Hope this works and I am not putting out $800 plus for one of these in another 50000. And I am surprised that BMW is not acknowledging this problem and showing a fix on newer models.
Old 10-02-2011, 07:16 PM   #49
JRWooden
Oddometer: 4,257
Toadride:
I can see how a bad ground might cause early death of the regulator, but given the design of our systems where the stator is (as I understand it) ALWAYS putting out 100% of what it can give I don't see how a bad ground could cause stator failure ...
I'm not saying your tech. has it wrong ... there's a damn good chance I don't know WTF I'm talking about ...
I do think a bad ground could cause lots of other "interesting" problems, so I'm adding a check to my maintenance sheet to check the R/R ground once a year or so...
Old 10-02-2011, 09:19 PM   #50
ebrabaek
Oddometer: 4,745
I fully agree that a bad ground can severely diminish the rr function.
It's easy to speculate how the rr is constructed.... And personally I don't have an idea how th 8 gs rr look on the inside.
But most like Lukas mentioned are just a bunch of diodes which does the rectification....
But if you have a bad ground.... The rr can't dissipate the exess energy to ground.... And it's gonna go somewhere.
I will have a look at my grounding tomorrow....
Erling
Old 10-02-2011, 11:37 PM   #51
Toadride
Toadride's Avatar
Oddometer: 836
Don't believe I mentioned anything about a bad ground. The mech just said that adding the extra ground at the regulator fixed the Duc problems with burning up stators. I think we are both hoping it takes care of any future problems with mine.
Old 10-03-2011, 05:54 AM   #52
ebrabaek
Oddometer: 4,745
True.... You did not..... But the stator have to be grounded........ That is how it dissipates the heat.... Only reason it need a "extra one" is if the factory one is bad...... Some RR`s are grounded via a chassis mount....In which same apply. So you wan`t to check the grounding in general...... But adding another wire would work as well....as long as it`s grounded.....
Erling
Old 10-03-2011, 08:57 AM   #53
itsatdm
itsatdm's Avatar
Oddometer: 4,873
Maybe another reason to check contact points. R/R housing is aluminum, the chassis is steel = galvanic corrosion. The contact point on the frame is some type of insert, maybe a means to combat corrosion.
Old 10-03-2011, 05:41 PM   #54
TheCowboy
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
Today, 1/2 way into a month-long ride - the display blanked, then came on again - then off, then on. Stopped for gas in the middle of nowhere New Mexico - would not restart. Jumped battery to start - raced 12 miles to Auto Parts store - rechared battery - raced 100 miles to Durango CO. Now stuck here. Will try to make the BMW dealer 20 miles to the West tomarrow on just what is left of battery.... oh yes, I am at 50,400 miles. First failure on bike. I am sure it is the stator. I think it will be expensive.
TheCowboy
TheCowboy is offline   Reply With Quote
Old 10-03-2011, 06:03 PM   #55
JRWooden
Oddometer: 4,257
Cowboy ... that sucks....
Not sure if you've been following the threads on this, but if you buy from BMW you get a new flywheel in the "kit" not sure why ... I would not expect the permanent magnets in the flywheel to be much of a problem .... but with the flywheel it bumps the price quite a bit apparently to some $800 or so...
If it is the stator, a competent shop can re-wind your stator for you saving you some cash ... price ~$150.
Apparently the mechanics of replacement are pretty simple.... key thing is to torque the side cover bolts in proper sequence when re-assembling. I can post that sequence ... if you need it let me know!
Old 10-03-2011, 07:14 PM   #56
TheCowboy
TheCowboy's Avatar
Oddometer: 606
JR, yes, please give me that sequence, also, how do you unplug the wires from the stator? I have cover off but cannot figure out how the wires come off so I can pull stator completely off... thanks
TheCowboy
Old 10-03-2011, 07:37 PM   #57
JRWooden
Oddometer: 4,257
Ok ... if I did this correctly there should be an attachment showing how the stator wiring is removed ...
basically from the back of the regulator is seems.......
Old 10-03-2011, 07:40 PM   #58
JRWooden
Oddometer: 4,257
next installing the (repaired) stator:
Old 10-03-2011, 07:44 PM   #59
JRWooden
Oddometer: 4,257
next ... sequence for bolting up the cover below...
THEN install all the other crap you took off,
make sure the regulator is FIRMLY grounded / bolted to the frame...
check oil level etc....
Old 10-04-2011, 02:52 AM   #60
LukasM
Oddometer: 5,418
That sucks... Rick's Electrics can probably turn a rewind around in a day or so if you give them advance notice ($165 incl. return shipping).
And the wires stay attached to the stator, so just unplug the connector at the other end.
Times are GMT -7.   It's 07:27 PM.
